03-28-2010, 06:12 AM | #1 |
s14 t28 spooling early?
got my motor all hooked up! and im not sure if this could be because my motor is maybe off timing? but my turbo will spool really early it seems like, i will be in the low 2k rpms and it sounds like my turbo is spooling, pretty loud, and im also getting compression surge while moving, but when the car is sitting and i rev it there is very little to no compression surge, anyone know whats up?timing?
i have sr20det, with s14 t28 turbo with hks bov, isis front mount intercooler, enpalthy tune, 480cc injec, 264 toda racing cams, toda adjustable cam gears so let me know what you guys think it could be |
03-28-2010, 06:14 AM | #2 |
Your BOV is adjusted wrong. Ball bearing turbos need a load to spool, which is why it doesn't compressor surge at idle.
Loosen up your BOV spring and it should blow-off while driving.
03-29-2010, 10:59 AM | #4 |
Unless your engine gets really hot or is low on power, I wouldn't worry about the timing for now. Make sure you BOV is working and then take it for a drive. If it runs real hot then it could be timing. I really doubt anything else is wrong if you didn't mess with the timing (Taking the CAS out or whatever).
03-29-2010, 04:19 PM | #5 |
nope i drove it about 5 miles to a gas station, but i babied the shit out of it, the temp is real steady in the middle of the gauge, and it feels like it has power, i just don't want to give it full throttle just incase... i was told that maybe my actuator is stuck shut? i don't have a boost guage so i don't know where my boost is building at
the t28 is just really loudly spooling at like 2k with my foot bearly on the gas, so i dunno.. |
03-29-2010, 04:33 PM | #6 |
Trader Rating: (32)
Feedback Score: 32 reviews
Buy a boost gauge. Sounds like your blow off valve Is leaking! plus a boost gauge will help you check your vaccum pressure which can tell you If you do have any vaccum leaks such as a leaky blow off valve.
*-- SPIDER --* |
03-29-2010, 06:11 PM | #8 |
i kinda want to lean towards timing, except you dont get compressor surge by just free revving. which i have typically seen.
as for the BOV you need to make sure it is working properly. if u drive it hard does it blow off? the BOV WOULD give you alot of compressor surge if it doesnt properly open, but wont spool your turbo any faster. is the wastegate functioning properly?
@UpshiftEngineering |
03-29-2010, 10:32 PM | #9 |
yeah i don't know if its working properly, when free revving it seems like it is, but like is said when im in gear it wants to surge, i took off the back peice on my bov and i don't really see how it can be adjusted? i see a big nut type thing looks like a 16mm but doesn't look like its meant to be adjusted, i may have a v2 ssqv..
as for the actuator i tested it today by sucking on the vacc line to the actuator and keeping it on my toung to see if it kept suction, and also i blew compressed air into the line to see if it would do anything, and it seems to move correctly... maybe its my vacc source? should i use the same vac source for my FPR and BOV? and a seperate line for my actuator? here the bov Last edited by Options13; 03-29-2010 at 11:14 PM.. |
03-30-2010, 03:49 PM | #10 |
this has been happening from the start but its kind of getting worse... the fact that the motor wants to stall out after revving now.. used to only do that when driving
its very shaky, and it wants to stall out after i rev it, and as you can see my bov ain't doin shit.. YouTube - sr20det haggard idle |
03-30-2010, 04:01 PM | #11 |
your timing is off. it's spooling and creating boost with no load which means timing.
My timing was off by 33 degress and I was creating 10lbs of boost with NO LOAD which is not supposed to happen. Simone Video Blog - Boost Gauge Readings on Vimeo |
03-30-2010, 05:42 PM | #13 |
if the bov is not recirculated (which yours is not obviously) then it will have a problem catching it's idle. sometimes it may choke out and die. make sure the electrodes on the maf itself are not caked with dirt.
