Old 04-13-2010, 09:14 AM   #1
SoloSilvia
SoloSilvia's Avatar
Trader Rating: (36)
SoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud of
Feedback Score: 36 reviews
Thumbs up S13 S14 SR and KA parts, the list keeps going!
stuff for sale pictures by brsilvia - Photobucket
Check above link for pics....
95-98 Nissan 240SX S14
1- Tanabe Rear Subframe Bushings, New($80)
1- Driver Door, gutted,dented, repairable, custom gold($30)
1- Rad Shroud/lower/sides($15)
1- OEM Electric Fan ($20)
2+- Clutch Fans($10 ea)
1- Full Fiberglass Interior, needs refinished($350)
1- A/T Drive Shaft, no ABS($50 obo)
1- Brake Master Cylinders complete with Booster(from 97 w/abs 15/16" yellow cap, mint)($50)
1- R & L OEM Rear upper arms($20)
1- R & L OEM Rear Struts, good($30)
1- Front R & L OEM Calipers 55k, Rotors, pads hardware ($80 obo takes all)
1- Misc Blue Interior Peices, ask and I may have, Panels, Trims, ect.....
1- Misc Window trims, door trims, ect
1- Cowl Panel($20)
1- Blower Motor assembly($30)
1- Bumper Light, Driver($10)
1- Complete rear seat, Black with colored patterns, SE model($50)
1- Some and I mean some Misc black interior peices, no dashes or big panels, maybe some trims...
1- Carbon Fiber Subwoofer Enclosure for S14 Trunk, fits in wheel well, fits a 12" Kicker L7, scratches and hole, uber light!($50)
2- Complete OEM Airbox assembly, all plastics, lot of doubles, and triples, so I will sell whatever peices you may need!
1- KA Alternator ($50 obo)
1- Starter ($50 obo)
2- P/S Pumps and brackets/bolts($50 pump only-$60 with bracket)
2- P/S Resivoirs ($10)
3- KADE Front Covers top($20ea)
1- KA Front Main Cover( Missing Oil Pump(($20)
(Any KA Part you may need Im sure I have a few of them, I boxes of accesories and internals, bolts, the hard to find lil things!)
1- Misc AC Parts, lines, brackets
4- Pilot Bushing's , Brand New($10 ea)
2- Pair KADE Engine Mount Brackets($40 set obo)
2- Window Washer Resivoir, with motor, and cap, complete($40 obo)
1- KA24DE S14 Valve Cover($40 obo)
1- Used Clutch, OE replacement, unknown brand, half life left($50 shipped obo)
1- Flywheel Bolt Set($20 obo)
1- Clutch Pressure Plate Bolts($15 obo)
1- Tranny Bolts for 5 Speed($20 0bo)
1- KA24DE Long Block, Needs timing chain set, oil pump, and gasket set. This motor still ran, when dissassembled, Just needs a rebuild basicly($150 obo, will part out also, Just lmk what ya need)
89-94 Nissan 240SX S13
1- SOHC Engine Harness($80 OBO)
1- SOHC Lower Harness($25 obo)
1- DOHC Fuel Rail & Injectors(missing fpr)($50 obo)
1- DOHC Throttle Body and TPS Sensor)($30 OBO)
1- OEM Front Brakes, R&L, rotors, calipers, pads, great working condition, painted red, very low miles($100 obo complete)
1- Ton of KA24DE Parts! TONS! (please refer to above at bottom S14 list) Ask and Ill let ya know, I prob have it!
1- Also a handful of SOHC KA24E parts, Brackets, Alternator, Starter, all accesories,ect
1- OEM Airbox assembly, tubing, ect($25....)
2- Clutch Fans($10 ea)
1- Misc Black interior pc's, door sills, kick panels, center console,ect .....ask, i may have
1- PS resivoir($15)
2- P/S Pump SOHC($40)
1- AC Compressor(1 ka24e, w/brackets, ect....)
S13 SR20DET
(Had Pretty Much for a Complete Build with lots of goodies to part out! Will update accordingly!)
