Old 07-12-2012, 02:26 AM   #1
FutureFab
Trader Rating: (32)
FutureFab is an unknown quantity at this point
Feedback Score: 32 reviews
Rb parts galore!
Everything Rb related has sold!
Apexi Powerfc D-jetro ecu setup. Brand new in box!!!
Fits R32 and R33 Gtr rb26dett.
Comes with Ecu, hand controller, Map harness, and 2 New Gm 3 bar map sensors with pigtails.
Get rid of those pesky mafs and restrictive intake plumbing.
Sold
Various rb parts.
Rb20/25/26 stainless exhaust manifold. T3 divided, dual tial 44mm waste gate ports, Black ceramic coated. Un used. sold
Freddy polished intake manifold with q45 throttle body and Iacv. Has -6 male An fittings welded on above coolant ports for bleeders. Sold
Chromoly flywheel for rb25. light weight. Sold
Neo head. Cam journals have small gouges in it. Maybe good for builder or if you want to cut up to see how thick walls are for porting on good head. Sold
rb25 crank pulley nice condition. Sold
rb25 custom aluminum fuel rail. Dual -6 inlets on either end, center -6 return. Anodized black for e85 use. Sold
rb25 metal timing covers. Sold
Malory build your own plug wires. black. 75 plus shipping
rb25 engine wire harness. 100 plus shipping.
Garrett custom intercooler. Custom made for large turbo setup on s13. Uses 1/8th inch aluminum for end tanks, all tig welded with massive beads. 3 inch inlet, 3.5 inch outlet for Q45 throttle body. Fits s13 with silvia front, just barely have to trim tabs on bottom of silvia lights. Bolts up to lower tension rod bracket holes. Unused condition.
Core measures 24" wide, 12" tall, 3.5" thick.
Garrett rates this core at 925 Hp.
450.
Un
Just picked up a Rb25det Neo 6, letting go of some parts not needed.
R34 Rb25det Neo 6 Stegga Ecu. Has no traction control like Gtt ecu. No traction control codes to pop up and put you in limp mode. 100
R34 Rb25det Neo 6 Engine wire harness. Uncut at firewall. Need this to run Neo ecu as plug is different than R33 25det's. Some small 2 wire connectors broken/missing, but didnt seem to go to engine. 100
The one missing plug that didnt connect to engine anywhere, 2 wires.
R34 Neo 6 turbo. Bolt on upgrade for rb20 and rb25 s1/s2 engines. OP6 turbine housing, larger than other 25det housings. No oil in housings, spins free, normal small amount of shaft play. Sold.
R34 Neo 6 Ac compressor and bracket to block. Has tensioner and ac fittings to get lines made if need be. Sold
Rb25 neo 6 fuel rail and injectors. Sold
R33 Rb26dett Gtr Crank. Long snout oil drive. Very clean journals. Sold
[IMG]http://i1083.photobucket.com/albums/j398/2weldit/Snapbucket/E63922C8-orig.jpg[/IMG
R34 rb25 neo coil packs. Ignitor built in. Sold
R33 rb25det bare block. Small vertical scratches in cyl 5 and 6. Perfect for 86.5mm bore or 87mm.
Sold.
Tomei Rb26 headgasket. 87mm bore, 1.2 mm thick. New un used. Has some plastic from bag stuck on it but cleans off with thumb nail. 180.
Sr20det valve stem seals
New in bag, both sides. 25
Z32 maf, sold
Rb25det S2 maf 25
Rb25det ecu MEC-R722, 75
Rb25det MINES ecu. MEC-R630, 150 bux
Q45 throttle body 40
Turbonetics T3. 61mm compressor wheel, stage 5 exhaust wheel, to4e compressor cover with aluminum back plate thats anodized blue. Nice and tight, spins free. 380
Rb25 S1 cam sensor, mitsubishi, working order, 70
Rb25 oil drain tube, Sold.
Generic oil filter relocation castings. One for block, one for filter, has -10an fittings. Used condition. 25
Rb25 S1 stamped steel oil pan, 45
Rb25 S1 timing belt covers, steel, Sold
Rb20 top feed fuel rail, 20
Rb25 neo Upper and lower intake manifold with throttle body, 80
Rb25 s1 crank pulley, no chips. 50
Rb25 neo stock water pump, 25
Rb25 S1 alternator, working, just missing little plastic insulator where power output 12mm is. Use your old one here. Sold
Rb25 s1 water pump pulley, 10
Rb26 rear main seal housing. 20
Rb25 neo cross over Ic pipe (goes above motor just before throttle body) with stock Bov. 25
All prices before shipping and paypal fee.
futurefabrication.com
FutureFab is offline   Reply With Quote
Old 07-12-2012, 08:28 PM   #2
FutureFab
Trader Rating: (32)
Bumpity bump up
Old 07-16-2012, 05:17 PM   #3
FutureFab
Trader Rating: (32)
Added parts and lowered prices. Willing to bundle items and lower prices further.
Old 07-16-2012, 11:05 PM   #4
Frostedbutts
Frostedbutts is an unknown quantity at this point
bump for a good dude, bought something off him and he shipped it quick for a pretty reasonable price.
