Old 05-03-2008, 02:34 AM   #1
kingkilburn
Philosopher King
kingkilburn's Avatar
kingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfection
KA KA sounds like a lawn mower
Long story short I had some head work done(mostly removal of a broken stud). After I put it back together it sounds like a lawn mower and is loud as fuck. I took it apart three times to try again but got the same results.
When it starts it revs up then sputters out. It will only keep going on it's own for about a minute and like I said, it is substantially louder than normal.
What do you guys think the problem is?
G O L D E N B E A R R E P U B L I C
kingkilburn is offline   Reply With Quote
Old 05-06-2008, 09:23 AM   #2
posdrift240
posdrift240's Avatar
posdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymore
when you removed the head did you get it re-surfaced? with a new head gasket? Intake/ Exhaust?
posdrift240 is offline   Reply With Quote
Old 05-06-2008, 11:51 AM   #3
kingkilburn
Philosopher King
Yes
msglength
Old 05-07-2008, 06:22 PM   #4
RiceKidd
RiceKidd has made poor choicesRiceKidd has made poor choicesRiceKidd has made poor choicesRiceKidd has made poor choicesRiceKidd has made poor choicesRiceKidd has made poor choicesRiceKidd has made poor choices
hm.... when i had that happend to me i changed my oil and i was low and than added more oil and let it idle for a while and went away.
check your oil.
RiceKidd is offline   Reply With Quote
Old 05-07-2008, 10:32 PM   #5
kingkilburn
Philosopher King
It's def not the oil. I took it to a mechanic to get the timing set, all they said besides the timing being of was that the intake gasket was bad. I guess that would contribute to the sound I was getting.
I update when I get the car or more info.
Old 05-08-2008, 08:09 PM   #6
kingkilburn
Philosopher King
It turns out the problem was stacked intake gaskets. The gasket that joins the two sections of the intake was not properly scraped before a new one went down.
That will teach me to let others help on critical parts of my car.