Engine Mount Brackets ($80 obo)
Alternator Bracket($40 obo)
1-P/S Bracket($30 ea obo)
1-Starter ($80 obo)
1- AAC Idle Air Control($80 obo)
X- OEM 8 EX Valves/13 Springs/Retainers($xx obo)
1- OEM Timing Chain Guides/Chain Very minimal wear if any...($75 obo)
1- OEM Cam Gears Great shape($50 obo)
1- OEM Valve Stem Seals New($50)
Head Bolts($25 obo)
Main Bolts($25 obo)
Greddy Oil Sandwich Adapter w/3 ports ($50)
Manifold Studs(new-$30, used $15)
OEM Multi Layer Exhaust Manifold gasket, pressed once, great shape($25)
Oil Strainer Good shape($20)
So many extra nuts and bolts for the SR, anything you may need, I probably have, please check my photobucket album!
3- AC Compressors, with Brackets, ect($100 complete with bracket, or $50 ea pc obo)
1- Misc turbo items, oem actuators, lines, ect...
1- Misc wiring, plug ends, ect....
1- OEM Fuel Rail, with Caps, no fuel pressure regulator, no injectors($30 obo)
1- Water Lines on side of block, complete with sensors, ect($50 obo)
1- Misc items, rare bolts, sensors, lil things, I may have, just ask....
I have alot of 240 parts among other parts, So if you need something, just ask!
Call/TEXT 330-432-4871
PM me with all serious inquiries!
I can get pics of anything needed,but Im not gonna waste time taking pics for lowballers. And if the item says New, I promise you it is NEW! Most likely in original box whatever it came in!
Thanks,
Brian
Ive been getting alot of inquiries about the carbon fiber sub box. Here is a few pics of it in the car...
I have a complete Kicker system that is Loud as FXXX will include 1000.1 amp kicker l7 sub, 350.4 amp, 6.5 component front, 6.5 coaxil rear, with box all for only $1000 OBO!!! PM if interested! All stuffis like new condition, except box....battery came loose and bounced around box. lil wetsand and buff may save the carboin look, or repaint to match your car, or graffitti it, IDC! lol
Hatas Keep Hatin, I Keep Rollin!
Last edited by SoloSilvia; 06-23-2010 at 08:40 PM.. Reason: Updated! Parts Sold deleted! Parts Added!
SoloSilvia is offline
Old 04-13-2010, 09:40 AM   #2
2fast4y0u
2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore2fast4y0u is not welcome here anymore
very interested in the sub thing for the s14 trunk. i looked throguh the pics but didnt see it...to makny to look through maybe? can you send me some pics please and a price shipped to 60520
2fast4y0u is offline
Old 04-18-2010, 06:47 PM   #3
SoloSilvia
SoloSilvia's Avatar
Trader Rating: (36)
Sunday night Bump #1!
Thanks for the interest everyone, list is updated when items are sold, if its still there, I still got it!
Old 04-26-2010, 09:59 AM   #4
SoloSilvia
SoloSilvia's Avatar
Trader Rating: (36)
Next Monday Bump #2!
Thanks to everyone whos bought off me, please leave trader feedback!
Old 04-30-2010, 09:43 AM   #5
fairglen21
fairglen21 is an unknown quantity at this point
I really need a 5 speed tranny if you have one available?
fairglen21 is offline
Old 04-30-2010, 07:52 PM   #6
malcolms12
malcolms12's Avatar
malcolms12 is an unknown quantity at this point
Are those new head bolts?
malcolms12 is offline
Old 05-01-2010, 09:55 PM   #7
IIIXziuR
IIIXziuR's Avatar
Trader Rating: (22)
IIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfection
Feedback Score: 22 reviews
What are you looking to get for the these water lines?
I need just the actual metal piping here none of the rubber hoses or sensors
Shipped to 08831. Thanks for your time.
IIIXziuR is offline
Old 05-02-2010, 09:03 AM   #8
SoloSilvia
SoloSilvia's Avatar
Trader Rating: (36)
PM'd.........................
