engine temp sensor circuit what/where?
what is the engine temp sensor circuit and where is it located on a 1990 s-13 coupe it came up when i checked the codes
thanks |
![]() Join Date: Oct 2001
Find your where the #1 injector branches off the main wiring harness, and follow the main stem of the wiring harness a few inches forward, untill you see a short branch that goes to a red plug. The red plug is going into the engine temp sensor.
![]() Join Date: Dec 2002
If it is the coolant temp sensor...
There's a little metal clip that slides over the harness securing it to the sensor. The clip is just a thin wire shaped in a 'U'. Just pull the clip off w/needle nose and then the harness should come off fairly easily. Make sure to put the clip back in or the sensor won't read right. -I couldn't figure out why my gauge wasn't working, turns out that I was missing the clip, so the harness didn't seat well enough and I wasn't getting any signal.
Gimme a "A"! Gimme a "P"! Gimme a "C"! What does that spell? CRAP! |
