09-03-2013, 11:17 AM | #1 |
12.4 AFR's at idle
SR20DET: enthalpy tune, 740cc injectors, z32 mafs, Tomei 256 cams, and aeromotive fpr.
At idle it won't lean out anymore than 12.4 or so. I know that with bigger injectors idle will be richer but this is ridic. I rev it out and it blows smoke. Kinda embarrassing if you ask me. I can't seem to figure out the rich issue and its driving me up the wall!! CenTex240 |
09-03-2013, 11:27 AM | #2 | |
The supra at our shop that idles at 13 doesnt blow smoke either. |
09-03-2013, 11:51 AM | #3 | |
CenTex240 |
09-06-2013, 03:04 PM | #4 |
What's your fuel pressure like? do you have an adjustable fuel pressure regulator?
It's possible the o-rings are seeping too. Especially if you did a quick job of installing the injectors which a lot of people try to rush to get in. Thanks
Like Me on FaceBook ! |
09-12-2013, 10:36 AM | #5 | |
I just pulled my plugs and cleaned them. The top of the pistons were wet. Mind you the car has been sitting since Monday. So should I pull the manifold, remove fuel rail and charge prime the system and then see if the injectors are leaking? CenTex240 |
09-12-2013, 08:01 PM | #7 |
I have the same issue my AFR is at 13.7-13.2 at idle,runs real strong at wot and cruising. I think it my ecu the tune thats on it. I just changed the pump and pressure tested it. Can't figure it out Too!
09-12-2013, 08:05 PM | #9 | |
Trader Rating: (58)
Feedback Score: 58 reviews
Check for vaacuum leaks, check timing, and make sure idle is proper...make sure TPS is registering closed etc etc.
09-12-2013, 08:09 PM | #10 |
Is it warmed up when its running rich?
Did you pull the rail and spin the CAS with the key on ignition off? Is the o2 hooked up, clean and functional??
09-12-2013, 08:20 PM | #11 |
I've checked everything,I'm very picky about my motor. I always warm it up and at about 170-175* it idles at 800rpm timing and 14-15* TPS at .46v . At idle you dont really smell fuel bad. I had a straight pipe 2.5in off the turbo no muffler and never blows smoke. I just did the head all new stuff in it. I just put a magnaflow round muffler on it and the same afr. Idle valve works fine I cleaned it. O2 is working but I can change it too but it about 5-6months old.
09-12-2013, 09:42 PM | #12 |
Trader Rating: (58)
So the setup was working perfectly fine until you rebuild the bead? As in your AFR and tune were all the same before?
Look into what you changed/fixed/remvoed.
09-13-2013, 02:23 PM | #13 |
Today I checked for leaky injectors and there were none, boost leaks and there were none, cleaned the z32 mafs, made sure the ground was nice and tight, and made sure the tps was set at .45 with the tb closed.
Still idling in the low 12's. Still have yet to clean the o2 sensor, and replace the ecu coolant temp sensor. The only other thing that would be even remotely possible is having a fault in the wire harness somewhere. CenTex240 |
09-13-2013, 02:29 PM | #14 |
Since I've rebuilt the head the car has been running rich. If I indeed raised the compression ratio by decking the head and a valve job then how would I go about leaning out the mixture?
Am I crazy or have I heard that at idle bigger fuel injectors richen the mixture? CenTex240 |
09-13-2013, 04:46 PM | #16 | |
I'm guessing its time for a safc and have it dyno tuned? CenTex240 |
09-13-2013, 04:49 PM | #17 | |
CenTex240 |
09-13-2013, 05:32 PM | #18 | |||
Trader Rating: (58)
09-13-2013, 05:44 PM | #19 | |
CenTex240 |
09-13-2013, 06:19 PM | #20 | |
09-15-2013, 05:06 PM | #22 |
Did some driving today and noticed that while driving, the AFR's fluctuate brewed 14.6 and 15.7. Back and forth. So I guess I'm just going to leave it alone and not worry about it anymore. If the car idles rich then that's fine. I figured I'd just inform the ones who are interested in my findings.
CenTex240 |
09-15-2013, 06:07 PM | #23 |
Trader Rating: (58)
The afr's will move around a bit when ideling, it'll never be perfect or even on the same tenth that long.
I'd just make sure the tune you have is for those injectors, as they all do behave a little diffrently in that regard. Another thing to check, is to make sure you FPR is actually raising pressure properly.
09-16-2013, 06:26 AM | #24 | |
CenTex240 |
09-16-2013, 11:59 PM | #25 |
Best thing i can think of is dropping static fuel pressure a little more.
If you are in the 10's in boost you can afford to pull some more fuel that way. If you are doing good in 11's dont touch it. You can go as lean as 15-16 in low loading/cruise and still fare ok. All else fails? Save up for a real ecu. Safc is garbage. Thank you for that moronic analysis.
Just another broke ass drifter |
09-17-2013, 07:48 PM | #26 |
Here's what mine does at Idle it's warmed up about 180*.
SR20det AFR Idle issue - YouTube |
09-19-2013, 06:01 PM | #27 | |
Thanks again for the help guys. I'll post it up if I find out what might be causing the issue. CenTex240 |
