Old 08-18-2012, 07:36 AM   #1
chucky norris
chucky norris's Avatar
chucky norris is an unknown quantity at this point
Send a message via AIM to chucky norris
S13 coupe brake light problem.......its not the pedal
Ok guys so here is the problem when I have my lights on I noticed I have my dtivers side brake light is dimer than my passeger brake light. When I step on the brake my driver side completely shuts off and will slowly get some what light in there
Thank you for.reading
"If you're not first ..... you're last"
Ricky Bobby
chucky norris is offline   Reply With Quote
Old 08-18-2012, 11:10 AM   #2
moco
moco is an unknown quantity at this point
Have you tried getting new light bulbs?
moco is offline   Reply With Quote
Old 08-18-2012, 11:18 AM   #3
d0pe240
d0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of light
^above and check for corrosion in the sockets.
d0pe240 is offline   Reply With Quote
Old 08-18-2012, 12:44 PM   #4
Nissan206
Nissan206's Avatar
Nissan206 is an unknown quantity at this point
Similar thing happens to me with my coupe. When my lights are on, the driver side rear brake lights go completely out when I step on the brakes, but when I let off the brakes they stay on. They work perfectly fine when my lights are off, it's ONLY when the lights are on they start doing that. I've checked the bulbs, even changed them with the other side just to make sure, sockets, fuses, and the wiring on the housing and everything looks fine. Maybe a short somewhere or a bad relay? If anyone has any info please help chucky norris and I. Will be greatly appreciated!
Nissan206 is offline   Reply With Quote
Old 08-18-2012, 12:50 PM   #5
h2v7
h2v7 is an unknown quantity at this point
pop those rear bulb holders off unscrew all ground and scrub them good as they get corroded and should fix er up
h2v7 is offline   Reply With Quote
Old 08-18-2012, 01:34 PM   #6
sidewayzsilvia
sidewayzsilvia's Avatar
sidewayzsilvia is an unknown quantity at this point
what h2v7 said, this is what i did to fix the same problem
sidewayzsilvia is offline   Reply With Quote
Old 08-18-2012, 06:41 PM   #7
chucky norris
thaks guys for your help
i finally fixed it and it was just bad connection on one of them
Ricky Bobby
