![]() Join Date: Dec 2009
![]() While getting my distributor timing correct I warmed the car up then shut It off, unplugged the tps and then started it again And put timing to 20 degrees btdc then shut the car of And plugged the tps back in And...now the starter wont engage, I just put this motor in And also did a five speed swap at the same time, but I know its not the neutral safety switch because I already switched it through all of the positions and nothing helped
![]() Join Date: Jul 2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
please state the following to help you get a answer to your problem.
what type of car you have. what type of motor it has. what type of modifications you have. Do you have power? have you checked for a blow fuse? have you tested the starter to be functioning normal?
![]() sorry problem solved, it is a 240sx, which i thought was obvious by my screen name with a ka and all it has is shaved head .060 and full exhaust starter was bad but would work sometimes... that is why i was so confused
