sr acting funny in higer rpm range
ive been trying to figure this out for a little while and i need some input.as im driving if i take her up closer to 6k she like dosent really bogg but sounds like there no spark or gas going in until it drops back down then will kick but there that barrier of 6k. the only gears ive tried this in is 1-3 not even smacking it. just rolling on it. smooth all the way up to that though. as i let off i just hear sounds like just vacume suck and that it. i really have no idea what it is
spark blow out maybe? help please |
Check the intake tube on the front of the turbo.
Are you still using a rubber one? Does it have a big metal spring inside of it to keep it from collapsing under load on itself? If it does, it could still be worn out and weak, get a solid pipe to replace the old rubber pipe. Other possibility is your ignitor coil pack harness ground is coming loose on the back of the head/firewall, make sure this is tight
Like Me on FaceBook ![]() |
#3 | |
