Old 05-17-2008, 12:45 PM   #1
jackjack
jackjack's Avatar
car died on highway last night
alright, so i'm doing about 70mph (keeping up with traffic) last night on the highway. first thing i notice is my radio shuts off (never did that before). then a couple seconds later my engine completely cuts out. i coast over to the shoulder and notice smoke coming out of the engine bay. everything gets power, but engine will not crank over. oil level is normal. coolant level is normal. i've got 200,000 miles and it NEVER gave me a problem (only things i've had to change.... clutch and alternator) till now.
any ideas?
Old 05-17-2008, 12:59 PM   #2
gotta240
what did the smoke smell like? Oil or plastic?
I'm guessing its electrical.
Old 05-17-2008, 01:03 PM   #3
osal
osal is making his/her stupidity well-knownosal is making his/her stupidity well-knownosal is making his/her stupidity well-knownosal is making his/her stupidity well-known
i say alternator....try jump cables to start it....then after a while disconect ...if the car dies after some time it means the alternator is not charging the battery
osal is offline   Reply With Quote
Old 05-17-2008, 01:27 PM   #4
jackjack
jackjack's Avatar
^alternator was brand new and charging fine. according to the meter anyway.
couldnt tell. it was too dark and windy. checked the wiring though. everything is fine.
Old 05-17-2008, 02:06 PM   #5
berz
berz's Avatar
berz is close to perfectionberz is close to perfectionberz is close to perfectionberz is close to perfectionberz is close to perfectionberz is close to perfectionberz is close to perfectionberz is close to perfectionberz is close to perfectionberz is close to perfectionberz is close to perfection
maybe the battery arked to something but it happened to m z cuzz the battery's side post terminals were too close to the engine bay.. just a thought
berz is offline   Reply With Quote
Old 05-17-2008, 06:29 PM   #6
s13Carlo
s13Carlo's Avatar
s13Carlo has a spectacular aura abouts13Carlo has a spectacular aura abouts13Carlo has a spectacular aura abouts13Carlo has a spectacular aura abouts13Carlo has a spectacular aura abouts13Carlo has a spectacular aura about
Send a message via AIM to s13Carlo
sounds like your alternator over heated
s13Carlo is offline   Reply With Quote
Old 05-17-2008, 06:35 PM   #7
jinesz32
jinesz32's Avatar
jinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to behold
Send a message via AIM to jinesz32
same thing happened to my gf the other day, but no smoke.
car woulnd't crank anymore. they pushed started it, she drive it acouple miles right before she got home, radio turned off, then engine turned off, she got her battery replaced and everything was fine, i thought it was her alternator, but they got a new battery, left it running for about 30 minutes and everything seem fine, they took it to a shop to let them check the alternator and it seem to be fine as well, the car is running fine now i guess? it made it 200 miles from SD to here just today.
gl with your problem, try swaping out batterys with a buddy of yours
jinesz32 is offline   Reply With Quote
Old 05-17-2008, 08:52 PM   #8
flip3d
flip3d's Avatar
flip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond repute
Send a message via AIM to flip3d
Check your battery terminals. My car did the same thing. Terminal was loose.
flip3d is offline   Reply With Quote
Old 05-17-2008, 10:05 PM   #9
bardabe
bardabe's Avatar
and your alternator fuse check that too.
Review Thread
bardabe is offline   Reply With Quote
Old 05-17-2008, 10:11 PM   #10
mifesto
mifesto is just really nicemifesto is just really nicemifesto is just really nicemifesto is just really nicemifesto is just really nicemifesto is just really nicemifesto is just really nicemifesto is just really nicemifesto is just really nicemifesto is just really nice
i dont think you sufficiently tested the life of your alternator. bring it to a shop and they can tell you in a split (and even rebuild it often). Osal's advice is also good. car does not require the battery to idle, just to crank the starter.
this is a shot in the dark too but hows the grounding on your alternator?
mifesto is offline   Reply With Quote
Old 05-17-2008, 11:21 PM   #11
DataXUnknown
Trader Rating: (30)
DataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfection
Feedback Score: 30 reviews
maybe somthing is shorting out the alternator? if you have any gauges that have the steel braided line, they might be touching the alternator and shorting it out. an easy way to fix it is to just wrap the line in cloth tape or electrical tape where its touching. if the smoke doesn't have a distinct smell, it usually means electrical.
thats what happened with me, except it happened to the starter.
DataXUnknown is offline   Reply With Quote
Old 05-18-2008, 11:32 AM   #12
i need tires
i need tires's Avatar
i need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to all
Send a message via AIM to i need tires
this same thing happened on my buddies mercedes, and it ended up being his power wire from the battery to the harness had fried
i need tires is offline   Reply With Quote
