04-01-2010, 01:34 PM | #1 |
SR20DET Blacktop w/ Garrett GT2871r .64 turbo dyno charts
Single 17.2PSI boost run:
Multiple runs: My 1991 Nissan 240sx S13 with SR20DET got dyno and here is the mod list. Engine: 1996 SR20DET Blacktop w/ Garrett GT2871r .64 Apexi 1.2mm head gasket Arp studs Tomei 256 cams Brian crawler springs, retainers Cp pistons, rods Fuel: Nissan oem 740cc injectors Walbro 255 fuel pump Sard fuel regulator w/ gauge Splitfire Direct Ignition Coils Breathing: Z32 n62 MAF Apexi power intake filter Greddy intake piping Greddy VSPL intercooler HKS SSQV Bov Greddy intake manifold Fullrace exhaust manifold (bottom mount) Garrett dump pipe Megan test pipe RSR Ex-mag Drivetrain: DSS aluminum driveshaft Toda lightweight flywheel Exedy 3 puck clutch Electronics: Blitz SBC id boost controller Apexi PowerFC with commander Questions: 1) Are my dyno curves look good? 2) If I set the boost controller 0 boost, it means stock boost right? Then, I should have 6-7 psi for stock internal wastgate for Garrett GT2871r turbo. Then why the chart show 0 psi (3rd pic of the "Multiple runs")? 3) How do I correct the 10 psi boost creep shown on the 3rd pic of the "Multiple runs"? Should I set the gain on the boost controller differently? Thanks! |
04-01-2010, 03:14 PM | #3 |
Imageshack - 201003291993nissan240sx.jpg - Uploaded by Imageshack user Imageshack - 201003291993nissan240sx.jpg - Uploaded by Imageshack user Imageshack - 201003291993nissan240sx.jpg - Uploaded by Imageshack user Imageshack - 201003291993nissan240sx.jpg - Uploaded by Imageshack user Multiple runs: Imageshack - 201003291993nissan240sx.jpg - Uploaded by Imageshack user Imageshack - 201003291993nissan240sxg.jpg - Uploaded by Imageshack user Imageshack - 201003291993nissan240sx.jpg - Uploaded by Imageshack user Thanks! |
04-01-2010, 05:07 PM | #4 |
Whats you timing look like from 4k to 8k in the load row that correlates to 17psi? Should be around 14-18 degrees depending on octane.
Whats the lift on those 256 tomei cams? At that boost pressure that turbo should be capable of maintianing a flat torque curve beyond 6k. The quantity of torque isnt so important as it is to note that its droping at 6k. Something in the system is choking. My guess would be the cams. |
04-01-2010, 06:28 PM | #5 | |
Daily driven |
04-02-2010, 10:43 AM | #6 |
I am not sure about the lift. I bought the car that already modded. So if I know the part #, I can find that out, right?
Is my T25 bottom mounted exhaust manifold choking? |
04-02-2010, 10:46 AM | #7 | |
It will eventually, but not yet it's not. People are able to push ~400-420 whp and 300-330 ft-lbs tq with that turbo, provided you have good supporting mods and the right cams and intake manifold. I would say with where your dyno is at right now, it is not choking at all, you are operating in the "sweet spot" of the turbo.
Daily driven |
