06-24-2008, 12:00 AM | #1 |
SR will NOT crank
Heres the dealio. I've been problem solving on my SR for the last few days. I kept trying to start it and eventually the cranks for slower and slower. I figured it was just the battery and thought nothing of it. I found out that the CAS was busted and so was the ignitor. So I replace the following. Now when I try to start my car nothing happens. This is after charging my battery AND jumper cables on it. I've read that it could be my CAS, but I used to be able to crank it without it being plugged in. It worked before now it wont. Anyone run into this issue before?
Nagasaki Motors Friends help you move. Real friends help you move bodies. |
06-24-2008, 12:48 AM | #2 |
I really dont think it is the cas, Not cranking like not turning over and knowing that it has good voltage means you probably have a bad starter.
please dont tell me that your lights are dimming either becuase if you tell me that like the last guy did, i will slap you.
I was going to, but I can not think of a sig less than 75 characters. |
06-24-2008, 05:39 AM | #3 |
Its not dimming. It worked fine before, I don't see why it would just go out like that. I kinda pulled the power cable to the battery up to make it reach my battery. That maybe it, but im not sure cause it slowly went out. Im going to check all my connections tomorrow.
07-04-2008, 09:50 AM | #8 |
Ahh it was the starter signal. It keeps coming loose. Gatta fix that.
