Old 09-21-2012, 04:56 PM   #1
AlexiS13
AlexiS13 is an unknown quantity at this point
Stripped Oil Pan Plug. Help.
Bought a S13, went to change the oil and the plug is stripped(keeps spinning, will get slightly tight before it loosens again, so i keep it at the slightly tight).
Seen a few fix-it things but of course each site/video advises "this is the BEST solution" and "don't do the other things".
Not sure if any of you have had this and solved it with this but wondered how it holds up QuickOilDrainValve.com
I am really not even sure if that will help or not.
Should I, if this is even an option, re-thread the pan a size bigger and just go with a bigger bolt?
Also saw about some rubber plug that you put in, and tight the top so it widens it to plug(poor explanation).
Oil-Tite Oil Drain Plug by Dorman
If there is a better solution, I am all ears!
Have a nice day!
AlexiS13 is offline   Reply With Quote
Old 09-21-2012, 05:20 PM   #2
s14j
s14j's Avatar
Trader Rating: (72)
s14j is an unknown quantity at this point
Feedback Score: 72 reviews
for what motor? just change the pan its not that hard. or expencive.
95 s14 ka DD
s14j is offline   Reply With Quote
Old 09-21-2012, 05:29 PM   #3
AlexiS13
Oops, forgot to mention.
Aluminum Greddy pan
Have a nice day!
Old 09-21-2012, 05:39 PM   #4
future
future's Avatar
Trader Rating: (42)
future has much to be proud offuture has much to be proud offuture has much to be proud offuture has much to be proud offuture has much to be proud offuture has much to be proud offuture has much to be proud offuture has much to be proud offuture has much to be proud offuture has much to be proud offuture has much to be proud of
Feedback Score: 42 reviews
Buy a new one
Old 09-21-2012, 05:52 PM   #5
mack97
mack97 is an unknown quantity at this point
just do this
mack97 is offline   Reply With Quote
Old 09-21-2012, 06:13 PM   #6
dms2
Banned from the Marketplace
dms2 is an unknown quantity at this point
Send a message via Yahoo to dms2
How to Repair A Stripped Out Aluminum Oil Pan - EricTheCarGuy - YouTube
dms2 is offline   Reply With Quote
Old 09-21-2012, 06:36 PM   #7
AlexiS13
Yeah, saw the ericthecarguy one, wasn't sure if that was a good way to go about it or not. You tried it by any chance?
Have a nice day!
Old 09-21-2012, 06:40 PM   #8
s14j
s14j's Avatar
Trader Rating: (72)
aluminum is very simple to re-thread. you can use the thread insert way as well, iv used it they work well.
95 s14 ka DD
Old 09-21-2012, 09:24 PM   #9
Hardie
Hardie's Avatar
Hardie is an unknown quantity at this point
Drill it out and re-tap thread, easiest/cheapest way.
Hardie is offline   Reply With Quote
Old 09-21-2012, 09:26 PM   #10
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
godrifttoday is an unknown quantity at this point
Feedback Score: 82 reviews
if u have access to a welder, buy a nut weld it to the tip... and u good to go
NEED Bolt kits for your car?
http://i48.tinypic.com/6gx5e0.jpg
godrifttoday is offline   Reply With Quote
Old 09-24-2012, 07:13 PM   #11
kennedy8383
kennedy8383's Avatar
kennedy8383 is an unknown quantity at this point
Do it right first time and get a new oil pan.. Don't follow ERIC.. Short cut can be very dangerous to you and your car..
kennedy8383 is offline   Reply With Quote
