08-17-2011, 11:20 PM | #1 |
S-Chassis Dual Caliper Kit!!! NEW!
NEW and improved! TRUE BOLT ON S-Chassis Dual Caliper e-brake Kit!!! NEW lower price!!! $250 shipped!!!!!! Introducing a BOLT ON solution for dual calipers for the Nissan S-Chassis. Work with steel and aluminum uprights. So what exactly is it? This bracket allows you to use 2 pairs of Z32 rear calipers for AWESOME stopping power. One pair of calipers gets plumbed up like normal and works off of the brake pedal. The other pair gets plumbed SEPARATELY to the hydraulic handbrake. No more weird pedal feel when pulling the e-brake and the footbrake! You now have a dedicated setup for the hydraulic handbrake. What comes with the kit: - One left bracket - One right braket - 2 hub rings to align rotors correctly. - 8x M12 Class 10.9 Bolts for hub. - 8x M12 Split locking washers. - 8x M10 Class 10.9 Flange head bolts for calipers. - 8x M10 Stainless steel flat washers. Features: - Made in the USA by an Aerospace/Medical certified machine shop with ISO9001:2008 certs. - 6061-T6 aluminum for strength and low weight used on brackets and hub rings. - The brackets are CNC'd and not water jetted. CNC is much more precise and cleaner. - Hardened steel liners(Rc 62-64) - FEA tested as well as real world tested on track. - Huge 11.7" rotors on the rear. Need to know: - You will use REAR rotors from one of the following vehicles. Code:
FORD MUSTANG BULLITT 2001 FORD MUSTANG COBRA (1994 - 2004) FORD MUSTANG COBRA R 1995 FORD MUSTANG COBRA SVT 1995 FORD MUSTANG SVT COBRA R 2000 - Aluminum uprights(Z32, R32, etc) need to have a few places ground down. Quick work with a grinder. - This will space your wheels out 8mm. It's like adding an 8mm spacer to the wheels. Please keep this in mind if you have flush fitting wheel already. - We recommend using a 3/4" bore hydraulic handbrake. 5/8" will work as well. - Allows the proper use of a hydraulic handbrake. No more rigged inline setups that don't work when you need them to! Bolted together: From the back: On car: CAD Designed: Price/Contact: $250 USD Shipped to the US. $270 USD Shipped to Canada/Mexico $290 USD Shipped internationally. Please contact me before sending money for international orders. I will be offering a hydraulic handbrake setup soon. Please PM me on here, email me sil8ty(at)gmail.com or call me at 520/444/4415 Thank you, George
-George Marstanovic Sr to VQ transmission adapter, dual caliper brackets, high angle tensions rods, and more! http://www.maverick-motorsports.com/collections/all Last edited by maverickmotorsports; 04-12-2012 at 02:45 PM.. |
08-17-2011, 11:42 PM | #2 |
Hill Kill, please clear your inbox. I tried replying to PM and it was saying your inbox is full.
-George Marstanovic Sr to VQ transmission adapter, dual caliper brackets, high angle tensions rods, and more! http://www.maverick-motorsports.com/collections/all |
08-17-2011, 11:50 PM | #5 |
I thought about that but it would make the kit really expensive. Z32 calipers are affordable and easy to get as well as the rotors. Wilwood products are very nice but my intention with this kit was to make it affordable for the "drifter" budget.
08-18-2011, 12:25 AM | #6 | |
good idea . whats the eta on the hydraulic handbrake set up? |
08-18-2011, 10:37 AM | #8 |
wow, props on a great idea/product. I'd like to get a set but I'm not running Z32s. I have a set of front/rear brembos from the new nissan GTR... I know its a shot in the dark but what are the chances it would fit for that....I don't even know where or what to begin measuring.
08-18-2011, 10:45 AM | #9 | |||
08-18-2011, 10:58 AM | #10 |
any chance I can grab the specs needed to fit from you? I can measure the thickness and diameter easily myself. I do not know what the hat offset is but if you can spare a second to tell me I'm sure I can measure that too.
if the specs line up or are close enough that I can modify it slightly I will order a pair. In the past I have built my own setup for hydro ebrakes and its almost always a huge pain. if you ever build one for a mazda miata NA with willwoods I would totally buy that one too. |
08-18-2011, 11:39 AM | #12 |
Sorry about that buddy. It can't be done. The Z32's use thicker vented rotors and the 240's use skinny solid rotors. Unfortunately it won't bolt together.
08-18-2011, 12:45 PM | #14 | |
you can see behind the silver bolt head(only silver bolt pictured), that the oem brake caliper mounts have been hacked off and smoothed down. great products geroge, i have a bunch of your steering angle rack adpaters from zt, i dont have a drift car s14 anymore, hoping one of my buddies pick up a set of these so i can test fit it on my z33 drift cahhh'
duh mah! wheels and suspension! |
08-18-2011, 02:11 PM | #16 |
do you know if this will work with the driftworks rear hubs?
Driftworks GeoMaster - Race Hub Knuckles - Steering & Geometry - Suspension - Car Parts Driftworks Shop |
08-18-2011, 02:28 PM | #17 |
question. so this means I lose parking brakes? Or do they make a vacuum less hydrolic brake master that I can use for the hand brake that will keep the caliper locked when parked?
08-18-2011, 07:31 PM | #19 | |
you could probably just use a hydro e-brake that has a locking mechanism so you could still use one pair of calipers as parking brake |
08-18-2011, 07:55 PM | #20 |
I cant wait to see what you come up with the handbrake, also add the lines and sell as a kit. I would like to buy it all at once. Also is there anyway to make those hub rings out of steel or something? Im having doubts about a thin T6 hub ring. Everything else looks great!
08-18-2011, 08:43 PM | #22 | |
This is just to facilitate a "drift only" hydraulic method of locking up the rears.... Again, if i'm off base, correct me.... |
08-18-2011, 08:50 PM | #23 | |
08-18-2011, 08:55 PM | #24 | |||||||
Thanks again for all the business. I'm actually going to be testing this setup on a Z33 soon. It might just work! Quote:
I make batches at a time and when they sell out it can take up to a month to get more in. I will keep making these as long as people want to keep buying them. Quote:
08-18-2011, 09:25 PM | #26 |
I remember what I really asked you now lol. I was asking if you could make one with dual oem 240sx calipers so I could retain the stock ebrake and have a separate caliper for the hydro while still using the stock rotor.
08-18-2011, 11:31 PM | #27 | |
I got a $800 alarm/starter system that only starts my car if the hand brake is up and I'm in neutral, so I don't think I can run this and remote start my car without my car rolling away by itself.
08-19-2011, 01:57 AM | #28 | |
By the way, this dual rear caliper setup is pretty sweet. Waiting to see how your hydraulic lever setup turns out. Im definitely interested in this setup. |
08-19-2011, 10:32 AM | #30 | |||
Correct, these use the REAR rotors.
