![]() Hey all,
So im one of the lucky ones stationed in Japan who got the opportunity to purchase a S15 Spec-R. The issue is I cant tell if this motor is a S14 or a actual S15 engine since its past is unknown or wheater this engine has been swapped. The reason I ask is because I know that on most S14 engines they use the acorn style valve cover nuts and on S15s they usually have the flat nuts. This particular engine has acorn style. I need to change the valve cover since mine is cracked and leaking oil and I know S14 and S15 valve covers differ. I did the obvious checks, the VIN came back as a actual spec-R, the ECU is a S15 spec R ECU, and the injectors are also S15 spec-R 480cc. Is there anywhere else on the motor I can check to see where this motor came from or were there S15 motors with acorn style nuts as well? For all I know this motor could be a half S15/14 motor. Thanks! I know in the photo its hard to see, but the nuts on the front of the valve cover are acorn S14 style |
What makes you think that the motor was swapped? From my understanding the valve covers are identical, it's just the hardware that differs between the two...
Well take it for what you will, but there are different part numbers amongst the two valve covers.
S14 SR20DET: 13264-69F02 S15 SR20DET: 13264-91F00
#6 |
The previous owner stated that the prior motor overboosted and blew, but that was information he got from the person he bought it from. The valve covers are identical for the most part except the coil packs don't fit properly between the two.
#8 | |
![]() Join Date: Dec 2007
Trader Rating: (63)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 63 reviews
Well first of all you if your motor has 6 speed, 99% sure it is S15 motor. only few will bother to go through 6 speed conversion for S14 motor. S15 and S14 Kouki SR20s have bolt for valve cover and S14 Zenki and S13 SR20s have washer and nuts for valve cover. In your case, someone could have been replaced it old style for some reason or replaced with S14 head since they are identical. |
#10 |
I forget that the coil pack area was changed on the S15 for the smaller dia coils.
#12 | |
#13 |
The P12 may have the same diameter coils. The P11 uses a distributor and plug wires.
#15 | |
Trader Rating: (63)
Regardless what motor you have, if you have S15 coilpacks get S15 valve cover. S15 coilpacks are different than Spitfire coilpacks. |
#16 | |
![]() Join Date: Jun 2007
Also, get an account here: www.zeroyon.com
#17 |
![]() Join Date: Feb 2009
^^^ loved going out there to see the..... um..... cars. You can also go to bill at b&m right out gate 1 also. But def get an account on zeroyon. The guys on there are pretty cool.
#19 | |
#20 | |
Man w/ CTSV & a Car Seat
