Old 05-04-2008, 05:50 PM   #1
jh3xp
jh3xp has a brilliant futurejh3xp has a brilliant futurejh3xp has a brilliant futurejh3xp has a brilliant futurejh3xp has a brilliant futurejh3xp has a brilliant futurejh3xp has a brilliant futurejh3xp has a brilliant futurejh3xp has a brilliant futurejh3xp has a brilliant futurejh3xp has a brilliant future
Ebrake problem
So today I parked my car and when i pulled my ebrake I hear a snap. Then my ebrake handle was all flimsy and could be pulled very easily and wouldnt stay up. My first thought was that my cable broke? But then I looked at the rear pads and they werent releasing. Do the pads usually stick when ebrake cables snap? or is my cable not snapped and something else happened. Any help would be nice thanks.
jh3xp is offline   Reply With Quote
Old 05-04-2008, 06:00 PM   #2
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
sound like your cable broke man. not really sure though, i've never had an e-brake problems.
https://instagram.com/e_lemonation/: @e_lemonation
Old 05-04-2008, 06:09 PM   #3
JVD
JVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfection
I'm assuming cable...
E-brake has nothing to do with your calipers/pads. It's a drum brake inside the rear rotor.
JVD is offline   Reply With Quote
Old 05-04-2008, 06:19 PM   #4
Sileighty_85
Sileighty_85's Avatar
What???
That would be true if he had the Z32 Rear Brake conversion on it.
But im thinking he doesnt. when you pull the E-brake handle it pushes the piston out of the rear calipers and clamps the rotors
but to answer the OP Question if the cable snaps then the Ebrake will release and not hold
so yes you sanpped your E-Brake cable
you can still drive it, the rear calipers will still clamp when the brake pedal is pressed
just dont park on a hill
More than likely it this cable labeled "Front Cable" in the pic
http://www.flickr.com/photos/7727712...51057/sizes/o/
Ignore the red circles
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 05-04-2008, 06:31 PM   #5
JVD
Originally Posted by Sileighty_85 View Post
What???
Ahahaha. My bad. Used to reading a million Z32 threads. Not paying attention.
Thanks for clearing it up for this kid. He would have been a little lost I think.
Old 05-04-2008, 06:49 PM   #6
jh3xp
In that case does anyone have a write up of how to swap the ebrake cable?
And thank you all for you help.
Old 05-04-2008, 07:45 PM   #7
projectRDM
projectRDM's Avatar
Do you really need one? Clip on each end, one bolt on the subframe, one on the chassis. Completely self explanatory.
FORMERLY R240NA
Old 05-04-2008, 08:06 PM   #8
jh3xp
okay thank you. I just didnt know what was involved sorry.
