Old 12-19-2001, 12:29 PM   #1
burgy240
burgy240's Avatar
burgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to all
Send a message via AIM to burgy240 Send a message via Yahoo to burgy240
I cleaned it with a throttle body cleaner from NAPA($2.13).  just removed the air intake tube and the rubber hose clamped to the throttle body.  sprayed the cleaner and really lightly with a toothbrush rubbed the crap off inside and on butterfly.  Very easy don't ever let the Dealer charge you to do this maintnence.  I will let you know that you're gonna want to remove the two hoses attached to the air intake tube and maybe unclamp the one from its holding clamp along side of the rubber tube attached to the throttle body.  Let the engine sit five minutes and then start it up.  will run real rough for about 30 seconds. I just pressed the gas to help move it along.  Very easy!!
burgy240 is offline   Reply With Quote
Old 12-19-2001, 12:50 PM   #2
whateverjames
whateverjames's Avatar
whateverjames has a little shameless behavior in the past
Send a message via AIM to whateverjames
notice any (re)gain in performance? i'm thinking of doing this
whateverjames is offline   Reply With Quote
Old 12-19-2001, 02:23 PM   #3
IceTekGuy
IceTekGuy is an unknown quantity at this point
i did that, and got about 50HP!!!!!!!!!!!
just kiddin, it should make some difference, cause it lets teh air slide along better with no restriction...
im gonna have mine polished, or do it myself... but that is good to do too
IceTekGuy is offline   Reply With Quote
Old 12-19-2001, 02:44 PM   #4
burgy240
burgy240's Avatar
Well, I noticed the the rpms rev up smoother and overall engine response seemed slightly better too.  My throttle body really needed cleaning though.  First time it was cleaned since production in 95'(65K miles).
Old 12-19-2001, 04:48 PM   #5
IceTekGuy
suprisingly mine was pretty #### clean for a freakin 12 year old car, i got the 89 240s, now i got an s14 SR and i had to clean the shit out of that one.
Copyright ©2000 - 2021, vBulletin Solutions Inc.
