Old 12-01-2009, 08:54 PM   #1
raf702
raf702 is an unknown quantity at this point
5spd conversion with sr20det swap ??
The car I hope to get is a 93 240sx coupe auto, for a really good price actually. A deal that I just can't pass up. But anyway, here's the link I read about the S13 "Auto to 5spd" conversion. http://zilvia.net/f/archive-faqs/211...peed-swap.html I understand the parts listed in that link are needed to complete the conversion. Now I also plan to get a complete SR20DET swap as well.
Will I still need to obtain all those same parts separately, that is listed in that link? Or do I just need a few parts? And if so, which ones would I need specifically to go with the SR20DET swap? Cause I assume the engine swap already has manual transmission parts.
I plan to do the swap and conversion myself. I'm not a professional mechanic, but I'm sure I can manage to perform this type of job. As I've worked on car's plenty of times. And going to my mechanic to do both, is my last option. Thanks, I appreciate everyones response.
raf702 is offline   Reply With Quote
Old 12-01-2009, 11:17 PM   #2
Ceepo
Ceepo's Avatar
Ceepo will become famous soon enoughCeepo will become famous soon enoughCeepo will become famous soon enoughCeepo will become famous soon enough
Its not hard, the sr20det swap should come with the 5speed trans, shifter and what not, all you need is the clutch pedel, drive shaft(manual), clutch slave and master cylinder, either the hard line or steel braided line, tranny xmember, and re wire the lower harness(use the ka harness and just change the plugs)
1.Clutch pedel
2.Drive shaft
3.Clutch Slave
4.Clutch Master
5.Clutch Hardlines/Braided Lines
6.Manual Transmission Crossmember
7.Wiring
I think thats about it hope that helps, im in a good mood lol...
http://www.driftingisgay.com/
http://www.ka24development.com/cwilf...lectrical.html
http://zilvia.net/f/tech-talk/237660...swap-info.html
Those links should have some good info for you...
Ceepo is offline   Reply With Quote
Old 12-01-2009, 11:34 PM   #3
nismoR123
nismoR123's Avatar
nismoR123 is an unknown quantity at this point
i have just about every thing you need to do the swap. hit me up and i can tell you what i'm missing to complete your list and for how much i'm letting it go for. (951)907-0954
nismoR123 is offline   Reply With Quote
Old 12-02-2009, 09:31 AM   #4
g6civcx
g6civcx's Avatar
The best thing you can do is get a front clip. It will have all the manual parts you need.
Old 01-07-2010, 12:54 AM   #5
angel mkiv
angel mkiv's Avatar
angel mkiv is an unknown quantity at this point
wait im in the same situation....so do u keep the ka speed sensor at all?what exacly do i need to keep from my old ka24de motor and tranny??thanks
angel mkiv is offline   Reply With Quote