03-30-2010, 11:21 PM | #14 |
they aren't maf looks rather clean
i popped the valve cover off, these cam gears are on stock settings correct? they may be a hair off, but i don't see how that could make a dramatic difference. intake exhaust |
03-30-2010, 11:43 PM | #16 |
ah yes, there is.. for some reason i took these pics at 2 separate times... also is it possible my car could be idling like that because my maf is mounted to close to my turbo?
p.s - i also grounded the coil pack ground in between a nut a washer on the valve cover, that ok? Last edited by Options13; 03-31-2010 at 02:30 AM.. |
03-31-2010, 02:41 PM | #19 |
First you need to check the ignition timing using a timing gun. The cam timing looks good, only thing I couldn't verify from your two pics is that there are 20 pins between the alignment marks on the cam gears but if you were at TDC when you took this the cam timing looks good. Also those shiny links don't mean much and will only line up every few rotations. Anyone who has worked on an SR very much will almost never use those links to install a timing chain.
Next how can you say your turbo is spooling too quick? Spooling quickly is good as long as you don't have compressor surge and your ignition timing is set right. Its impossible for any of us to say your car is spooling too quick. Especially with a T28 you should be midway spooled by 2,000 rpms. But you need to get your timing set, if you have the valve cover off still re-stab your CAS. This should get it very close, close enough that the idle problems should go away. I've had an open atmosphere BOV for 5 years and never once had my car die from it. Do you have Electric fans? If so they can pull too much draw and cause a car to stall out on decel or idle. Also maybe I missed it but was the comments on adjusting your BOV about your idle or your turbo spooling? You turbo spooling quickly would be a refelction of the exhaust system not the intercooler piping. If the BOV leaked you should be running rich, and will also generally see slower spool. And if your BOV never even opened you can't get a turbo to spool faster that way. Many people with BB turbo's don't even run BOV's, the only time this will help with spool is during transient response (staying spooled during shifts). Things like the size of your piping can help it "spool" faster as the piping/manifold will fill faster and show the pressure quicker, but the turbo itself is still spooling at the same rate essentially, other than that the extra pressure flowing through the head will help the turbo spool up but that is not going to be enough difference to really notice. My suggestion is check the timing/re-stab the CAS, then test it out. If you still have idle problems there are a ton of other things we can check but first things first you need your timing right. With aftermarket cams it would be a good idea at some point to degree them just to make sure you get the most out of them. But they should be close enough right now that you can enjoy your car without any drivability issues. I'll try and follow up with this thread to see what you find and see if I can help with any more suggestions. Feel free to PM me if you need any specific help. |
04-01-2010, 01:34 AM | #20 |
hmm that might just be my problem! THAT and timing, i am going to reposition my cas tomorrow, and install a stock crank pulley back on, since the pulley i had only has a mark for TDC.. as far as my efans go, i had the power wire running to the engine control fuse, i took it out and shoved the wire in there... think that may be my stalling problem? also for my ground for my coilpacks, you think its ok that i have the ground in between a washer and nut on my valve cover? oh and thanks a lot man, your post may have just solved my stalling problems |
04-01-2010, 09:04 AM | #21 |
You should really try and ground the coilpacks somewhere like the head or intake manifold. Not the valve cover. But that shouldn't effect your idle like this. I've seen plenty of ghetto wired 240's with that ground not even used. If you have a volt meter you should check the ohms of any grounds to find the best ground possible. But thats probably overkill in this situation.
Do you have relays for your E-fans? If not you really should be using a relay for each fan. If you search on here there is plenty of threads showing how to wire these up but if you need help let me know and I can help you out. Pushing the wire into a fuse is never a really good permanent way to wire anything. |
04-01-2010, 02:41 PM | #22 |
alright, i'll look into getting relays
also im trying to re-position my CAS and it lines up with the left notch like FRsport says but it only lines up when the CAS is set like this |
04-02-2010, 12:01 AM | #23 |
i also found out why my car may have been dying.. i wired my e-fans wrong, i just shoved the power wire to my e-fans under the engine control fuse in my fuse box, it worked for a little bit... i took the fuse out and it was blown.. replaced it and motor seems to run ALOT better, i don't exactly see where to get my power source for my efans... so you were right on the money teamsprock!
i think my BOV is leaking, i drove the car a little today in my driveway, it won't build boost, it sounds like it is, but not according to the gauge! OR could my CAS be a tooth retarted again?! i stabbed it multiple times and got the same results (pics above) |
04-02-2010, 12:30 AM | #24 | |
Did you count the pins between the marks like he asked? When I did my swap, I was boosting wicked fast. I tried to set timing with a gun using the loop as well as a high tension cable but it was all over the place. I counted the pins and sure enough I was off a couple tooth. Count the pins and report back. |
