Old 04-21-2003, 11:34 PM   #1
Dousan_PG
Dousan_PG's Avatar
Tein Hard Tie Rods
WELL! i did it!
installed them today sicne i got them today (yeah yeah i have no patience)
WOW these suckers are BEEFY!!! im very impressed in both its quality and ease of install
why did i buy them?
I go drifting a lot
1 friend broke his going around a cone
another friend bend his (seriously bent) at the track friday
Mike (VRT) broke his dropping a wheel at the track
i read a lot of drifters bring extra tie rods to the track. after the above 2 (top 2) incidents, i seriosuly understand why!!
ok. let's begin:
Tein Hard Tie rods (inner) retail: 80 dollars
Tein Tie Rod endlinks: retail 80 dollars
you MUST buy the endlninks w/ the hard tie rods!! stock WILL NOT FIT the inner rods!!
i bought mine thru JDM Spec Performance in IL. contact Leo:
http://www.jdmspecperf.com/
836 Arlington Heights Rd. #192
Elk Grove, IL 60007
Phone : (630) 890 -6341
Fax : (630) 563-0343
HOURS (CST)
M-Th 12-8
F 12-6
order inquries: [email protected]
album: http://www.imagestation.com/album/?id=4290310787
OK the actual install:
Jack car and place jack stands
Remove Wheels
Turn wheel (easy access to tie rods)
remove cover boot on inner rod (has a wire strap type deal holding it
pull the boot forward to expose ball joint (beware, its greasy and messy)
loosen ball joint on tie rod endlink. bang out
now loosen and remove the inner rod
COUNT THREADS! VERY IMPORTANT!
compare w/ stock
OH DAMN! tein MUCh beefier!
install (reverse of above) torque to specs
cover boot back over the rack.
do other side (same process)
baddabing. wheels on and drive off!
GET AN ALIGNMENT (i am this week)
i'll continue the write up AFTER the alignment (write about handling)
right now, felt less bumpsteer, car felt VERY smooth on the freeway. but i'll write aout that when my head is clear and car is properly aligned!
any comments?!
Aaron
Pink GodziRa
Dousan_PG is offline
Old 04-21-2003, 11:49 PM   #2
mrmephistopheles
mrmephistopheles's Avatar
Now THIS is the GOOD ****! This is what I like to see! Thanks a ton, Aaron!
mrmephistopheles is offline
Old 04-21-2003, 11:52 PM   #3
240Stilo
Junkie
240Stilo's Avatar
240Stilo is an unknown quantity at this point
Send a message via AIM to 240Stilo
I thought the beefyness was just to keep it from breaking, without any performance gain.
-Juan
240Stilo is offline
Old 04-22-2003, 12:01 AM   #4
Dousan_PG
Dousan_PG's Avatar
actually i was told they are desined primarily for lowered cars
they seems can move a lot easier
i heard some bumpsteer would be eliminated, as do the KAZAMA endlinks
that's the purpose of them
ill findout soon after alignment
riding home felt tad smoother, but i'd rather not say becase of lack of alignment and my mind wasnt on my car at that time
i'll know tomorrow driving to work
i go same way everyday and know the road well
also yeah the keepingit from breaking was the PRIMARY reason i bought these. breaking tie rods at teh track SUCKS.
oh time to do install, worked by myself for the most part (my friend pushed brakes for me when i removed and torqued wheels) took about 2 hours. maybe bit more because i ddint count threads and hand to hadn measure it to get a 'driveable" alignment! d'oh!
Aaron
Pink GodziRa
Old 04-22-2003, 12:02 AM   #5
ny_jee
ny_jee's Avatar
ny_jee is an unknown quantity at this point
Bro, did you leave out the spacer for the rod or did you installed that too? The above pix didn't show whether you had them or not. Some pix in your imagestation albums had them. So, what's up? You gonna get more countersteer or not?
-Nicky
ny_jee is offline
Old 04-22-2003, 12:04 AM   #6
Dousan_PG
Dousan_PG's Avatar
DUDE! i put the spacer IN! haha
ill take pics after alignemtn so my toe will be at 0
i'll get pics nex to my friends car so you can see the change
yeah the spacer is in. no doubt
the other reason i bought it
i'll be drifting like haruguchi's (yellow FC) in no time yeah....riiiiight.
Aaron
Pink GodziRa
Old 04-22-2003, 12:04 AM   #7
FRpilot
FRpilot's Avatar
does anyone know the difference between the tein hard tie rods and jics? is there much difference at all besides the 450+ price tag on jic' and $80 for teins? the jic tie rods look nice but at $450 each.. i dunno.. they look kinda beefier from pictures than teins but i dont know if its worth the price
dousan, will the kazama tie rod ends fit on the tein tie rods like cake or the thread pattern is different?? should be the same right? stock..
