![]() Join Date: Nov 2009
Trader Rating: (42)
![]() Feedback Score: 42 reviews
that's a terribly designed manifold, grinding down the master cylinder is a bad idea for one. for two, you will overheat your fluid, go to stop, wreck and possibly die seeing how it will be resting on it....you can't even fit a heat shield there, i would see about getting another manifold (looks like a cheap one anyways)
SW Fab |
#7 | |
![]() Join Date: Nov 2011
![]() ![]() ![]() Feedback Score: 3 reviews
buy a new master
either reweld the flange or get new manifold
#10 |
Yessirr JGS manifold will solve your problem... Also invest in a pre bent heat shield to keep the BMC from failing....
Boost makes me sooooooo happy! |
#12 |
![]() Join Date: Oct 2011
![]() Feedback Score: 15 reviews
The JGS is kinda expensive for me right now. I'm just starting school so I don't have much money to buy a manifold like that at this moment. I was thinking of picking up the cx racing stainless steel top mount. Anyone have one of those?
#13 |
Trader Rating: (42)
the problem with the chinese manifolds is the flanges are usually off/not straight, causing leaks and lots of blown out gaskets. they're also thin/shitty metal and can crack/break. if you're on a budget, look into the mazworx diy log manifold. i can weld it for you, pm me if you're interested.
http://www.mazworx.com/product/fabri...-kit-log-style
SW Fab |
#14 |
![]() Join Date: Jun 2010
ya or get a cheaper manifold and have someone weld braces on it to prevent cracking or save up a lil and get a nicer manifold or get the one cut and rewelded
ka24de, ka24det, turbo |
