08-31-2008, 03:39 PM | #1 |
Turbo Oil return line thread problem help!!
Hey everyone look I have a problem and I need some help. If your gonna flame or bash don't even bother cuz it's not worth it. I Take really good care of my 240 it's my pride and joy.....anyway recently I took out the stock exhaust manifold and replaced it with an aftermarket one...being that all the bolts on the back of turbine to manifold are so hard to reach I took out the whole thing turbo and all. everything went great putting it all back in except for the oil return line. I am pretty positive that the hole for the banjo bolt on the block is stripped!! everytime I try and get it in it just pops out. I tried to rethread it and that didn't work...any suggestions help?? cuz I know that this is a pretty big problem and I am about to throw in the towel! any help is greatly appreciated!
08-31-2008, 09:04 PM | #2 |
you are either going to have to change all the hardware to a higher size and rethread it to that pitch n so on.
or you can use a heli-coil but im not sure how it would hold up.. good luck
www.massimopower.com PH: 1(951)402-5386 EM:[email protected] Special Thanks To: www.aeperformance.com www.domospeed.com/blog For Their Continued Support |
09-01-2008, 08:47 AM | #3 |
The hole in the block is oil supply, not return. It's high pressure so unless you retap and seal with a proper fitting it will leak.
09-01-2008, 10:28 AM | #5 | |
i just went through the SAME exact problem with my sr20. stripped the block. steel bolt, aluminum block, steel wins! So i used the advice i found on this very forum. TIME-SERT! i just purcahsed the thread repair kit. NEW TIME-SERT M12 X 1.25 Metric Thread Repair Kit the thread is M12x1.25 for that oil line. so what you do is drill out the hole, thread it to be a step larger, and then thread in the insert and viola, the insert ist he original size of the thread and it's better than new. make sure you use red loc-tite on the threads when you use the insert. this is the best option, and i have co mpleted this and it's not leaking and works great!! |
