11-05-2013, 05:02 PM | #1 |
Trader Rating: (43)
Feedback Score: 43 reviews
My storage unit is too damn full...sale!
So I have way too much crap sitting around and would like some space back, best way to get ahold of me is via PM, if you have any questions feel free to ask.
Prices - Pricing does not include shipping, if you're going to make me a shipped offer please keep this in mind. Some items have wiggle room while others do not, if you try and lowball me don't expect a response, simple as that. I accept payment via paypal, chase quickpay and cash for locals. Shipping - I tend to ship smaller items via USPS Priority due to the cost, integration with paypal and location as I can drop the packages off on my way to/from work. Larger items will be shipped via FedEx ground, I do not ship via UPS. Pictures - Due to the large numbers of items pictures will be added to a photobucket galary and a link will be posted next to the section. Over the next couple days I will be taking pictures of everything, if you don't see a picture of an item you're interested in check back in a couple of days or just let me know. Engine - Pictures can be found here. SPL 3" SR20DET Downpipe - 100.00 Full stainless, used but in great shape. Megan 3" Downpipe - 90.00 3" stainless downpipe with built in flex section, used but in good shape. Megan 3" turbo outlet - 65.00 Used but in good shape, full stainless, no hardware/gaskets. KoyoRad 53mm S13 SR20DET Radiator - 225.00 Fins are in great shape, no damage to the fins or end tanks. Mishimoto radiator shroud - 140.00 Comes with slimfans, keep that SR cool! Cusco sidemount pipes - 180.00 A little beat up but still in good shape, another cool little JDM bit. 3" S13/S14 Test pipe - 30.00 each Not much to say about these, stainless and in good shape, I have two of these. Exedy STG2 clutch - 150.00 Used but has a ton of life left, sprung 3 puck model. Stock SR flywheel - 60.00 Stock S13 SR20DET flywheel, no hot spots. S13 SR20DET IACV - 50.00 each I have two of these, worked when pulled. Stock S13 SR20DET Sidemount Cores - 25.00 each Have two cores, both are in good shape, do not come with piping. S13 SR Valve Cover - 85.00 Powdercoated in a metallic satin red with polished lettering. No scratches in the finish, in awesome shape! ISIS KA/RB Oil Cooler - 165.00 Brand new and never used ISIS oil cooler for KA24DE/RBxx motors. Stock PS Reservoir- 25.00 In pretty good shape, pulled from my S13 coupe. S13 SR20DET Oil Catchcan - 15.00 OEM piece that mounts above the exhaust manifold. Oil Catchcan - 130.00 Custom piece that mounts behind the headlights, huge capacity, it no longer fits with my PBM highmount. S13 SR Transmission - 150.00 This was my spare, was told it was in good shape although I never personally used it. S14 VLSD - 125.00 Still in pumpkin, appears to be in good condition. SR20 Headgasket - 60.00 Came with my OEM gasket kit and never ended up using it. Still in packing. S13 SR20DET Braided Turbo Lines - 55.00 Some fittings will need to be replaced, although the lines are in great shape. S13 SR20DET Braided Turbo Lines - 110.00 EARLS branded lines, only used for a short amount of time, in great shape. S14 SR20DET Braided Turbo Lines - 110.00 EARLS branded lines, only used for a short amount of time, in great shape. HKS Adjustable Actuator - 100.00 Only used for a short amount of time before going to a EBC and stock actuator. SR20DET Turbo Outlet - 25.00 Stock cast unit, in good shape. S13 SR AC Compressor - 60.00 Came off a 91 Redtop, comes with bracket, told to be working condition, no play in the pulley and spins freely. S13 KA AC Compressor - 50.00 Comes with bracket, was working when pulled. AC Random Bits - Offer I have condensors, dryers and lines, let me know what you need. All from S13s GReddy TypeR/Hotpipe Combo - 160.00 GReddy hotpipe with a legit GReddy typeR blow off valve. S13 FMIC 350.00 Unknown core, setup for S14/S15 T28 or S13 SR with aftermarket intake manifold. Core is in great shape and comes with a legit HKS SSQV. RB25 Crank pulley - 60.00 OEM crank pulley in great shape, rubber is not cracked, purchased