Old 05-27-2008, 05:59 PM   #1
handinpants
FreshColdBeer.com
handinpants's Avatar
Trader Rating: (48)
handinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud of
Feedback Score: 48 reviews
Send a message via AIM to handinpants
revs drop while braking, while coming to a full stop.
So I have a 97 180sx sr20det in my car with a j4 ecu, the idle is set to about 1000 rpms, well maybe 900 rpms. anyways while driving, i need to slow down to stop, so i would put it in nuetral, and slow down to a stop. whether it be in traffic or at a stoplight or sign, Some times, well often the rpm level will drop to 500 or 600 rpm level, and then it will go back to the regular idle speed as soon as i am stopped. but it would dip down. I am not sure what this is. I am running a FMIC, but i am still using the stock recirculating BOV.
any help will do. If i have left out any information that is relevant to diagnosing this problem please ask, and i will reply.
-Thanks
handinpants is offline   Reply With Quote
Old 05-27-2008, 06:00 PM   #2
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
IACV, it's a pretty common problem
Slip Gypsies Blog
not sure if you realize this
Old 05-27-2008, 06:20 PM   #3
makulit054
makulit054's Avatar
makulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of light
yeah, I have a simliar problem. It's an intermittent problem. I've cleaned my IACV with cleaner and it still dips occasionally.
makulit054 is offline   Reply With Quote
Old 05-29-2008, 03:39 PM   #4
handinpants
FreshColdBeer.com
Trader Rating: (48)
What is a IACV?
Old 05-29-2008, 06:36 PM   #5
sbc
sbc is making a name for him/her selfsbc is making a name for him/her self
Intake Air Control Valve
Clean the plunger so that it doesn't seize or stick.
Also check that the spring isn't broken.
And get yourself an FSM.
sbc is offline   Reply With Quote
Old 05-30-2008, 04:50 AM   #6
handinpants
FreshColdBeer.com
Trader Rating: (48)
where on the engine can i find this valve?" pictures?
Old 05-30-2008, 10:08 AM   #7
flip3d
flip3d's Avatar
flip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond repute
Send a message via AIM to flip3d
+1 for Idle Air Control Valve.
It's on the intake manifold in between the 2nd and 3rd runners. Has a screw on top. You cant miss it.
Edit: Thats where it is on the S13 SR. Not sure about the 180 SR.
flip3d is offline   Reply With Quote
Old 05-30-2008, 10:16 AM   #8
EDacIouSX
EDacIouSX's Avatar
Trader Rating: (53)
EDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfection
Feedback Score: 53 reviews
i think basically black and red tops are identical engines aren't they?
