![]() Ok so my SR was running fine one day, then all of the sudden it sputtered out and died. Engine would crank and crank all day but would not kick over. Push started it and it ran, but the boost gauge wasn't reading anything (0 psi) and would stall once you took your foot off the gas, car smoked the whole time as well(car needed a tune prior, so i couldn't tell if the smoke was just the norm or was something else). Well, i got the car home, then went through a few things, compression, spark were fine but i haven't checked the fuel yet. After killing my battery from the countless tries
Could this also be caused (or the dying out at-least) from regular pump gas? I heard that from one source but not 100% sure if its true. If so, i'm going to get octane booster asap and try that too.
#5 |
Is your fuel pump running? If so do you have fuel pressure? No gauge, go buy a cheap one and hook it inline. Your battery is going to continue to die unless you charge it between times working on the car.
#7 |
I put a s14 sr in my s13 about two weeks ago. Had the same issues you did. We looked through every possible problem that there could be. It ended up being a wiring issue in the lower harness. Check your grounds, use a solder gun, and triple check that all the plugs are wired right to the ecu. We had to take the lower harness out and check every little thing. It runs beautifully now . I suck at wiring so my friends did it. If u want more and correct info I can have my friend tell you exactly what was wrong..
#9 |
Wow i didn't see your post until today, but i guess thats my last and only option. I got the starter tested and it was fine, so ill have to start taking the harness apart :sigh: ill update if that works.
s14 sr20det 240sx silvia |
