09-17-2009, 11:36 PM | #1 |
Trader Rating: (22)
Feedback Score: 22 reviews
PARTS FOR: J30 Infiniti MAXIMA 300ZX 240SX S13 S14 Pontiac GRAND AM
Located at 94121
To find your parts quicker hit F3 on keyboard and type the part you are looking for, this should help you find parts quicker, but no guarantee that it always works. If you can't find it then try scrolling through the page till you find what you need Click on Image for bigger size. If you need labor work let me know, I can do almost anything car or bike $99 300ZX pair of KTS Made in Japan front brake rotors 30mm slotted used for 100 miles only, surface is in perfect condition. $199 S13 can be modified to fit S14 3" catback exhaust made in Japan I can't see the rest of the tag because it's been scraped from the bottom, not loud, only around 88-90dB. Has some dents and scraps but its not affected in any way in terms of flow and sound, works for either KA or SR bolts up also to 2.5" piping. Everything you see in pics is for sale, except for clutch parts I know I'm forgetting to post some of the stuff up on here so ask $20 Turn signal lever switch $30 Ignition Lock comes with key $50 Steering column assembly Lock, switch, and steering together $60 $50 installation $60 Chassis harness from fuse/relay box to SMJ block under dashboard Comes with relays and fuses $60 Interior harness from SMJ block to back/Dashboard harness Comes with relays and fuses $60 rear hatch window $50 rear hatch $60 rear hatch with window $30 installation $40 Fuel tank also comes with the filler neck $80 installation $30 Fuel pump $60 tank and pump $40 front subframe/ cross member $40 manual drive shaft $10 hood lock assembly $8 hood release cable brakes: $30 mastercylinder $20 booster hard lines ranges $10short ~ $20long ea $20ea front calipers $20 driver rear caliper rack and peanut $60 2x for $100. $90 installation includes fluid http://i596.photobucket.com/albums/t...dzilla/Rak.jpg $10 tie rods inner ea, no play $20 installation $10 tie rods outer ea bushings aren't great but no play $20 installation $60 DOHC power steering lines, includes cooler line, pressure line, and rubber hoses $15 reservoir $40 door window passenger $20 door mirror passenger electric $20 door handle passenger $10 door lock $60 bare door $80 complete door with everything listed above, electric window and locks. $20 installation 1 ONLY stock strut and spring $15 REAR $20 installation glove box $10 BROWN COLOR $10 installation dashboard $60, I'll take $50 and your bad dashboard $60 installation $60 for all 3 USDM tail light pieces. 2 tail lights and center garnish, comes with sockets and bulbs. SR20DET Clutch and pressure plate, tell me your offer 1. $99 KA24DE electric parts: oil sens, fuel injectors, TPS, Idle control unit, temp sens, temp sending sens, all of these for $99 2. $60 Cam angle position sens, distributor with cap, with new plug wires 3. $60 Alternator 4. $60 Starter 5. $40 Mass Air Flow meter 3 for $90 6. $120 ECU and harness re-wrapped with blue tape ($110 harness, $25 ECM auto can be used with manual it so you get no speed limit) 7. $120 J30 brakes for FRONT 8. $60 Intake manifold, exhaust manifold 9. $20 Throttle body 10.$50 Idle Air Control The fallowing are universal parts $25 power steering pump off VG30DE, I'm sure it will fit many other engines 2 for $40 $20 Fan very strong, 110mm width has tremendous amount of flow, can be installed in any radiator with zip-ties or screws $15 S13 chucki turn signals $15 both headlights Brand new, uses sealed internal bulb fits S13 pop ups, but its a little smaller then OEM 165mm (6.5")Length 110mm (4.25")Height 90mm (3.5")Depth $10 GT short shifter fits all kinds of Nissan transmission, it can also be straightened $10 S13 hood lock $20 both speakers 6" with door box from S14 $75 HKS grounding earth wire gold plated new $130, buy it before December and get it for $60 $8 1 5x7 speaker Delta fan 241CFM rated @12V!!!! Lot's of air 120mm x 120mm x 38mm<br> I have 1 Brand new fan left, online they cost $30 shipped each after tax $25. They are bare wire about 5in.