Old 04-14-2010, 10:32 AM   #1
kikcaffine
kikcaffine is an unknown quantity at this point
Weird problem tryign to fill S14 with gas.
Im having a weird problem when trying to fill my car with gas. It will only allow about .10-.15 gallons of gas before it trips the safety shut-off on the pump. I pulled off the filler neck and it wasnt clogged and rummaged around in the gas tank around where the gas comes in at and there wasnt anything I could immediately feel that was in the way or anything. When I do have to refill the car with gas, its usually below a quarter tank of gas and it makes a hissing sound, so Im assuming its building pressure properly. Is there any vents I should be checking for to see if they are clogged? Or has anyone else experienced a problem like this before?
kikcaffine is offline   Reply With Quote
Old 04-16-2010, 10:18 PM   #2
kikcaffine
Anyone? Any insight as to what to start looking for?
Old 04-16-2010, 10:28 PM   #3
ddf2006
ddf2006's Avatar
ddf2006 is an unknown quantity at this point
is it possable that ur gas meter in the tank isnt just off and wen u do have a full tank it only reads half????
just a guess
happined to my cousins 86 corolla
the needle was bent and wasnt reading the right amount of gas
ddf2006 is offline   Reply With Quote
Old 04-17-2010, 03:19 PM   #4
kikcaffine
Nope, cause it will take in a solid 10-11 gallons of gas and it wont be 100% full
Old 04-17-2010, 03:46 PM   #5
R_G
R_G's Avatar
R_G is an unknown quantity at this point
how many miles does your 10-11 gallons of fuel give you>?
R_G is offline   Reply With Quote
Old 04-17-2010, 04:20 PM   #6
shinobis13hb
shinobis13hb's Avatar
shinobis13hb is an unknown quantity at this point
Mine has a similar poblemmine stops at 12 or so. honest i fill it till it gets mad at me. But 20 gives you about half a tank or so Judy members that and 40 fills it that's what it is with me (premium)
shinobis13hb is offline   Reply With Quote
Old 04-17-2010, 11:44 PM   #7
kikcaffine
Bout 200 or so. It will happen even when I drive it in almost completely empty also. It just hisses more when its that low though.
Old 04-20-2010, 04:12 PM   #8
kikcaffine
bump.
msg lgnth
