08-22-2008, 09:56 AM | #1 |
turbo KA Frontier??
i have a 98 nissan frontier with a ka24de, automatic that i thinking about turboing, i have the stock t-25 from my sr. I figure that i can use an afc neo for fuel and stock sr injectors should be plenty, i dont plan on boosting past 7psi or so. I have a FMIC core that i can use and oil/water lines are no problem.
my main issue is the piping and MAF if you have ever seen the frontiers the MAF is place in the throttle body, so can i set it up as a blow thru? or does anyone know if i can replace the T/b and use an s-14 maf? or can i remove the maf from t/b and put it in a s-14 casing...not sure if this is possible... TIA |
08-22-2008, 11:41 AM | #3 | |
my other problem is connecting the piping to the t/b. the stock air box sit on top of the t/b and is secured with 2 wing nuts and sealed by a rubber ring. does any one have any idea how to connect piping to it?? there isnt enough of a "lip" to clamp a silicone hose to it.. |
