05-02-2008, 10:37 AM | #1 |
Interior Brake light issue
Hey fellas, This started couple days ago. When I went to fontana speed way. Well the brakes all wow, pads are ok, fuild is ok. But when I drop my e-brake my light does not go off. Is there a sensor somewhere I can Check? Thank for you time.
05-02-2008, 10:55 AM | #2 |
Low brake fluid. Refill and check for leak or low pad thickness. If nothing else works, check the brake lever switch or for broken wire going to the lever or the master cylinder reservoir.
05-02-2008, 11:05 AM | #4 |
maybe the sensor into the BMC is like suuuuper dirty..i cleaned mine and it helped...but def check that fluid.. ^ and like awesomenick said.
lol i cant believe i just said that HAHAH just like he said there is a little connector deal see if it clipped of or waht not |
