Old 01-24-2012, 08:44 PM   #1
SMM
Trader Rating: (26)
SMM is an unknown quantity at this point
Feedback Score: 26 reviews
KA24DE Torque specs (searched)
Ok I have searched and searched. All I am getting is mixed answers, I also looked in the FSM.
Some people are saying they stripped the cam sprockets bolts when torquing to factory specs or have even broken cams.
This is what I have come up with.
Cam Cap Bolts:
Tighten: 1.4 (FOOT LBS) in sequence then to 8.7 (FOOT LBS)
Cam Sprocket Bolts:
123-130 ......really thinking only to do 90 ( FOOT LBS )
Idler Sprocket Bolt:
40-60 FOOT LBS
Others:
Crank Pulley 150 FOOT LBS
Chain Guides 17 FOOT LBS
Chain Tensioners 7 FOOT LBS
SMM is offline   Reply With Quote
Old 01-25-2012, 11:22 AM   #2
Promise Land
Promise Land's Avatar
Promise Land is an unknown quantity at this point
I think the Jim Wolf instructions for changing the cams also mirror the FSM specs.
Promise Land is offline   Reply With Quote
Old 01-25-2012, 01:18 PM   #3
let5l1de
let5l1de's Avatar
Trader Rating: (30)
let5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfection
Feedback Score: 30 reviews
Send a message via AIM to let5l1de Send a message via Yahoo to let5l1de
Stripped cam bolts and breakage?
Just use the fsm. You will be fine... Also, use the correct metric 6pt socket with cam properly locked or secure in place.
~mario
GR Performance
**GR Performance facebook** Pics & More! Comments! http://www.facebook.com/pages/GR-Performance/120477531339202
Read My Sales Review
626 Friday Nights San Gabriel
let5l1de is offline   Reply With Quote
Old 01-25-2012, 04:31 PM   #4
SMM
Trader Rating: (26)
^ Ya guys over on KA-T some of them torqued them to factory specs and they broke.
Old 01-26-2012, 04:37 AM   #5
Tantwoforty
Tantwoforty's Avatar
Tantwoforty is an unknown quantity at this point
I used the fsm, everything went fine.
Its from the factory, they made 1000's of them like that, why wouldn't it work?
For cam bolts i used a crescent wrench to hold it, put a towel under the wrench when it wedges against the head or it will make a small dent. it wont hurt anything, but it will bother you.
for the crank pully i used the flywheel bolt wrench trick.
Tantwoforty is offline   Reply With Quote
Old 01-26-2012, 01:27 PM   #6
SMM
Trader Rating: (26)
PER FSM:
Cam Cap Bolts:
1.Tighten to 17 INCH LBS first in sequence.
2. Tighten 80-104 INCH LBS
Cam Sprocket Bolts:
123-130 FOOT LBS
Idler Sprocket:
48-61 FOOT LBS
Crank Pulley:
105-112 FOOT LBS
Timing chain tensioners TOP & BOTTOM:
56-66 INCH LBS
Lower timing chain guides:
9-14 INCH LBS
Old 01-26-2012, 07:12 PM   #7
Tantwoforty
Yeah that sounds right..
I was trippin on the cam cap numbers but then i realized inch lbs
Old 01-27-2012, 11:21 AM   #8
let5l1de
let5l1de's Avatar
Trader Rating: (30)
Cam Sprockets:
Camshafts do break for many reasons. Typically, cracks may occur around the outside of the cam gear ridge.
Cams are usually a victim of some sort of abuse from heat, poor lubrication, misuse or severe internal problems prior to cracking.
I have never stripped the threads of a camshaft.
Idler sprockets:
Extreme care with proper thread engagement, lubrication and torque must be used when installing this piece.
~m
grp
Old 03-19-2012, 01:01 PM   #9
Mr. KA
Mr. KA is an unknown quantity at this point
First post, but I just wanted to chip in that I stripped the idler gear bolt with 50 ft/lbs (needing a helicoil) and the same went for the cam gears at 85 ft/lbs.
My motor was used and severely abused, but not turbo.
Mr. KA is offline   Reply With Quote
Old 03-20-2012, 06:28 AM   #10
JDMRIDDAZ
JDMRIDDAZ's Avatar
JDMRIDDAZ is an unknown quantity at this point
On cam caps u don't need the tourqe specs cause it 11inch pounds
I use 1/4 ratchet witg no issue in 10yrs
And I use the oldskool tourqe wrench..
Less likely to strip cause u use tru force and watch a needle
Not a new clicking type..u can strip shit out easy
That's why I switched back to oldskool
シチサn w/ka20det:in progress
シチサnw/sr20det:stolen
JDMRIDDAZ is offline   Reply With Quote
