![]() Ok so I have a 91 coupe. Dual cam motor. I took it to get it smog and it would not pass. They told me motor was taking to much gas and it's running to rich. Everything in the car is stock except for suspension, but I can't find the problem. I changed the fuel pressure regulator checked the sparkplugs just make sure nothing was going inside everything checked out fine check compression and they are all good. Also took out the fuel rail and checked if any of the nipples will leak as well nothing. So I'm stuck don't know what else to look for. Car still smells to rich and can smell a bit of gas from the exhaust when it runs. So can someone help me out. Thanks.
![]() Join Date: Feb 2010
running rich means there isnt enough spark
try distributor cap and rotor mine did smelled like fireworks!! lol its not that bad anymore how bout some exhaust leaks? |
#3 | ||
![]() Join Date: Feb 2008
Most likely a vacuum leak or a bad MAF. Check for those.
Check out the coolest new thing: toddrickkkkk.blogspot.com |