to replace a chipped pulley. Forge Intercooler - 180.00 Brand new Forge intercooler, fins are pretty much perfect! Walbro 255 - 80.00 Used but in great condition. DET Fuel Rail - 40.00 Comes with FPR and injector caps. Electronics - Pictures can be found here. S15 PFC L-jetro - 675.00 Used but looks pretty much new, purchased from GTR-Garage for my S15 swap but never finished due to the motorset getting damaged in shipping. Comes with commander, original instruction set and original box. S14 PFC D-jetro 925.00 Came out of a car I purchased and ran great, moving onto a full standalone. Comes with the newer OLED commander, MAP/IAT harness and sensors and has been tuned for S15 turbo and STi injectors. FCDatalogit - 300.00 Used only a handful of times, comes with the datalogit, serial to USB adaptor and software. AVC-R boost controller - 300.00 Pretty much new, never installed in a car. Comes with MAP/Boost control solenoid. GReddy Boost Gauge - 125.00 Black/White electronic 52mm series, complete and ready to install. Autometer Oil Temp Gauge - 45.00 Worked great, comes with gauge, wiring and sensor. HKS Turbo Timer - 85.00 Type0, comes with Nissan patch harness, no cutting up your stock harness! Nissan WC ECU - 125.00 Worked fine when pulled, no corrosion or other damage. S13SR Harness - 150.00 Already has been converted to be used in a USDM S13 chassis, both upper and lower harness. VDO Boost Gauge - 35.00 Mechanical boost gauge by VDO, black/white 52mm model. VDO Volt Gauge - 30.00 Black/white 52mm gauge. Defi BF Oil Temp Gauge - 165.00 60mm model, white face with green blacklight. Comes with gauge, harness and sensor. Defi Exhaust Temp Gauge - 80.00 A little beat up but still in working condition. 52mm model. Comes with harness and sensor. S15 SpecR MAF - 65.00 Was going to use this with the above PFC but scrapped the project. KA ECU - 45.00 Pulled from a running car, 91 dual cam model. HUD Projector - 25.00 Each OEM HUD Projector, in working condition. I have two of these. Eclipse Double Din - 250.00 Older Eclipse double din unit with GPS and Ipod hookup. Comes with harness, older eclipse AMP, monster cables and some other audio components. Worked when pulled from my miata. Lamco Boost Gauge 70.00 OEM 04 STi boost gauge, bolts to your steering column. Interior - Pictures can be found here. Corbeau fx1 Pro - 275.00 Each Only used for a couple of months, used but in great shape, no tares/stains/rips. Recaro Pole Position - 680.00 Brand new seat, it was produced in may of 2013. Never used. Momo 280mm Wheel - 130.00 Genuine Momo wheel, comes with steering wheel and horn button, leather is in great shape! Personal Neo Grinta 350mm - 225.00 Pretty much new, leather is in great shape along with the red stitching. Comes with red personal horn button. Yashio Factory Shift Knob - 80.00 This is the 6speed knob, brand new still in packaging. Stock S13 Shift Knob - 20.00 Stock 5 speed shift knob in good shape. Z32 Shift Knob - 30.00 OEM weighted Z32 knob in good shape. Coberu Camlock 5 Point Harness - 125.00 Each I have two of these, I'll check the FIA date on them but I do not believe they are expired. Apillar Gauge Pod - 25.00 Double 52mm unit for S13. Suspension - Pictures can be found here. SPL Toe Arms - 185.00 Latest model, has some surface rust but joints are in good shape. Circuit Sports RUCAS - 110.00 Used but in good shape. Circuit Sports Tension Rods- 100.00 Used but in good shape. Stance RUCAS 240.00 Brand new, latest model, never even mounted. SPL Eccentric Lockout Kit - 35.00 Brand new in box, for S13 HICAS model. Whiteline HICAS Bar - 115.00 Brand new, still in packaging. NISMO Powerbrace - 160.00 For S13, light surface rust but in good shape. JIC-Magic JIC FLT-A2 - 1250.00 On the fence about selling these, PM me if seriously interested. Apexi N1 Coilovers - 550.00 Overall in good shape, model with the helper springs. Rears are a little bouncy, fronts are rock solid. BuddyClub P1 Wheels 17x9 - 950.00 Light curbage but overall in good shape. I will be creating a more detailed FS thread under wheels section. Work Ewing - 750.00 16x7 Light curbage but overall in good shape. I will be creating a more detailed FS thread under wheels section. 