Old 05-30-2008, 03:10 PM   #1
ho1ywars
ho1ywars's Avatar
ho1ywars is an unknown quantity at this point
Cant Rev Past 2000 RPM (AEM EMS)
I feel like a freaking idiot. i just put in aem ems and configured all the sensors and stuff, start up the car, and it wont rev past 2000 rpms. checked all the rev limiters, grounds, connectors... im stumped. Any ideas?
redtop sr20det into an s14 if it matters
car ran fine on the power fc before this..
ho1ywars is offline   Reply With Quote
Old 05-30-2008, 04:43 PM   #2
Champz
Champz's Avatar
Champz is an unknown quantity at this point
seems like it could be your maf sensor, check if its properly connected and working
Tooo Sloooow 4 youuuu!
Champz is offline   Reply With Quote
Old 05-30-2008, 05:05 PM   #3
ho1ywars
ho1ywars's Avatar
3.5 bar map sensor and ait, thanks though..
Old 06-01-2008, 07:05 PM   #4
jakerps13
jakerps13 is an unknown quantity at this point
Send a message via AIM to jakerps13
Are you using the startup map aem gives you or a borrowed one? Sounds like a timing issue.
Check
Configure>
ECU setup>
Set ignition
Watch your timing as you rev it through and see what you get. I had the same issue, some reason an old map I had from someone elses car wasn't working for me, so I just started from scratch.
Lower than a pornstar's morals.
jakerps13 is offline   Reply With Quote
Old 06-05-2008, 03:29 PM   #5
ho1ywars
ho1ywars's Avatar
calibrated the timing three times now.. same thing.. anyone else?
Old 06-19-2008, 08:25 AM   #6
auk113
auk113 is an unknown quantity at this point
do you have v. from MAP. if you remember you have to cut one wire on the d-jetro setup for the IAT. make sure that wire is reconected
auk113 is offline   Reply With Quote
Old 06-19-2008, 01:26 PM   #7
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
Post the .cal file
AceInHole is offline   Reply With Quote
Old 04-29-2009, 08:02 PM   #8
jey_253
jey_253 is an unknown quantity at this point
Im having same problem on my rb25 now....weird. Ever figure it out? Factory ecu works fine just the AEM wont rev past 2k
jey_253 is offline   Reply With Quote
