09-30-2009, 02:57 PM | #1 |
S14 Partout - Quality Parts for Sale
Engine
The engine is in great running condition. $2,750.00 S14 SR20DET - Throttle Body to Exhaust Manifold Exedy Stage II Clutch Transmission - all gears in good working condition ARC SR20DET Oil Pan KR Water Pump Pulley Pre-wired Engine Harness for S14 WC ECU S14 SR20DET MAFS SR20DET CAS SR20DET Coil Packs Cusco Motor Mounts Nismo Transmission Mount MAMS Power Steering Line Power Steering Pump Starter Alternator Lower Engine Harness Turbo Sold S14 T28 Turbo with Taka oil, Taka water and OEM drain lines Manifold and Outlet Pipe are not included Intake Sold Apex'i Intake with aluminum intake pipe and bracket Mid Mount Intercooler $550.00 Precision Intercooler with Aluminum Cast 90s for S14 Chassis Aluminum I/C piping included Couplers and t-bolt clamps included Cooling Set $440.00 Koyo Radiator Samco Lower and HKS Upper Radiator Hoses RB26DETT Clutch Fan S14 SR20DET Fan Shroud - cut to fit I/C cold pipe Turbo Outlet Pipe $50.00 EBAY Turbo Outlet Pipe Flex Pipe $80.00 MR Flex Pipe Cat Back Exhaust $280.00 Custom S14 Exhaust with Aspec Blast Pipes Front Suspension Sold MR Coilovers with Z32 Lower Brackets Sold MA Awesometron 5000 Knuckles and LCAs Sold SPL Parts Outer with Tein S-chassis Inner Tie Rods $220.00 Front OEM 5-Lug Hubs with Ichiba Extended Wheel Studs $165.00 SPL T/C Rods $220.00 Carbing Aluminum Strut Bar Rear Suspension Sold Cusco Camber Arms Sold SPL Toe Arms Sold SPL Tractions Rods $55.00 S/T Sway Bar $250.00 Rear OEM 5-Lug Hubs with Ichiba Extended Wheel Studs Sold Tomei T-Trax 2-Way Diff in S13 Pumpkin and S14 Cover Complete Brake Setup $1,500.00 R32 Brembo Front and Rear Calipers, Rotors, and SS Lines Rear E-brake Assembly with Backing Plates R33 E-Brake Cables Tokico Z32 17/16 BMC Rear Z32 Aluminum Uprights Interior $350.00 OMP RS Bucket Seat $160.00 Bride FG Driver's Side Rail $220.00 Bride Brix I Seat with S-Chassis Passenger Rail Sold Nardi Deep Leather 330 Steering Wheel $225.00 WB GTC Flip Up Sold NRG Short Hub Sold ARC Titanium Round Shift Knob $425.00 Defi Water and Turbo Metric BF White Gauges with Controller $165.00 Fire Supression System - pick up only $55.00 Expired Cam Lock Harnesses Chassis The left rear section has been cut and replaced. The alignment setting while on the rack at R/T Tuning are within spec. The rear quarter panels have been cut to make room for more rim and tire. $1,650.00 Chassis Cage Doors All Glass All Moldings Harness from Fuse Box to Tail Lights Steering Rack and Column Side View Mirrors Metal Front Fenders Rear Overfenders Trunk Gas Tank Walbro Fuel Pump Engine Crossmember Front and Rear Bumper Reinforcements Side Skirts Rear Overs S14 Rain Guards Wipers Black Dash Pedals Clutch Master Cylinder Brake Booster Cluster Front Toe Hook T/C Brackets Johnny Fraz T/C Bracket Brace Rear Subframe with PowerTrix Spacers OEM Shocks and Springs OEM Toe, Traction, and Camber Arms Clean Title Exterior $440.00 D-MAX Zenki Hood with Aerocatch Non-locking Hood Pins Installed Lighting $650.00 Front JDM Headlights Retrofitted with Audi ECE HID Projectors and SuperMade Clear Covers and Matsu****a Ballasts/Igniters and Phillips HID Bulbs $20.00 Left OEM Taillight $100.00 Center and Right LED Taillights Wheels Sold Work VS-SS 17x9+5 with 1 day drifted for front 235/40/17 Federal SS595s 17x10+6 Tires $300 Four brand new 235/45/17 Federal SS595s CONTACT INFORMATION: LOCATION: NJ EMAIL: C doria (at) comcast .net AIM: carlos11 84 (1 word) PAYMENT OPTIONS: Paypal, Certified USPS Money Order, Check, and/or cash; first three payments have to clear in order for me to send the item out. FEEDBACK: eBay My World - carlos1184 http://www.importfanatix.com/Forums/...ead.php?t=1438 http://www.zilvia.net/f/showthread.php?t=95530 Wishing you all the best, Carlos Doria Last edited by Slidin240Wayz; 11-03-2009 at 08:26 AM.. |
10-01-2009, 06:58 AM | #8 |
No. I would like to sell the engine and transmission together as a package for someone looking to do a swap.
Replied What parts are you interested in? Thank you. |
10-01-2009, 09:09 PM | #10 |
WTF CARLOS?!?!?! you done with the 240?!?!? =\ time to get some vip rims for the Q45.
Legit seller. ive done business with him plenty of times. Buy his stuff!!!
10-02-2009, 12:24 PM | #13 | ||
Those will probably stay with the chassis.
Thanks for the kind words. Quote:
Here's the closest thing I have. |
10-06-2009, 07:42 AM | #20 | |
Sold: Intake Coilovers Rear arms Rims |