Frostedbutts is offline   Reply With Quote
Old 07-16-2012, 11:29 PM   #5
karl wasabi
karl wasabi's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
Pictures of the turbo? Is it bigger than a stock 25 turbo?
karl wasabi is offline   Reply With Quote
Old 07-16-2012, 11:41 PM   #6
Vicious Beaner!
Vicious Beaner!'s Avatar
Trader Rating: (38)
Vicious Beaner! is an unknown quantity at this point
Feedback Score: 38 reviews
^^ what he said
Vicious Beaner! is offline   Reply With Quote
Old 07-17-2012, 02:30 AM   #7
FutureFab
Trader Rating: (32)
Pics added for you guys. Yes the turbine housing is larger on this turbo than previous 25det's.
Old 07-17-2012, 09:07 PM   #8
Vicious Beaner!
Trader Rating: (38)
Clean Neo btw bro. Glws
Old 07-18-2012, 09:08 AM   #9
Drifter_85
Drifter_85 is an unknown quantity at this point
Does this crank already have the longer oil pump drive? some people tell me the r33 had this problem fixed and others are telling me that only the r34 had it fixed. Post pic of oil drive please
Drifter_85 is offline   Reply With Quote
Old 07-18-2012, 09:29 AM   #10
vw203
vw203's Avatar
vw203 is an unknown quantity at this point
Send a message via AIM to vw203
r33 is long drive. I may be interested in crank as well waiting to hear word from my machine shop to see if mines any good
スカイライン
vw203 is offline   Reply With Quote
Old 07-18-2012, 11:05 AM   #11
tuquik
tuquik's Avatar
tuquik is on a distinguished road
Send a message via AIM to tuquik
How much to ship the a/c compressor stuff to 73099
tuquik is offline   Reply With Quote
Old 07-18-2012, 02:17 PM   #12
FutureFab
Trader Rating: (32)
This is the long drive r33 crank.
Tuquik, it would be 80 total with shipping and paypal for ac setup.
Old 07-22-2012, 04:02 PM   #13
tuquik
tuquik's Avatar
PM me your paypal info.
Old 07-23-2012, 06:42 PM   #14
FutureFab
Trader Rating: (32)
Way more parts added with pics too.
Old 07-23-2012, 11:14 PM   #15
RB26DevilZ
RB26DevilZ is an unknown quantity at this point
how much for the rb26 rear main seal housing shipped to 93960!
Does it still have the rear main seal installed?
RB26DevilZ is offline   Reply With Quote
Old 07-24-2012, 04:19 PM   #16
FutureFab
Trader Rating: (32)
Yes it has a seal in the housing.
26 shipped and paypaled
Old 07-25-2012, 09:10 PM   #17
GT240R
GT240R is making his/her stupidity well-knownGT240R is making his/her stupidity well-knownGT240R is making his/her stupidity well-knownGT240R is making his/her stupidity well-knownGT240R is making his/her stupidity well-known
Timing belt covers and oil tube sold to me.
GT240R is offline   Reply With Quote
Old 07-26-2012, 12:08 AM   #18
gearhead55
gearhead55's Avatar
hey do you still have the RB25 dipstick?
gearhead55 is offline   Reply With Quote
Old 07-26-2012, 12:36 AM   #19
FutureFab
Trader Rating: (32)
No its gone. I have a differant one that was cut and marked the same as rb25 tho.
Old 07-26-2012, 06:51 PM   #20
FutureFab
Trader Rating: (32)
More parts shipped today.
Old 07-26-2012, 06:55 PM   #21
gearhead55
gearhead55's Avatar
same length and o-ring and everything? could you snap a picture for me?
Old 07-27-2012, 07:41 PM   #22
FutureFab
Trader Rating: (32)
Its a little differant, but still works the same.
Old 07-28-2012, 06:03 PM   #23
Kayle850
In time-out for misbehaving.
Kayle850 is an unknown quantity at this point
Bumpin for a good sale
Kayle850 is offline   Reply With Quote
Old 07-30-2012, 06:35 PM   #24
FutureFab
Trader Rating: (32)
Must clear out space.
Take 10% off listed price. Still requires shipping, but the 10% helps offset shipping.
Old 08-02-2012, 08:02 PM   #25
FutureFab
Trader Rating: (32)
What you need?
Old 08-04-2012, 11:44 PM   #26
M-A-T-T
M-A-T-T's Avatar
M-A-T-T is an unknown quantity at this point
Bump. Glws
M-A-T-T is offline   Reply With Quote
Old 08-19-2012, 11:49 AM   #27
KingoftheStreets
KingoftheStreets is an unknown quantity at this point
Willing to part the shifter with alignment pins? PM me
KingoftheStreets is offline   Reply With Quote
Old 08-19-2012, 01:00 PM   #28
FutureFab
Trader Rating: (32)
Thanks for intetest but not at this time. Its hard enough to sell a good complete transmission for 300 less than others as it is.
Old 09-03-2012, 02:01 PM   #29
Michaelwinne
Michaelwinne's Avatar
Michaelwinne is an unknown quantity at this point
Bump for a legit seller!
Michaelwinne is offline   Reply With Quote
Old 09-17-2012, 11:41 PM   #30
FutureFab
Trader Rating: (32)
Nice Garrett intercooler added.
