Old 09-07-2012, 06:31 PM   #1
SilviaT
SilviaT is an unknown quantity at this point
SR Pilot bushing issue sr20det
So Im having a issue installing my input shaft into the flywheel on my freshly rebuilt sr20det with a new spec stage 2 clutch kit. So I got my engine into the bay all nicely but it just isn't popping into place.. Anybody else having this issue? Or advice? Should I shave off a little bit of the pilot bushing because it's a HELL of a tight fit! After that it should be a piece of cake.
SilviaT is offline   Reply With Quote
Old 09-07-2012, 06:51 PM   #2
chetos13
chetos13's Avatar
chetos13 is an unknown quantity at this point
Send a message via Yahoo to chetos13
U might have damage the pilot bearing when u installed it that's why the input shaft won't slide in remove it and buy another there only a couple bucks
TEAM ELITE
chetos13 is offline   Reply With Quote
Old 09-07-2012, 07:16 PM   #3
SLiDe_WaYz
SLiDe_WaYz's Avatar
SLiDe_WaYz is an unknown quantity at this point
Check the teeth on the actual clutch disk. I had that issue with the spec clutch I was using.
SLiDe_WaYz is offline   Reply With Quote
Old 09-07-2012, 10:00 PM   #4
SilviaT
Ill pull the pilot bushing out tomorrow and check it out hopefully its fine. if not ill buy a new one.
And what did you do about it?.. Thanks guys!
Old 09-07-2012, 10:07 PM   #5
SLiDe_WaYz
SLiDe_WaYz's Avatar
Bought a file and filed down the teeth
Old 09-07-2012, 10:29 PM   #6
SilviaT
Haha i have files and alot of other useful tools. I'm just having a problem popping the drive shaft into the engine. Seems like the pilot bushing is stopping it or something. Its just not going together like it should! I'm probably an inch away from the bellhousing connecting to the block but its (like i said before) not popping into place and fitting! Ughhhhh. I have the engine on the hoist just waiting for the 2 to connect but i'm having a terrible time..
Old 09-07-2012, 10:35 PM   #7
Sauce98
Sauce98 is an unknown quantity at this point
I had that problem when I installed my 5 speed trans. Getting the input shaft in can be a little bastard. make sure you set the pilot bushing as far back as its supposed to be and push like a man. It should be easier if you have it on a hoist like you say. I did this from under the car and it took forever.
Sauce98 is offline   Reply With Quote
Old 09-08-2012, 10:47 PM   #8
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
If the pilot bearing is all the way in, and it wont slide in, it could be the TOB/carrier being too think. Did you change the clutch too?
CLICK HERE!!!
Old 09-09-2012, 01:13 AM   #9
SilviaT
Yeah i bought a SPEC stage 2 clutch kit. I installed that onto the engine, now i'm trying to connect the engine to the tranny but it just isnt connecting like it should.. Maybe i just need to force it more im not sure. But its irritating. The clutch allignement tool barely fits at all. I have to tap it in with a hammer to have it fully inserted......
Old 09-09-2012, 08:00 AM   #10
fliprayzin240sx
Get a deep socket and see if you can push the pilot bearing in some more. Stick your finger in there and feel how close it is to hitting the back.
CLICK HERE!!!
Old 09-10-2012, 10:16 PM   #11
SilviaT
GOT IT! Filed down the pilot bushing a hair and it actually went together after i fxcked around with it for a while. Finally! No all i gotttta do is plug and play! Thanks guys i really appreciate it!
