Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Drivetrain
Old 03-02-2011, 10:26 AM   #1
maverickmotorsports
maverickmotorsports is an unknown quantity at this point
Z33/VQ35 to SR20 Adapters in stock!
$430 shipped for the adapter plate!
Z33 Transmission to SR20 Adapter!
Hey Zilvia! We had a really good response to the original thread and we just got more adapters in!
These are the new Version 2 adapters. The new plates have a slight modification which allows a little more clearance with bottom mount turbos.
So why a Z33 transmission? Keep reading!
The gearing is superior to an SR/KA/Z32 transmission. All of the gears are shorter now so you won't find yourself stuck between 2-3 gear on courses any more. You can now leave it in 3rd gear and rip! Not to mention having a 6 speed transmission that is tough and not made of glass like any SR/KA transmission!
This transmission is also significantly stronger. There are local 9 second Z33's that have yet to blow a trans. STOP BREAKING STOCK TRANSMISSIONS! Check out the gear size comparison!
You will retain your SR Clutch/Flywheel. You do not need a Z33 clutch.
What you need for the swap:
-Adapter plate
-Transmission mount
-Driveshaft
-Shortened shifter bracket
-Modifying Z33 Bellhousing
-Stainless steel clutch line. There are many vendors out there who sell these.
Pricing:
Just the plate and hardware is $430 shipped
Additionally other mods are available in stages depending on what you want to pay for.
Bellhousing Machining. Not just any machine shop can do this because of the size of the bellhousing. $80 +ship
Shifter modification. You send in your shifter and it gets modified then sent back to you. $125 +ship
Transmission crossmember. You can retain the original rubber mount(aftermarket mounts will also work). $100 +ship
A video of the first drive.
The two-tone s13 in front has the Z33 trans installed.
ImportTuner feature on the car we did the prototyping on.
Once this is done, you become rad!
Contact:
http://www.maverick-motorsports.com/collections/all
Thanks, George
-George Marstanovic
Sr to VQ transmission adapter, dual caliper brackets, high angle tensions rods, and more!
maverickmotorsports is offline   Reply With Quote
Old 03-02-2011, 12:17 PM   #2
lazysk8er2
lazysk8er2's Avatar
lazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud of
Ahh no KA-T love?
Well i have a 95 240 and i like my cars low... But my parents don't like my wheels tilted
________________________________
lazysk8er2 is offline   Reply With Quote
Old 03-02-2011, 12:26 PM   #3
maverickmotorsports
Originally Posted by lazysk8er2 View Post
Ahh no KA-T love?
Working on it right now. We should have the R&D done soon and then it will go into testing.
-George Marstanovic
Old 03-02-2011, 02:04 PM   #4
Mitsubayati
Trader Rating: (18)
Mitsubayati is an unknown quantity at this point
Feedback Score: 18 reviews
Send a message via AIM to Mitsubayati
Nice I want a VQ tranny for my KA-T setup too! Can you guys make a whole kit so that it's just easier? Maybe with a core charge if we don't exchange.
http://www.fittedlife.com/images/nickbanner.jpg
Mitsubayati is offline   Reply With Quote
Old 03-02-2011, 11:50 PM   #5
maverickmotorsports
WOW. These are selling fast!
Only 2 left.
-George Marstanovic
Old 03-03-2011, 09:21 AM   #6
roland
roland's Avatar
roland is an unknown quantity at this point
Badass; wish I would of found this sooner. Already did the VQ swap!!!
roland is offline   Reply With Quote
Old 03-03-2011, 06:10 PM   #7
s15lover
s15lover's Avatar
s15lover is an unknown quantity at this point
Send a message via Yahoo to s15lover
what's up with the speedo prob? Any solid solutions?
s15lover is offline   Reply With Quote
Old 03-03-2011, 09:49 PM   #8
maverickmotorsports
The speedo conversion has already been done by a customer of ours. You will need an ABS diff and a dakota digital conversion box. You can also use the S15 diff and the procedure is the same as putting an S15 transmission in.
