![]() So I recently rebuilt the top end on my car (obviously something went wrong)
I tried to start the car up for its initial run, let everything prime, etc.. but nothing, she'd crank and crank and crank, it sounded a little rough at first but it certainly didnt sound like it grenade'd all four rocker arms.. ![]() I'm not sure if jumping a tooth on startup could have caused this or what. I'm stumped, I measured shims out, put everything back in where it went, and hand cranked it a few times to see if the timing lined up. Now my question is.. how can I tell if a valve may be bent? Or is it really a risk if they just all sort of fell off after they broke? Any advice or anybody ever have a similar experience? |
shoulda bought my car lol. that really sucks man
http://zilvia.net/f/showthread.php?t=637070 last of my parts f/s |
![]() Join Date: Sep 2006
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 16 reviews
Did you measure valve height for each shim?
HOW TO: Measure Valve Shim Heights (Pics) - SR20 Forum Im doing the shims now and followed this guy Id like to know what you did so i dont make your mistake |
#5 | |
Anyways I just cranked my motor over by hand a bazillion times by hand and got the marks on the cam gears to line up with the links of the timing chain, motor is at tdc.. but it seems a little loose in one section.. is it still possible there is a skipped tooth in there somewhere? I'm totally lost, I primed the lifters, measured the shims over and over, everything seems perfect. I really feel like something is messed up here and I'm just missing it.. ![]() |
#9 |
![]() Join Date: Sep 2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 3 reviews
What valve spring and camshaft lift were you running? They broke like you may have had high lift cams. Not like they were shimmed wrong, but anything is possible. Valve springs too strong? Just do it again, a lil different this time, because that would be the definition of insane!
Sent from a Highly Tuned SIII using Tapatalk HD
#10 | |
![]() ![]() Anybody see anything odd? To be honest the lobes on cylinder 1 don't look like theyre facing outwards perfectly, one looks tilted SLIGHTLY upwards. I don't know if its just the angle I'm looking at it from or what though FML ![]() |
#13 |
![]() Join Date: Dec 2004
Trader Rating: (58)
If he had the tensioner out you'll get slack like that if you spin the cams backward.
The exhaust side cam is installed correctly, you can tell by the dowell location and the links to the side of the head. This would lead me to believe the intake cam is ok as there are 20 barrels between marks. The cam lobes you see are on Hole 2
#14 |
![]() Join Date: Jul 2005
That doesnt look like 10 and 12, but it could just be the picture or slack in the chain. But seriously, when you are TDC normally you get a 10 and 12 position. Almost looks like the chain is off 1 link on both cams.
That shouldnt break rockers, though. guides to the left, shims to the right? verify the TDC vs camshafts by setting the crankshaft to Top Dead center (pictured) and inspecting the CYLINDER #1 camshaft lobes themselves. They should BOTH be pointing OUTWARDS, if not slightly upwards. Outwards means nearly exactly 180* away from each other (its more like 174* apart). they should be symmetrical. If one is slightly up and the other slightly down... not good. |
#15 |
Is your tensioner installed in that pic? If it is, the chain shouldn't be slack like that.
Any pics of cam direction? Did you push down on the top of the lifters with the rocker arms installed to see if they were spongy or hard? If they are spongy, they are not bled properly. I am thinking there had to be some sort of strike on the cylinder head to cause a problem like that.