<br>PRICING IS FIRM, you save $5 buying from me<br> Use it for radiator cooling and other needs such as window defroster, brakes, diff, tranny, steering, engine oil<br></h3> <a href="http://www.sidewindercomputers.com/deaf12recgrh.html" rel="nofollow">http://www.sidewindercomputers.com/deaf12recgrh.html</a> Infiniti J30 300ZX parts VG30DE: $20 TPS (Throttle Position Sensor) $25 power steering pump 2 for $40 J30 BRAKES: excellent upgrade for many NISSAN cars and others calipers use 2 pistons and will give better stopping power and clearance for many wheel fitment, rotors are bigger in diameter, and thicker. These are 5 lug, but it's no problem drilling it to 4 lug ( I can also do the install for you, $50 to install on front for 5lug, I can also drill them to 4 lug for $15) 1. $50 2 new front brake rotors 2. $60 2 used front brake calipers with mounting bracket, and hardware 3. $40 4 new front performance brake pads 4. $15 2 front rubber brake lines $140 for the 4 items to complete your front brake job $30 1 right rear brake caliper with bracket $15 2 rear brake pads $5 rear brake line The fallowing parts are off a 94 Grand AM $9 ECU $9 ignition coils with bracket The fallowing parts are from an USDM Maxima A32 95-99 VQ30DE $59 block with girdle, washed, has .004" wear on all cylinders. I can bore and hone the block for $80 $39 upper oil pan, bead blasted and clear coated $39 both front engine covers $79 Crank mic'ed and within standard size no need to cut crank $39 rods. I can machine them for $40 but rod bolts need to be bought first $229 both heads rebuilt, 3angle valve job, hand lapped, polished ports and combustion chamber, decked cut off .007", bead blasted and clear coated, comes with 4 OEM camshafts and I can also give you the old sprockets. $1000 labor for heads swap. $79 6 ignition coils, or $20 ea $19 ea valve cover $29 intake plenum ( upper intake) $29 throttle body $29 throttle position sensor $29 knock sensor $29 air idle control Heads, block, crank, and rods for $349 or everything $399 The fallowing parts are from an USDM S13 240SX $6 glove box with mounting bracket, brown color $19 OEM differential only, no housing, no ring gear, no output axles, just the bare diff. Comes with bearings, get this welded and swap it into your housing or don't weld it, up to you. $11 Brown 2 piece rear seats Suspension arms/parts $15ea. or $20pair:, ($20 labor for pair of arms installed, $10 ea additional pair) REAR [ Upper control arm 1 only] [ Toe arms ] [ Traction arms ] FRONT [ Tension rod braces ] $60 black cargo cover for hatchback mint condition. No fading, No rips, No smell, No stain or dirt, just a very clean cargo cover $29 hatchback center garnish no crack, 2 bulbs included ($10 installation) $10ea or $15 for both 1 Master Cylinder Rear brake HARDLINE 1 MC Right brake HARDLINE The fallowing parts are from a JDM S13 180SX (SR20DET) PARTS ARE NOT SPRAYPAINTED OR ANYTHING They are all bead blasted $210 INTEC ECM 200RPM raised rev limiter Revised fuel and ignition maps Tuned for- S15 Turbo GT28R, stock injectors, and stock MAF Also has a 3 wire connector, it can be used to control the ECM $20 engine mount brackets left and right $30 stock flywheel Used $30 ea or 3 for $29, OEM 86mm pistons with pins and rings Used $30 ea or 3 for $49 OEM rods 3 rods and pistons together ONLY $59 cam caps $10 ea or all 10 for $49 $20 turbo inlet pipe The following parts are from an USDM S14 240SX Zenki 95 96 $39 all 3 parts, $49 passenger air bag $19 air bag wiring harness $19 air bag computer/backup battery (installation available) $5 automatic shift lock cable $30 installation want to do trades? here's what I need Money