Old 05-18-2008, 08:43 AM   #1
nismo tuned s14
nismo tuned s14's Avatar
nismo tuned s14 is making a name for him/her selfnismo tuned s14 is making a name for him/her selfnismo tuned s14 is making a name for him/her self
turbo wastegate question
i have the greddy (mitsubishi) TD06SH-20G turbo with the infamous small wastegate. i have the greddy turbo kit for the KA. i cut out the restrictor in the turbo inlet pipe and i also have an after market downpipe which aids in the boost creep. the stock kit is only supposed to boost around 8 PSI, but now it holds about 14 PSI every time it's at wide open throttle (without the boost controller hooked up). i recently bought a boost controller, and i cant control the boost. the boost controller was installed and set up properly, but the boost will go way higher than what it's set at every time. it caused my ECU to throw a knock sensor code that i cant get rid of.
my question:
i've looked around at different internal wastegates, but i dont know which one will fit on my turbo. which one do i need? can i just replace the spring?
i searched the web without any luck. i dont want to go with an external. i need a wastegate that bolts up and will take around 350hp daily. also if anyone knows how to get rid of that damn knock sensor code that'd be helpful. (i'll probably just start a new thread later)
nismo tuned s14 is offline   Reply With Quote
Old 05-18-2008, 09:07 AM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Im not familiar with the KA-T kit but is it internal wastegated or ext wastegated??? If its internal and its the small flapper opening thats causing it to spike, take the turbo off and mill the hole larger. I had a greddy T518Z and it had an adjustable internal wastegate, you should be able to extend the rod more to give the flapper some slack.
CLICK HERE!!!
Old 05-18-2008, 10:10 AM   #3
nismo tuned s14
yeah its an internal wastegate. how do i know if its the flapper causing the spike? it's actually not a spike because boost never falls back where it needs to be, it just holds it.
so if i extend the rod it wont hold the flap open?
Old 05-18-2008, 03:45 PM   #4
fliprayzin240sx
The way adjustable internal wastegates work is that the shorter the rod, the longer it stays shut, so the higher the boost level before it opens up. You extend it a bit longer to lower the boost and effectively letting it open up sooner.
CLICK HERE!!!