Old 05-04-2010, 08:06 AM   #9
dinger 240
dinger 240 is an unknown quantity at this point
I need the windshield wiper bearing passenger side and the rod that connects to the driver side for s13 shipped 15904 [email protected]
dinger 240 is offline
Old 05-12-2010, 02:25 PM   #10
SoloSilvia
SoloSilvia's Avatar
Trader Rating: (36)
Sorry,I Do not have any S13 Wiper assemblies/bearings(bushing), and all ones I have for S14 are used up. Try a local salvage yard, Good Luck!
Old 05-21-2010, 06:39 PM   #11
94vert
94vert's Avatar
94vert is an unknown quantity at this point
I need the Coil Pack Harness shipped to 70806 pm me your pay pal nfo
94vert is offline
Old 05-30-2010, 11:01 AM   #12
SoloSilvia
SoloSilvia's Avatar
Trader Rating: (36)
all coilpack harness's sold
still have full 4 set of coil packs!
Old 06-20-2010, 08:08 PM   #13
SoloSilvia
SoloSilvia's Avatar
Trader Rating: (36)
Last bump before this gets locked.
Taking inventory and new thread up in a few weeks!
Thanks to all who have been in contact and dealt with me.
I still have All the above and then some available!
Old 06-20-2010, 11:04 PM   #14
barrera546101
barrera546101 is an unknown quantity at this point
where are you in ohio do you have the adjuster bracket fo the alt? for a sr
barrera546101 is offline
Old 06-21-2010, 07:41 PM   #15
SoloSilvia
SoloSilvia's Avatar
Trader Rating: (36)
Im in New Philadelphia, zip 44663, and yes I beleive I do have the tensioner. PM me if you still need it.
Old 06-22-2010, 12:21 AM   #16
NIZzS13
NIZzS13 is an unknown quantity at this point
How much for the intake manifold shipped to 10469. But is has to be a dual overhead from a 91-94 S13. S14 manifold i cannot use.
NIZzS13 is offline
Old 06-22-2010, 09:03 AM   #17
SoloSilvia
SoloSilvia's Avatar
Trader Rating: (36)
Yes it is from an S13, Pm sent!
Old 06-22-2010, 10:50 AM   #18
Xclusive_racer
Xclusive_racer's Avatar
Xclusive_racer is an unknown quantity at this point
picture of breaK booster and master cylinder please and what will it be 5 $ extra shipped in a flat rate box?
You Build Cheap! Your Car Will Feel and Drive Cheap!
Xclusive_racer is offline
Old 06-22-2010, 12:40 PM   #19
Xclusive_racer
Thumbs up Sorry I saw the pics
I Saw The picture how much shipped in flat rate box
Old 06-23-2010, 08:46 PM   #20
SoloSilvia
SoloSilvia's Avatar
Trader Rating: (36)
Xclusive_racer- Sorry I could not help you out, GL.
Just sold one of the 2 Brake Master cylinders, only got one left: 1- Brake Master Cylinders complete with Booster(from 97 w/abs 15/16" yellow cap, mint)($50)
Old 06-30-2010, 06:37 PM   #21
blackcandle0
blackcandle0's Avatar
blackcandle0 is an unknown quantity at this point
How complete is the de longblock you have. I plan on a rebuild just wondering if u have little things like main caps, crank and rods.
blackcandle0 is offline
Old 07-01-2010, 09:05 PM   #22
SoloSilvia
SoloSilvia's Avatar
Trader Rating: (36)
The Long block is complete, head has not been pulled yet. I did remove the oil pump to use for another engine, but it still has the front cover on it. and a timing chain guide on driver side broke(plastic guide). The engine still cranked , but was retarded in time. So All internals are fine, I pulled oil pan and everything looked good. PM me and Let me know if your interested!
Old 07-02-2010, 09:04 AM   #23
racerx2k1
460
racerx2k1's Avatar
racerx2k1 is offline