FRpilot is online now
Old 04-22-2003, 12:07 AM   #8
Dousan_PG
Dousan_PG's Avatar
no!
here's where it gets REALLY complicated (for the dummies outthere--and there's a lot)
basically
s13 tie rods (stock) you use s13 kazama tie rod endlinks
tein hard tie rods you use s14 kazama tie rod endlinks
JIC? F*ck JIC
Aaron
Pink GodziRa
Old 04-22-2003, 12:07 AM   #9
ny_jee
ny_jee's Avatar
Was talking to the other aaron today about the tie rod. My friend bought the JIC rod and still hasn't put them in yet. He mentioned a special tool to take out the rod, but seems like you didn't need any special tools... I am confused now, I assume that it was pretty easy to take out the rod w/o any special tools, correct? Or maybe the JIC rods are different?
-Nicky
ny_jee is offline
Old 04-22-2003, 12:09 AM   #10
Dousan_PG
Dousan_PG's Avatar
nah
tools used?
cresent wrench
needle nose pliers
screwdriver
hammer (mallet-heavy one for ball joint)
19mm wrench
elbow grease and my brain
note that BRAIN USAGE is the most important of all those.
Aaron
Pink GodziRa
Old 04-22-2003, 12:16 AM   #11
NiteKids
NiteKids is not welcome here anymoreNiteKids is not welcome here anymoreNiteKids is not welcome here anymoreNiteKids is not welcome here anymoreNiteKids is not welcome here anymoreNiteKids is not welcome here anymoreNiteKids is not welcome here anymoreNiteKids is not welcome here anymoreNiteKids is not welcome here anymoreNiteKids is not welcome here anymoreNiteKids is not welcome here anymore
Send a message via AIM to NiteKids
Originally posted by dousan36
JIC? F*ck JIC
Hey now...were not talkin about what you think of the people who run it but the products themselfs.
NiteKids is offline
Old 04-22-2003, 12:19 AM   #12
Dousan_PG
Dousan_PG's Avatar
haha i know
thats why idont support JIC
products are great
but the people suck=no support from me or my friends
also JIC is VERY pricey and im extremely interested in WHY
beefier? longer? more adjustabilty?
i'd like to know
nicky-find out!
Aaron
Pink GodziRa
Old 04-22-2003, 12:20 AM   #13
adey
adey's Avatar
adey is an unknown quantity at this point
I have to say though, JIC hard tie rods LOOK different... I don't know if that has anything to do with anything, though. We'll know when NY_Jee's friend puts his rods in. In his car, not in NY_Jee.
Instagram: @SX180HKG
adey is offline
Old 04-22-2003, 12:23 AM   #14
NiteKids
Since JIC is domestically available now I don't understand why their products are SOO expensive. There shouldn't be the "jdm tyte" mark up on them.
NiteKids is offline
Old 04-22-2003, 12:26 AM   #15
ny_jee
ny_jee's Avatar
I've personally seen the JIC rod, it's beefy alrite... Haven't seen the tein rods, so can't make a comparison there. But in relation to my ST sway bars... The JIC rods are about as beefy as the front one, hope that draws a better picture for y'all. BTW, the spacer on the JIC rod is built in. That's about all I know. Are JIC's better, I don't know for a fact that they are. Are they beefy, yes. Is the built in spacer better than a add-on like tein or any other company, I have no clue. My friend hasn't put them in on his car yet, so I can't tell you if it made a huge difference. He was able to use Kazama end links tho. I haven't driven a car w/ tein rods in them(what you doing this weekend, aaron?), so I can't give any feedback on them either. But I'd love to find out tho.
-Nicky
ny_jee is offline
Old 04-22-2003, 12:26 AM   #16
FRpilot
FRpilot's Avatar
whoa.. i just went to browse the for sale and gb forum and just came back to see so many replies.. anyways.. thanks for the info dousan. i mighta made a big ass mistake in buying the wrong super tie rod ends. thats kinda odd.. why do the tein tie rods use s14 tie rod ends? did tein make the thread pattern on their tie rods for s14?
Old 04-22-2003, 12:28 AM   #17
Dousan_PG
Dousan_PG's Avatar
oh that's what richard told me
he has the s13 kazama ones and he was Tein hard rods
also, it is the size. the tein uses s14 size (M14)
s13 is M12 size
Aaron
Pink GodziRa
Old 04-22-2003, 12:30 AM   #18
Dousan_PG
Dousan_PG's Avatar
yeah i'll be in walnut this weekend it seems...water pump replacing d'oh! hahahaha..oh well
wow the jics WOULD be super heavy duty! sweet. but not for 400+ bucks! ouch. well only suckers pay retail so im sure can get it much cheaper, but still, that's laot
sounds good. i can wait to see your friend's, im very interested in them.
Aaron
Pink GodziRa
Old 04-22-2003, 12:35 AM   #19
240Stilo
Junkie
240Stilo's Avatar
Isn't the picture of the Tein rod in comparison to the stock rod up at the start of the thread?
-Juan
240Stilo is offline
Old 04-22-2003, 12:38 AM   #20
Dousan_PG
Dousan_PG's Avatar
he means JIC vs. TEIN vs. STOCK comparisions
Aaron
Pink GodziRa
Old 04-22-2003, 12:39 AM   #21
ny_jee
ny_jee's Avatar
Sometimes pix don't do justice. For example, the pix of JIC rods doesn't justify its price. Seeing it in person(although I still think it's overpriced), it's really well made and beefy. Although aaron took pic of the tein rod next the stock ones, haven't seen them in person, I don't want to jump to conclusion.
