![]() Join Date: Nov 2007
Trader Rating: (36)
![]() ![]() ![]() Feedback Score: 36 reviews
S14 Kouki complete part out thread. SR, KW, Cusco, Do Luck, SPL, SPC, Nagisa, etc.
S14 Kouki Sr20det - PENDING full swap (everything included below) turn key 350whp engine meticulously tuned / dyno proven
Perfect 150psi compression straight across. Supertech Single titanium springs HKS step 1 256 deg. intake camshaft HKS step 1 264 deg. exhaust camshaft Apexi 1.1mm head gasket New OEM water pump New OEM oil pan All gaskets / valve stem seals replaced N/A s14 sr throttle body Garrett .64 A/R 52 trim GT2871r Nismo pilot bushing Nismo 555cc injectors Converted s14 Harness Enthalpy Rom tune Exedy Stage 1 clutch Shortened stock shifter (retains stock throw) Greddy Suction kit z32 maf Codyace A/C conversion brackets / compressor S14 SR fan clutch / fan 5 speed transmission This engine doesn't miss a beat, doesn't burn a drop of oil, is as reliable as they come and will get 28mpg. Will consider parting out if I find buyers that want to split parts. SR/Ka samco lower radiator hose - $20 ![]() S14 Fuse box cover - SOLD S14 RLCA - $60 for the pair. ![]() JDM S14 silvia hood badge. (Add double stick tape and use!) - SOLD S14 Factory Floor mats No rips or holes/discontinued - SOLD S14 rubber shifter boot / retainer - $25 (2 available) S14 Kouki hood insulation with mounting clips - $10 ![]() S14 kouki hood weather stripping. (seals headlights, grill to hood) - SOLD S14 Kouki high and low pressure AC lines (Low pressure line purchased brand new from the dealer and is undamaged!!!) - $150 S14 power steering reservoir with BRAND NEW OEM Nissan rubber lines. (these were on the car for a whopping 3 weeks) - $40 S14 Hood prop - $10 S14 kouki windshield washer squirters - $10 ![]() S14 cross member, perfect shape - SOLD S14 kouki passenger fender with damaged tip - SOLD S14 kouki driver fender - SOLD Kouki Front Bumper Damaged front, good for drift missile or car without a bumper. - $50 ![]() S14 Dashboard defrost vent trim DISCONTINUED PART PURCHASED NEW - ZERO BROKEN CLIPS OR TABS ABSOLUTELY PERFECT SHAPE - SOLD Circuit sports 1 piece oval cobra downpipe - SOLD Project Nissan resonated test pipe - PENDING RSR Exmag 3 inch exhaust - PENDING KW Clubsport Coilovers with T3 (Techno Toy Tuning camber/caster plates not even 5k miles on them) - SOLD Nismo Motor and Tranny mounts. PURCHASED NEW, ONLY ON CAR FOR 4 MONTHS. - PENDING Denso Supra TT fuel pump - PENDING Cusco OS front and rear strut tower bars - SOLD Doluck Transmission Tunnel brace - SOLD Nagisa Auto Shakkito plates - SOLD Kenwood radio with conversion harness, radio brackets, and din pocket - $70 ![]() GT Spec fender braces - SOLD SPC full arm kit (ruca, traction control rods, toe links, tension rods) - SOLD SPL V5 outer tie rods / z32 inners - SOLD Nismo Power Brace - SOLD Kouki R33 Skyline GTR front seats - SOLD Kouki S14 Door panels SOLD MB A-Tech competition wheels 17X9 +27 offset 235 40 17 and 255 40 17 Nitto NT05 tires (less than 2k on front tires, less than 500 on rears) - SOLD S14 5 lug - $350 Forge motorsport BOV - PENDING S14 rear uprights with DEF spherical bushings - $300 ![]() ![]() S14 Six bolt axles excellent shape 80k miles NO RIPS - $100 ![]() S14 Mint un-cracked dashboard - SOLD S14 Mint radio trim - SOLD S14 Mint center console - SOLD S14 Mint A/C trim with all hazard, security, and defrost switch no broken clips!!!- SOLD S14 glovebox - $10 Kouki S14 driver and passenger window switches with door panel inserts PURCHASED NEW no broken tabs & led's in switch work too!