CHEAP S14 SR20DET SWAP: ENGINE BLOWN OR WHATEVER HOPEFULLY NOT WORKING SO IT'S CHEAP. TRANNY. ECM. WIRING HARNESS FOR TRANNY AND ENGINE. S14 Kouki front end, lights, bumper, hood, grill, fenders, etc. S14 KA24DE AUTO TO MANUAL SWAP PARTS Knifes, throwing knifes, swords Money Japanese movies on DVD, horror action drama CPU Q9550 Q9450 E8400 E8500 1080p 720p flat TV 30" to 50" S13 PARTS: if you got any wheels 4 or 5 lug for 240 somewhere around 16" or 17" by 9.0"wide to 10" wide steering wheel, quick release, hub adapter carbon fiber driveshaft carbon fiber hood carbon fiber trunk with lightweight window 1 racing bucket seat or 2 with slider and rail 4 or 5 point harness Z32 back calipers, conversion lines, rotors pads, brake booster, mc front TEIN uppermount front tension rods aluminum only rear subframe spacers gauges tools: Matco snap on mac or something on the high end is recommended 1/2" electric impact gun 1/2" air impact gun, 3/8" air ratchets, cordless tools, 30" or 40" toolbox the wider box you have the better, and some other crap I cant think of now Motorcycle gear, MED or LRG helmet, 2 piece zip together racing suit sz40-44, armor keywords: turbogodzilla body reverse light lights back trim cover rear garnish heater ac air condition blower motor radiator cooler heater interior cover window air conditioning heater cooler cold 89 90 91 92 93 94 95 96 97 98 silvia amplifier amp ii audio pioneer alpine sony jvc aiwa onkyo iii rx7 fd fc b18 d15 h22 k24 s4 s5 4age chevy chev ford svt alpina bmw amg benz mercedes opel yamaha kawasaki porsche 944 kenwood jlc sanyo nissan honda toyota subaru mitsubishi suzuki 240sx integra corolla thundra tacoma civic sub subwoofer woofer speaker speakers stereo x crx camry impala caprice lexus infiniti bose aiwa jic spl kicker thunder samsung i mark cressida corona turbo godzilla corrona korona ngk blitz nagisa signal tomei sparco Phillips fuji zenrin calsonic total unisia jecs dunlop bridgstone toyo ebbro motul autech taisan advan ssr stp jomo ichikoh nismo xanavi impul seiko tomica hiroto kondo mine's tanabe Last edited by Hashiriya415; 11-27-2009 at 03:44 PM.. |
09-21-2009, 10:30 PM | #2 |
Trader Rating: (22)
anyone have any idea what it would cost to ship the dashboard?
I'm also trying to figure out what the dimension would be for the box. I tried to do it online and the calculator says dimensions are too big, I hope I don't have to deliver it myself from the west to the east. |
09-28-2009, 07:46 AM | #4 |
Dude seriously.... DONT POST SO MANY ADDS ON CRAIGSLIST YOU FUCK!!!!!!! post one then let it sit for a day... !!! FUCKING STOP IT DOOSHE BAG. its really fucking annoying when you do shit like that. make a post. list your shit... leave it. for a few days..... other people who use the site dont want to look at 240 parts and every single one is your garbage!
09-28-2009, 06:06 PM | #6 | |
Trader Rating: (22)
09-29-2009, 08:30 PM | #10 |
That seems a bit much considering you were asking $99 for Knock sens, oil sens, fuel injectors, TPS, Idle control unit, O2 sens, temp sens, and temp sending sens... and unfortunately is out of my budget at the moment...
So forget the injectors, How much for the knock sensor and the o2, and in what condition are they? |
09-29-2009, 08:41 PM | #13 |
Trader Rating: (22)
seriously I'll take 2500 cents to my paypal with verified address. [email protected]
10-14-2009, 03:02 PM | #27 |
man, thats a lot of parts...what brand is the flywheel? im local so pick up is no problem...
s14| y34| 911 gts| exige s| 600rr| r3| 250r| 85 girlfriend |
10-24-2009, 12:26 PM | #30 |
Trader Rating: (22)
$12
$26 Turbo compressor outlet CLICK PIC FOR BIGGER VIEW Rear sway bar $12, comes with bushings as seen in pics. S13 pop up light brackets $7ea, replace yours if they are bent or your light is sitting crooked. Last edited by Hashiriya415; 11-04-2009 at 11:16 AM.. |
