11-11-2002, 10:41 AM | #1 |
Well, I am back after an extended period of time. (no broadband, then crashed computer)
It is good to be back. First, Does anyone know if a helical type LSD from an s15 will fit in an s13? Second, with all this discussion about LSD's, I checked out www.howstuffworks.com and found that they have an excellent description on differentials including animations which simplify the process. Check out: www.howstuffworks.com/differential.htm ADD: I just found out that a helical LSD is the same as a Torsen LSD, Torsen being a name brand. Here are some cool pics of LSD's http://www.marklines.com/en/presen/tochigifuji.jsp
"It's not how you stand by your car, it's how you drive your car. You better learn that." Winning comes only after preparation. If you don't prepare so you can win then you are inadvertantly preparing to lose. Drive it like you stole it! |
11-11-2002, 10:54 AM | #2 |
Some problems I can see:
The S15 uses 5-bolt output shafts (like a 300ZX or early J30). The 240SX uses 6-bolt output shafts. You might be able to use your open diff output shafts, you might be able to use VLSD output shafts, I don't know. The S15 diff carrier mounts to the subframe via bushings (again like a 300ZX, J30, S14). Same issue/fix as any of those diffs in an S13 chassis, you'd need to replace the front bushings with something solid and swap rear covers. The S15 diff carrier has an ABS sensor (like J30, S14). Might be a problem, might not, depends on how much play you have in your driveshaft. Lastly, it has a ratio ca. 3.7:1... it's gonna toss off your speedometer and slow you down. Of course you could get the helical diff itself and install it in an S13 carrier with your stock gears eliminating all the problems except the output shaft issue. |
11-11-2002, 11:21 AM | #3 |
OK, I found an LSD. But this one comes without the case. Does that mean that all I need is to reuse my case/outputshafts/etc. to make it work.
The owner says that it is out of a JDM 93 Silvia K, s14 chassis. I think that it has to be an s13, but would like other input. Thanks, Chuck here is a link to the picture of the part: http://www.valley.ne.jp/~sirogane/1573b.jpg
11-11-2002, 12:15 PM | #4 |
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (cmathews @ Nov. 11 2002,12:21)</td></tr><tr><td id="QUOTE">OK, I found an LSD. But this one comes without the case. Does that mean that all I need is to reuse my case/outputshafts/etc. to make it work.
The owner says that it is out of a JDM 93 Silvia K, s14 chassis. I think that it has to be an s13, but would like other input. Thanks, Chuck here is a link to the picture of the part: http://www.valley.ne.jp/~sirogane/1573b.jpg</td></tr></table><span id='postcolor'> yes it should bolt in. the carrier doesnt matter it'll fit into any of the R200 pumpkins. the pumpkins are all a little different but will all work cross chassis. I have my LSD in an S13 pumpkin in my S14. swapped rear covers and was golden. but yes the S15 helical carrier is swapable into the S13 pumpkin. swomeone in Atlanta I know is going to do just that
Keeping it Godzira bishes. So I murdered another turbo |
11-11-2002, 12:26 PM | #5 |
That's a viscous LSD, just so you know.
It will fit in your pumpkin. You can't use your output shafts, however. You need VLSD output shafts. |
11-11-2002, 01:15 PM | #6 |
So, I think I have this worked out now.
1. the picture shows just the carrier 2. the case is the pumpkin, and I have the one I need already on the car. 3. the output shafts needed are neither pictured with the new lsd, or already included with the non-lsd diff, so I will need to purchase new output shafts from nissan. If I am wrong, please correct me. If I am right, this is pretty simple and I will soon be sporting a slightly used viscus lsd, rather than the helical lsd from the s15 that I found. It is not appropriate for my purpose (light autocross, must be driveable in snow-- see reference to www.howstuffworks.com). Thanks, Chuck
