Old 05-07-2008, 10:59 PM   #1
Zero_X
Zero_X's Avatar
Zero_X is a splendid one to beholdZero_X is a splendid one to beholdZero_X is a splendid one to beholdZero_X is a splendid one to beholdZero_X is a splendid one to beholdZero_X is a splendid one to beholdZero_X is a splendid one to beholdZero_X is a splendid one to beholdZero_X is a splendid one to beholdZero_X is a splendid one to beholdZero_X is a splendid one to behold
start up problem....
when i start my car..it starts and then rpm drops all the way down and engine seems like it'll die..most of the time it dies...i have to rev it to keep it going...drives fine when driving.......just only start up..rpm drops and car dies...i check the MAF and clean throttle body...if anything...else..any suggestions???
Last edited by Zero_X; 05-15-2008 at 09:49 PM.. Reason: better description of problem.
Zero_X is offline   Reply With Quote
Old 05-15-2008, 09:50 PM   #2
Zero_X
Zero_X's Avatar
any suggestions anybody?
Old 05-15-2008, 10:13 PM   #3
Sileighty_85
Sileighty_85's Avatar
What engine?
Could be lots of things
Vacuume leak, timing off, bad plugs, Bad distrubutor, TPS, Coolant Temp Sensor
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 05-15-2008, 11:09 PM   #4
playastarkz123
playastarkz123's Avatar
playastarkz123 has a spectacular aura aboutplayastarkz123 has a spectacular aura aboutplayastarkz123 has a spectacular aura aboutplayastarkz123 has a spectacular aura aboutplayastarkz123 has a spectacular aura aboutplayastarkz123 has a spectacular aura about
did u check the ground for you maf?
playastarkz123 is offline   Reply With Quote
Old 05-15-2008, 11:43 PM   #5
Zero_X
Zero_X's Avatar
its 96 s14 ka24de..about 166XXX miles on it..no i havn't check for ground on my maf yet...but thanks..i'll check it out..
Old 05-15-2008, 11:45 PM   #6
!Zar!
!Zar!'s Avatar
Sounds like your Coolant Temp Sensor.
Old 05-18-2008, 02:32 AM   #7
Zero_X
Zero_X's Avatar
thanks..i'll check my CTS..thanks..
Old 05-18-2008, 02:36 AM   #8
seto_s14
seto_s14's Avatar
seto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud of
Send a message via AIM to seto_s14
eh, that's super common. mine does it too.
it's not that big of a deal. think of it as a theft-deterrant lol
try cleaning your iacv valve
my ninja
seto_s14 is offline   Reply With Quote
Old 05-18-2008, 02:42 AM   #9
Zero_X
Zero_X's Avatar
lol ok..i'll clean it..yea..lol no check engine light or nothing so i thought it was no biggie..but just got worried..
Old 05-20-2008, 05:17 PM   #10
Zero_X
Zero_X's Avatar
to clean the iacv how do u take it out..seems like u need a philips screw driver but there is not enough room...jw....
Old 05-20-2008, 09:58 PM   #11
seto_s14
seto_s14's Avatar
http://www.zilvia.net/f/showthread.php?t=96967
the pix are gone but try ur best
my ninja
Old 05-20-2008, 11:48 PM   #12
Zero_X
Zero_X's Avatar
thanks no pics but still helpful
