Old 06-09-2008, 09:28 PM   #1
sicairos_2007
sicairos_2007 will become famous soon enoughsicairos_2007 will become famous soon enoughsicairos_2007 will become famous soon enough
Need Help Please Help Sr Wont Start
Ok i swapped in my sr from another 240 it ran and now that i put it into this hatch back it wont start at all, i already Checked for spark, compression, and fuel, so im really out of ideas now any ideas will be apriciated, also when im cranking the engine it make a pop pop noise once in a while i been messing around with the CAS iv been following the frsport manual and no good so please I need some help been working on it for days now
sicairos_2007 is offline   Reply With Quote
Old 06-09-2008, 09:37 PM   #2
Sil-Eighty SE-K
Sil-Eighty SE-K's Avatar
Sil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfection
Send a message via AIM to Sil-Eighty SE-K
check the coolant temp sensor to the ecu (big one) is it plugged in?
if so prolly timing
Originally Posted by JTunedMotorsports View Post
get off the thread...no one cares...
Sil-Eighty SE-K is offline   Reply With Quote
Old 06-09-2008, 09:41 PM   #3
sicairos_2007
i feel dumb but is that the under the intake manifold? thanks alot for the reply
Old 06-09-2008, 09:52 PM   #4
Sileighty_85
Sileighty_85's Avatar
No its right above the Thermostat housing you will see two sensors next to each other its going to be the Left one (A 2 lead sensor with a square plug)
See the red plug toward the frot right next to the timing chain tensioner?
Thats the one.
Check you ECU for codes also, it will save a lot of trouble shootin. CTS will be Code 13
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 06-09-2008, 10:08 PM   #5
sicairos_2007
Just got back from checking that and it didnt work, just makes the same back fire noise once in a while, iv been messing with the cas timing and wouldent it atleast start if it was close and i know im atleast alittle close.
Old 06-09-2008, 10:10 PM   #6
sicairos_2007
Will Check for codes right now never done it before but iv read a few forums on it
Old 06-09-2008, 10:14 PM   #7
Sileighty_85
well if it were the CTS you would have to replace it in order or it to fix it
Normally when the CTS is bad your engine will run rich and take 15 seconds of cranking to turn on after the engine is warm, but will start when cold
後輪駆動車1番
1986 SR86 - 200ish
Old 06-09-2008, 10:21 PM   #8
sicairos_2007
na im pretty sure its not that just because it dosent start at all...... thanks for the replies man
Old 06-09-2008, 10:40 PM   #9
sicairos_2007
my ecu is shooting a code 55
Old 06-11-2008, 10:34 AM   #10
sicairos_2007
hey thanks for the help everyone I got it to stat now the timing was way off now I guess now I just need to adjust that now because it back fires alot