-Nicky
ny_jee is offline
Old 04-22-2003, 12:43 AM   #22
FRpilot
FRpilot's Avatar
yea.. the jic pics make the jic tie rods look nice.. it probably is nicer than teins and a little beefier.. but just a little.. i dont think its 4 times nicer to justify for the 4 times difference in price hike? i dunno. they look maybe twice as nice if that.. maybe if they were $200 i'd consider buying them..
Old 04-22-2003, 04:23 AM   #23
johnadams
johnadams is an unknown quantity at this point
so the hard tie rods are basically the same thing as the kazama super tie rod end.
Then what is a pillow tension rod?
thanks for the help
johnadams is offline
Old 04-22-2003, 07:57 AM   #24
Steeles
Steeles's Avatar
Steeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura about
Send a message via AIM to Steeles Send a message via Yahoo to Steeles
good write up Dous! get it aligned and let us know how they are! lol Im sure the first time I bend a tie rod those'll go in! So the Tiens work with the Kazama super end links huh cool.
Keeping it Godzira bishes.
So I murdered another turbo
Steeles is offline
Old 04-22-2003, 08:37 AM   #25
AKADriver
AKADriver's Avatar
AKADriver is a splendid one to beholdAKADriver is a splendid one to beholdAKADriver is a splendid one to beholdAKADriver is a splendid one to beholdAKADriver is a splendid one to beholdAKADriver is a splendid one to beholdAKADriver is a splendid one to beholdAKADriver is a splendid one to beholdAKADriver is a splendid one to beholdAKADriver is a splendid one to beholdAKADriver is a splendid one to behold
nice writeup!
now for a noob question from the guy with 1600 posts - is tie rod breakage a typical consequence of high cornering forces, or is it something that comes from hopping curbs and lots of quick steering wheel movement?
For $160 for the complete setup I might consider these if I ever need to replace tie rod ends anyway... and DEFINITELY if I ever break a tie rod heh
AKADriver is offline
Old 04-22-2003, 08:43 AM   #26
sykikchimp
WOW addicted
sykikchimp's Avatar
sykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura about
Send a message via AIM to sykikchimp
thanks for the help
John.. I've read a few of your posts now.. and you definately need to spend some time with our friend, and yours:
sykikchimp is offline
Old 04-22-2003, 08:45 AM   #27
sykikchimp
WOW addicted
sykikchimp's Avatar
Dousan, I'm most interested in HOW they acheive more countersteer.. You should climb up under there and take some illustrative pics of how the Spacer works.
Old 04-22-2003, 10:40 AM   #28
DoriftoSlut
DoriftoSlut's Avatar
DoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to behold
Send a message via AIM to DoriftoSlut
the spacer allows the "block" or "stopper" part of the inner tie rod to be slighty further away from the rack. This allows a few more degrees bfore they finally contact.
From Mike aka DJElektrique:
"Here.... I made a diagram.
The green color is the spacer.
Notice how the rack will stop moving because
the opposite side (the red colored tie rod joint on the right) hits the rack, keeping it from turning anymore.
Well, add in the green spacers and you just made the rack longer and it will turn that much more before the red tie rod joint hits the rack. Easy as using brake cleaner to clean your hands. "
Here is the full thread on FA: http://forums.freshalloy.com/ubbthre...e#Post67347302
Death Before Dishonor.
www.pinkgodzira.com
www.driftalliance.com
DoriftoSlut is offline
Old 04-22-2003, 10:41 AM   #29
AKADriver
AKADriver's Avatar
Hmmm... I think if you lengthen the inner tie rods (with the spacer) then shorten the outer tie rods (with the normal toe adjustment) you'll alter the steering geometry such that the knuckle moves through more of an arc for a given amount of movement at the rack.
Edit: I guess not... hahaha oh well, all that doodling on the back of a calendar page for nothing!
Old 04-22-2003, 10:55 AM   #30
Dousan_PG
Dousan_PG's Avatar
yeah VRT pic rocks
he'll probably reply on FA about it i posted it there
yeah turning. oh damn. well my toe is off (big time) but let me give example
i do a uturn everyday on my street to leave (its a culdesac)
so usually i end up getting REALLY close to the curb (scuffing tire) or have to make a 3pt turnabout
this morning. i had, i kid you not, a HUGE gap by the time i ended the uturn. the radius was SO MUCH tighter
when i get the alignement fixed, we'll shoot some video (digtal) of my car and my friends (stock setup) doing a uturn on the same street both this way:
full stop against sidewalk
turn to full left
turn
we both will have LSDs too, so already lose some uturning ability.
anyways, just to give an idea. its funny when i turned it all the way to see EVERYTHING (more then before) hahaha..
yeah i'll get more inf. when i crawled under there and turned everything i was lke "AH i see how that spacer works!!"
i am horrible at described. i'll try and get some vid/pcitures...one day. haha..im so lazy. and i hate lying under cars.
i'll get some vid of the crazy turning radius later!
Aaron
Pink GodziRa
