Old 10-10-2011, 09:00 PM   #1
F1tuner
F1tuner is an unknown quantity at this point
very clean black 1997 s14 with stock s13 sr20det setup
SOLD SOLD SOLD
only trades would consider is for a AP1 S2000
for serious inquires my cell phone is 732 762 3203
car is located nearby englishtown, NJ 08857
Chassis:
1997 240sx se
93931 miles on chassis
approx 6000 miles on motor
no rust
stock body was repainted oem black in 2007
with oem front kouki lower lip spoiler
6000k HIDs
Motor:
Stock S13 SR20DET with fully functional A/C conversion
fresh stock rebuild with all new oem components prior to motor swap
new oem piston rings, main bearings, rod bearings, thrust washers, and timing chain components, gaskets, and seals
engine block honed and cleaned
cylinder head surfaced and valve seals replaced
Red Wrinkle powdercoated valve cover
ARP headstuds
Cometic Headgasket
Apexi Intake
HKS wastegate actuator set to approx 10psi
Isis Front Mount Intercooler with
Isis Hotpipe with HKS bov
Brand new Wiring Specialties.com Wiring Harness
Koyo N Flow Radiator
DIF Fan Controller
Flex a lite dual fans
Greddy Oil Catch Can
BRM catback exhaust
RS Enthalpy flashed ecu for stock t25 turbo
AEM wideband gauges, VDO boost, and VDO water temp gauges
Drivetrain:
Gram Light 57 Maximum Gunmetal 17x9 et22 245/40/17 Dunlop Direzzas Star Specs with 80% treadlife
Kaaz 2 way LSD with 4.6 ring and pinion (8000mi) and Greddy Diff Cover
KTS coilovers
Tein front and rear strut bars
SPL tension rods with brake cooling deflectors
Suspension Techniques front and rear swaybars
Powered By Max rear Camber arms
Powered By Max rear Toe arms
South Bend Clutch Stage 3
Fidenza Lightweight Flywheel
StopTech Big Brake update ST-40
with Porterfield R-4 brakepads
Cons: will need a new stock t25 turbo due to oil seals have started to leak and exhaust smokes alittle at idle.
I've owned this car since 2006 and been built to perform flawlessly at autox and HPDE track days, and have been drifted occasionally.
This car is an ideal candidate for anyone looking to go big turbo upgrade on a very clean chassis and freshly rebuilt stock block.
F1tuner is offline   Reply With Quote
Old 10-11-2011, 12:23 AM   #2
okiwan
okiwan is an unknown quantity at this point
nice kouki.
okiwan is offline   Reply With Quote
Old 10-11-2011, 09:36 AM   #3
GoOn3
GoOn3 is an unknown quantity at this point
Turbo s2000
Hey man,
Beautiful 240 you have! Ive got a turbo 2003 s2000 which i saw you were interested in a possible s2k trade.
Check this link about half way down the page. There is a description of parts and a few pictures. Car has 400whp and is a blast to drive. Let me know if you would be interested.
Thanks
How much power does you car put down? How much boost were you running?
Any issues with the car at all? Rust?
Thanks again
http://zilvia.net/f/cars-sale/399948...ual-trade.html
GoOn3 is offline   Reply With Quote