7mm Spacers - 10.00 Autozone special spacers, they are cheap and work. HPS Z32 Pads - 125.00 Used for about 15 miles before switching to a more aggressive pad, both front and rears in pretty much new shape. Tein EDFC - 250.00 Each Comes completed with harnesses, motors, control unit and install kit. I have two kits. Work RS Lug Nuts - 165.00 Brand new in box, never used, red in color. Body - Pictures can be found here. Silvia Fenders - 300.00 Local only Pair of black silvia fenders in good shape, one has a dent the size of a half dollar. Silvia Hood - 175.00 Local only In good shape, will need to be cleaned up and painted. Currently in black. Silvia Bumper - 150.00 Local only Q's bumper, cut for FMIC, currently painted black. Dual Projectors - 250.00 No broken tabs or damaged glass, these are in great shape! Silvia GTR Grill - 90.00 Black, in good shape. Silvia Grill - 80.00 Silvia small letter grill, tabs in good shape. Silvia headlight brackets - 55.00 In good shape, no bends or broken bolts. Chuki Skirts - 325.00 Comes with install hardware, paint is in OK shape but the skirts are not cracked. Ebay S13 FSB - 30.00 Ebay S13 RSB - 30.00 Miscellaneous S13 Coupe Shell - 1000.00 I'll make another thread for this aswell but if anyone is interested just shoot me a PM. I have a very clean S13 coupe shell from california. I purchased the car to build but came upon another coupe that already had a very nice cage and no longer have a use for this car. Zero rust and is in great shape. No front end, suspension or wheels. Come bring your own bits. S13 SR20 Motorset - 2250.00 More information can be found here - http://zilvia.net/f/sale-items/54189...2950-00-a.html I also have stuff left over from previous cars, if anything interests you shoot me a PM. G20/FWD SR20 Parts SR20 Flywheel DET Turbo outlet Fog covers DET fuel rail Miata Stuffs PS Setup Alt 1.8 Starter 1.8 Starter NB Dash NB Center Oil cooler Interior MSC Cool box NB MAF NB ECU NB Endlinks EVO Stuffs Stock sway bar Cusco sway bar Evo8 center caps Clutch line - braided Evo8 highflow CAT Aluminum racing lugs Camber bolts Rear LCA Evo pocket din Last edited by hobbs; 11-26-2013 at 10:41 PM.. |
11-06-2013, 05:51 AM | #9 |
can you send pics of the bride driver side rail and SPL Eccentric Lockout Kit to [email protected]
11-06-2013, 03:54 PM | #13 |
Trader Rating: (43)
Got back to most of the PM's that I got so far, still working on the pictures so please just be patient.
Also, if you PM me asking "what's your lowest price" you wont get a response. Asking prices are posted next to each item, either you pay my asking price or you need to make me an offer. West suburbs of chicago. |
11-07-2013, 01:52 PM | #17 |
You weren't kidding about being full. Interested in the Buddy Club wheels. Are they P1, PIIs, or QFs; offsets? Also interested in some NB parts. What year is the center console from? Would you happen to have:
-gauge cluster hood -e-brake cover -passenger side dash kick panel -driver's side sun shade
s14| y34| 911 gts| exige s| 600rr| r3| 250r| 85 girlfriend |
11-07-2013, 11:33 PM | #18 | |
Trader Rating: (43)
Been dealing with some pretty nasty food poisoning this week, hopefully will have all of the albums filled this weekend for you guys.
Payment recieved on the following items: - AEM UEGO - 370cc injectors - R33 rear calipers - Brembo rear rotors Quote:
11-08-2013, 09:28 AM | #19 |
...in for pics
cONtRol FReAkS |
11-08-2013, 08:49 PM | #20 |
Greddy boost gauge... it's fully electronic, so boost sensor is under the hood? And what unit does it measure in? If PSI, message me
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
11-20-2013, 05:18 PM | #22 |
interested in one of the Bride Brix.
pending pictures of course. i will PM you with my number/email for you to send to me once you get a chance to snag some. thanks! |
11-23-2013, 09:15 PM | #24 |
Trader Rating: (130)
Feedback Score: 130 reviews
Hey can you send me pix and model numbers of the double din head units, and pix of the yashio shift knob?
