![]() Join Date: Jul 2007
Trader Rating: (36)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 36 reviews
S13/S14/SR/KA All Kinds of parts, mostly OEM, some AM...
UPDATED 12/8/11
Here is a list I put together with alot of S14-S13 and SR20 Parts! Im sure I missed alot of things, so please PM me if you dont see it in the list. Pics can be found in my Photobucket: stuff for sale pictures by brsilvia - Photobucket If you cant find an item your looking for, Please PM me and I will get you a pic ASAP! 240SX Parts list S14 Zenki Front Bumper Mounting Retainer - $25 S14 Tail lights 3pc Zenki (reverse clear part in center has slight aging cracks, not broke) - $40 S14 Third Brake Light (in trunk, no cracks, nice) - $20 S14 Window/Door Pillar Trims (Rubbers & metal w/black peices that screw into chassis, clean) $10 S14 Passenger Fender (maroon, only rust is where it bolts to rocker, not visible when on car) - $20 S14 Electric Fan x2 - $20 S14 Clutch Fan, Blade Only - $15 S14 Passenger Door Panel black/grey insert - $20 S14 Rear Seat Belts black (no buckles) - $20 S14 Door Handles (Black, Interior Levers, not pockets) -$10 S14 Rear InteriorTrim (black, 1/4 sides upper and lower) - $15 pc S14 Trunk Trim (peice sits over trunk latch very rear, w/all push clips) - $10 S14 Behind Rear seats trim black x2 - $10 S14 Glove Box x2 black - $15 S14 Cluster Gauge Trim black - $15 S14 Lower Column Trim black - $10 S14 Kick Panels black sold, have a blue pair - $10 pair S14 Misc Rubber Seals, door jams, trunk, ect. - $5-$10 depending which seal S14 Dash vents, side, top corners, inside tubes, ect - $5 each S14 Rear Seat Swivel Brackets - $10 S14 Sunroof Control/Map light x2 - $10 S14 Sunroof Motor - $20 S14 Sunroof Mounting Hardware - $10 S14 OEM Amplifier under rear deck x2 - $20 S14 Computer (model 3D) - $20 S14 P/S Resivoir x2 - $5 S14 Radiator Brackets, Upper(no rubber insert) and Lower - $10 set S14 Hood Latch Cable x2 - $10 S14 Cowl Panel x2 - $10 S14 Jack & Tools - $20 S14 Heater Core Cable - $5 S14 Wiper Motor - $25 S14 Washer Fluid Motor(side of resivoir) - $5 S14 Nissan OEM Fuel Cap - $5 S14 Seat Rail Caps - $10 set S14 Door Striker Latch - $5 S14 RH Hood Hinge - $5 KA Pilot Bearings x5 - $5 KA Clutch Bolts x2 sets - $5 set KA MT Flywheel Bolts - $10 set KA AT Flywheel Bolts x2 sets - $10 set S13 Door Sills black - $20 S13 Driver Kick Panel black - $10 S13 SOHC Computer model 10 - $20 Tons of SR S13 Engine Parts from a Full Build Part Out! MONSTER TURBO KIT for fraction price! S13 SR20DET : Block: 90% Bare, bored .020 over, still has oil squirters in tact, all main caps, girdles, ect are there also, all other parts listed below. -$850 OBO Short Block with Pistons & Rods, $300 OBO Empty Block INTERNALS: -OEM rocker arms -$80 obo -Adjustable Cam Gears-blue-70 miles -$40 OEM PARTS: -OEM Dip Stick and Tube - $20 -OEM Valve Stem Seals - $20 -OEM flywheel bolts - $20 -OEM rear main seal and housing - $20 -Water lines on side of block x2 -$30 -Alternator & Bracket - Alt SOLD, bracket $30 -Engine Mount Brackets x2 - $40 pair -Water Necks/ Thermo Housing (2 pairs,1 polished,1 black powdercoat)- $20 each -Coil Packs & Harness - $100 -O2 Sensors, skinny type - $20 -Oil Squirters/Cams - $40 -CAS/with Polished Cover - $100 -Enjuku Racing Stainless CAS Cover -$40 obo -Crank Pulley - $50 -AICV - $60 -Brackets(Intake, Engine Mounts, ect) - $-- -OEM Cam Gears - $30 -Main Girdle w/baffle plate/bolts - $40 -Baffle Plate(the one oil pickup runs through) - $10 -Oil Squirters for Pistons(bottom of block)x3 - $10 ea -Bearing main caps - $-- OTHER PARTS: -FULL RACE front mount intercooler core with piping -$650 obo -S13 SR to S14 Chassis Harness - $250( very nice harness with a diff fuel inj plugs and Z32 mafs plug(can be swapped easily), I have spare harnesses to put both back to stock) -Custom 3 Core Aluminum Radiator -$500 OBO Package deal (will include samco hoses if asking price is met) -Electric Fan with Custom Aluminum Housing to match Radiator(Radiator/Fan/Shroud combo one off original!) -Samco Silicone Radiator Hose Kit -$80 OBO -80mm Race Cat -Invidia 3" Cat back Exhaust -Tranny Sandwich plate - $30 -Transmission -$250 -B & M Short Throw Shift Kit -$150 -Blitz Power Meter-id -$150 -Blitz Boost Controll SBC-id $450 ---These 2 units work with each other, combo package $500!!! -Blitz FATT DC111 Turbo Timer -$75 HERE IS A LINK TO MOST OF THESE PARTS: http://s109.photobucket.com/albums/n...%20Part%20Out/ http://s109.photobucket.com/albums/n...%20for%20sale/
Last edited by SoloSilvia; 01-01-2012 at 09:37 AM.. Reason: Lots of new stuff added and sold items deleted! |
#5 |
![]() Join Date: Dec 2005
Please let me know if you have the KA hose that goes from the front of the valve cover to the intake, just before the TB.
Ahh shit, kinda old. |
#6 |
Trader Rating: (36)
Scrapped a whole lot of stuff and threw away even more. I deleted alot already and will be adding and deleting more in an update list soon. Including a full Built SR part-out! So Please keep the PM's coming!
#20 |
Trader Rating: (36)
Sorry it took so long for a reply, I just moved and have been without internet the past few weeks.
Thanks, Brian 330-432-4871 TEXT for faster response!