- $180 ![]() ![]() ![]() ![]() ![]() S14 doors with glass / window motors, regulators - SOLD S14 Mint carpet - SOLD S14 Kouki rear seats $60 S14 No sunroof headliner - $30 S14 brand new oem nissan windshield - $100 Defi 60mm 1.2 bar boost gauge with defi link and pod fitted to steering cover - $200 ![]() Gizzmo MSIBC boost controller - SOLD S14 Complete DCC with all sensors - SOLD S14 Front seat belts - SOLD S14 rear quarter glass with rubber - $50 each S14 kouki side skirts - SOLD S14 KA 5 speed transmission - SOLD S14 Non ABS 5 speed driveshaft - $100 S15 Subframe with nismo bushings - PENDING S15 HLSD with 4.36 final drive in s13 pumpkin with s14 cover - SOLD S14 Clutch pedal - $60 Agency power stainless steel clutch line - SOLD Q45 Front brakes, rotors, lines with altima rear rotors, stock caliper z31 brackets ALL HAVE HAWK PADS!!!- $350 ![]() ![]() ![]() ![]() ![]() 15/16 BMC and 5 speed booster - $60 S14 Kouki wiper motor - $30 S14 Zenki wiper motor - $30 1998 S14 Kouki KA mint uncut wiring harness - $120 S15 Steering wheel - SOLD S14 Donut Spare - $20 ![]() S14 Gas Tank (No cracks, perfect shape just dusty) - $100 ![]() Cracked S14 Dash with airbag popped - Make offer ![]() S14 Kouki clock spring - $60 ![]() S14 Door handle plastic inserts (unbroken) - $20 ![]() S14 Gas Pedal with throttle cable - $30 S14 Hood release cable - $15 S14 Gas Pedal stopper - $5 S14 Trunk Release Cable - $20 S14 E-Brake Cables - $10 S14 Parking Brake boot - $10 S14 Parking Brake arm with boot - $20 S14 interior door handles - $20 ![]() S14 Ash Tray - $20 ![]() S14 Dead Pedal - $5 S14 Zenki Grill (96) - $40 S14 Kouki Grill (98) - $60 ![]() ![]() S14 Coolant overflow bottle - $15 ![]() S14 Nismo Radiator Cap - $10 ![]() ![]() S14 KA Blasted and painted intake manifold with fuel rail - $60 (All injector screws replaced with allen bolts for easy maintenance) ![]() S14 OEM Rain guards - $40 ![]() S14 Dome Light - $15 ![]() S14 Rear view mirror with plastic cap - $15 S14 Rear view mirror without plastic cap - $10 SR Ignitor Chip - $40 JDM Greddy Type S Bov - $200 (Perfect working order) ![]() ![]() SR P/S Pump - $40 ![]() S14 SR Water pump - $30 ![]() ![]() SR Water pump pulley - $5 S14 OEM Sun Shade (Perfect fit for s14 windshield not the autozone shit) - $20 ![]() S14 Kouki 147k cluster - $125 ![]() S14 Sun visors with clips / hardware - $40 ![]() S14 Zenki owners manual with case - $30 ![]() ![]() ![]() S14 Kouki owners manual with case - $40 (Complete with warranty info brochure, Supplemental manual, and owners manual) ![]() ![]() ![]() ![]() S14 Power steering rack - $150 (NO LEAKS EXCELLENT CONDITION!!!) Last edited by mewantkouki; 08-28-2011 at 02:12 AM.. |
Sorry to hear the loss of your kouki... What part of town did ur uncle crash?
I need the driver side speaker plastic base/holder. What condition is the S14 ka tranny in? Possibly interested. pm or txt me 4075796936 |
#11 |
![]() Join Date: Sep 2008
Guys I am pretty sure the car is totalled, it hit the front and the rear.
Bump for an awesome guy/car, I have driven/ridden in it and it pulls super hard.
WTB: 1(one) battle version toe rod
-Mike |
#15 |
I would be interested in the KW's but the Clubsports come with their own camber plates.. Why do you have Techno Toy Tuning ones on there? Are you sure they are not the normal KW Variant V3's?
Anyways, I'll take the complete s14 DCC if you will ship it.. I have paypal ready.. |
#22 |
![]() Join Date: Nov 2004
Trader Rating: (53)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 53 reviews
Dude... I want your subframe and Do Luck tunnel brace.... will you ship either to 90032 los angeles?? please pm. if not, glws and sorry to hear about your car.
#24 |
![]() Join Date: Mar 2011
Trader Rating: (50)
![]() Feedback Score: 50 reviews
I hit u up on the do luck tunnel brace way b4 anybody here...When u were barely posting stuff up ...wats up?
Have dibs on resonator pipe and shakitto plates too...I was waiting on the pics..... |