-George Marstanovic
Old 03-03-2011, 09:59 PM   #9
s15lover
s15lover's Avatar
I'm wondering if I can use the sensor locations on the q45 r200 housings...as I have built a 4.6 and a 4.9 that I will be using...the both have the abs toothed rings on the output shafts. Any writeup on how to wire up that digital conversion box?
Nevermind found a pretty straightforward one on nico.
Old 03-07-2011, 12:43 PM   #10
maverickmotorsports
We had one of our customers install this kit and do some testing. You guys might know Rob Primo from the northwest. He has some very well built cars and he got a chance to drift with our Z33 kit. Read below to see what he has to say.
Ok so I just got back from testing my new Z33 Transmission setup on my Blue car.
I did a couple short test sessions at Pacific Grand Prix today as there was a shift kart competition. For those of you who havent had the privilege to drive Pacific Grand Prix yet its mainly a 2nd gear course for most cars. However with this transmission setup I found myself forced to upshift to 3rd during turn 2. This was unbelievably fun as I had never upshifted mid drift in a RHD. I also found myself in 3rd gear when I would initiate on the straights and then downshift to 2nd once I cleared the corner (again very fun) when I would usually be in the top of second. I could probably get away with keeping it in third the whole time with the Z33 transmission but that would require a lot of clutch kicks on this course as there multiple hairpins. Anyway this setup makes this track even more fun so Im happy. With the engine setup being super responsive and then tied to this transmission the car is unbelievably quick.
Here is a raw clip of my second and final test session.
I still have 2 more adapters in stock and ready to ship out.
-George Marstanovic
Old 03-08-2011, 11:13 PM   #11
sleepnsilvia
sleepnsilvia is an unknown quantity at this point
awsome item, I'd hop on it if I didnt already have the Z32 trans swap...+1
sleepnsilvia is offline   Reply With Quote
Old 03-15-2011, 12:29 PM   #12
maverickmotorsports
We still have a few more left!
The KA adapter is in the works right now. Should be available very soon.
-George Marstanovic
Old 03-16-2011, 05:52 PM   #13
martin ffrench
martin ffrench is an unknown quantity at this point
Hey dude looking forward to trying out your plate when it arrives.
Have the gearbox sitting on the ground ready to go. this is the car its going in by the way
CAR FEATURE>> A RECESSIONARY TALE - Speedhunters
martin ffrench is offline   Reply With Quote
Old 03-18-2011, 05:13 PM   #14
ReaperBJJ
ReaperBJJ's Avatar
ReaperBJJ is an unknown quantity at this point
I know you got asked a million times in the old thread but any date down the pipeline for an adapter for RBs?
'89 240sx-Track monster in progress
'03 Grand Prix GTP-pepped up DD.
ReaperBJJ is offline   Reply With Quote
Old 03-18-2011, 10:43 PM   #15
koukimunsta
koukimunsta is an unknown quantity at this point
Hey what type of Machining will have to be done to the bell housing on the Z33 transmission? have any photos? also a photo of the transmission bolted to the sr20 would be great!
koukimunsta is offline   Reply With Quote
Old 03-22-2011, 12:53 PM   #16
maverickmotorsports
Right now we are focusing on developing the KA setup because they don't have a strong solution to a transmission. The RB guys at least have a beefy box available. We will work on the RB setup after the KA one releases.
*please note, these pictures are from the R&D plate. The plates we sell are refined design.
-George Marstanovic
Old 03-23-2011, 07:31 AM   #17
koukimunsta
I read on a previous post that you said, The adapter plate cannot be thicker then "3/8". Any thicker and the input shaft on the Z33 wouldn't have made it into the SR pilot bushing." That does not seem to reliable if they are barley mating. I don't know if you mention this before but resurfacing 3/8" off the z33 transmission front flange will still have it engage entirely? send me an email regarding this at [email protected]
Old 03-23-2011, 02:03 PM   #18
maverickmotorsports
The bellhousing is machined to accommodate the adapter. The reason we cannot make the adapter thicker is because we would machine too much off of the bellhousing and cause a weak point in the system. I'd be happy to explain it in depth. Give me a call if you are interested, it's hard to type out why the thickness is what it is.
-George Marstanovic
Old 03-24-2011, 05:47 AM   #19
greg.g
greg.g is an unknown quantity at this point
Hi George
the sr20 adapter plate looks good ill take one, can you pm me a price shipped to england please.
Im currently running an rb box on a similar adapter plate but the ratios dont suit the sr20
greg.g is offline   Reply With Quote
Old 04-04-2011, 03:35 PM   #20
maverickmotorsports
BUMP!
Just made another run of plates. Keep the orders coming!
-George Marstanovic
Old 04-27-2011, 12:36 PM   #21
efrain_n7
Trader Rating: (99)
efrain_n7 is making a name for him/her selfefrain_n7 is making a name for him/her selfefrain_n7 is making a name for him/her self
Feedback Score: 99 reviews
awesome brackets, perfect for SR guys that want to keep up with LS's
efrain_n7 is offline   Reply With Quote
Old 04-27-2011, 12:48 PM   #22
hockeyrules
hockeyrules is an unknown quantity at this point
random question, but where at in flagstaff are you guys located?
hockeyrules is offline   Reply With Quote
Old 05-13-2011, 02:29 PM   #23
maverickmotorsports
Here are a few guys using our setup.
Martin Ffrench in his SR20 powered Altezza. This fine gentleman also won RD1 of the Drift Allstars series in the UK.
Another guy you might recognize is Walker Wilkerson who is KILLING it in Formula D this season. He's well on his way to rookie of the year.
We have also LOWERED the price to $420 shipped for the adapter plate.
-George Marstanovic
Old 06-07-2011, 01:44 AM   #24
Tafi (TR)
Tafi (TR)'s Avatar
Tafi (TR) is an unknown quantity at this point
Hi george,
I have s14 & g35 6 speed MT.
do you know your z33 adapter is fit on g35 transmission?
And my other question is for s14 speedo gauge
if I put the g35 in my car will my speedo gauge is work or not? if not what can I do to make it work?
because I look at your s13 video your speedo is dont work.
And my zip numper is 34893 how much is postage price for adapter?
Thanks
Tomei Sr22DeT Nissan s14 Silvia 200sx | Facebook
Tafi (TR) is offline   Reply With Quote
Old 06-13-2011, 04:51 PM   #25
maverickmotorsports
Local AZ native Mike Burns wins using a Z33 Adapter!
In his first event with the new Z33/SR20, XDC and Pro-Am competitor took the win at Vegas Drift Pro-Am RD2. Mike fought hard throughout the night and eventually reigned supreme.
It's hard to miss his slammed "Team Burst" styled car. Watch for it in upcoming XDC and Pro-Am events!
-George Marstanovic
Old 06-22-2011, 05:22 PM   #26
vjboost
vjboost is an unknown quantity at this point
+1 on KA adapter. george you have a PM.
vjboost is offline   Reply With Quote
Old 08-06-2011, 12:10 AM   #27
projects
projects is an unknown quantity at this point
Hi George.
quick question about fitting the Z33 gearboxes into S13's whithin the trans tunnel the mount for the cross member is spot welded up and around the tunnel. the box seems to be to big for this area, how have you gone about making it fit?
projects is offline   Reply With Quote
Old 08-06-2011, 04:38 PM   #28
projects
Anyone able to help me out with this problem? i'm probably just going to start cutting the support up and stiffen it other ways.
anyway i made one of these plates for a RB its behind my 26 thats gong into my ps13. if you want to see more pictures just ask and i kindly pm or post a thread somewhere. im new so just tell me where i should do one.
Old 08-14-2011, 11:35 AM   #29
kujo13
kujo13 is an unknown quantity at this point
Im driving a 240sx sr20det and working on a g35 transmission swap. I allready purchased the convertion kit that is mentioned in this forum.The problem i have is that g35 doents have the speed sensor so when i cant get the signal from the transmission do i get it through the ABS system? how can i get my speed meter work when i do the swap?
p.s. im using Aem Stand Alone ECU
kujo13 is offline   Reply With Quote
Old 08-21-2011, 05:52 PM   #30
maverickmotorsports
You can use the ABS signal in the diff similar to what needs to be done when swapping an S15 transmission.
-George Marstanovic
Copyright ©2000 - 2019, vBulletin Solutions Inc.
