04-03-2008, 09:25 PM | #1 |
boost without anything connected to the wg?
hey fellas was crackin-lackin anyways hears my question how much psi am i boosting on a stock sr when i have nothing hooked up to my waste gate with a front mount? and i have a stock fuel pump so if the boost is more than stock what can happend?
04-03-2008, 09:28 PM | #2 |
Man w/ CTSV & a Car Seat
You go buy a new engine...how about that?
Not running a line to the wastegate so it doesnt open at 7 psi like its supposed to, thats a great idea. God knows when it opens, another great idea. Not adding any fuel to the unknown amount of air going into the engine, and all this on stock 240sx fuel pump...absolutely classic... |
04-03-2008, 11:47 PM | #5 |
its an very easy answer.
If nothing hooks up to your wastegate, that means your wastegate is always close. And you will keep boosting up with no limit until your engine gets fucked up. And then you will be looking at new engine or some parts of the engine. and then you will go check my for sale thread and buy my parts. |
04-04-2008, 12:19 AM | #7 |
Please do your research before posting a stupid question like this one. how hard is to T fit a 3' vacuum line to the wasted gate. Where do you get your information man you need to star looking for another source.
04-04-2008, 03:00 AM | #8 | |
That simple enough? |
04-04-2008, 03:00 PM | #10 |
No compression in cylinder 3, most likely, because of a blown ring land, most likely. I tested my T25 back in the day with no wastegate vacuum (accidentally, forgot to hook it back up once), and at about 1/3 throttle and 4k rpm, boost was around 20psi. That's when I shut it down and figured out what the problem is. I can't imagine what that did to your turbo if you floored it.
It's for sure that you need an engine rebuild though. Probably a new turbo as well.
04-04-2008, 04:08 PM | #11 | |
you answered your own question
Why would you run no Vac. line to the W/G Im sorry dude but your a perfect example on why noobs dont need to drive turbo'd cars. Although the machine shops and parts dealers love you
04-04-2008, 05:38 PM | #12 |
My wastegate crapped out on me and right now I have it unplugged. I'm basically staying out of boost completely until I get a new wastegate. I would suggest the same to anyone who chooses to run without it connected.
04-04-2008, 05:52 PM | #13 | |
sure you'll have almost no boost but its safer than tryin not to hit boost
04-04-2008, 06:23 PM | #14 |
Your foot is your boost controller at the moment. Be sure to get into 5th gear and do a long highway pull... foot to the floor for best results.
Good luck! EDIT: Oh, seems I was too late. Your motor is already blown. |
04-05-2008, 12:06 PM | #15 | |
T25
T25 boosting 20lbs never heard of that. but anyways do you think its the same cyllinder thats has no comprerssion is making the knocking? |
04-05-2008, 12:09 PM | #16 | |
n**** you started some day to so shut up we all make mistakes |
04-05-2008, 12:35 PM | #17 |
It doesn't matter where the knocking comes from. Knocking means you've probably got a spun bearing, and low/no compression usually means a blown/burned piston. You have to take that motor apart and rebuild it.
04-05-2008, 01:01 PM | #19 |
simply wow....... hey guys if i take a spark plug out of my motor just so it sounds like a wrx will i hurt my motor?
****yes this is sarcasm***** |
04-05-2008, 01:57 PM | #20 |
^^^ sadly enough, you fail at sarcasm too. Taking out a spark plug will get fuel (and possibly some oil) all over your valve cover, but doesn't hurt anything.
AJ please end this thread... pleaaaase.
04-05-2008, 02:04 PM | #21 |
actuallywhen spark plug number 3 didn't work it did sound like an ej20. and also no spark plug would also mean raw fuel being injected into the cylinder and last i checked raw fuel doesn't act as a very good lubricant
04-08-2008, 01:28 PM | #25 | |
I did my research I sourced all the common SR problems and replaced/upgraded them, Im talkin FSM's and Zilvia I searched this Site for 6 months while I built my engine in my living room and learned from everyone elses mistakes. I ran every line and plugged everything in the way it should go, If I had a question on somthin I looked it up. I didnt crank my engine until I was sure I had everything the way it should go, which was done on the first day and DD on day 2. But then again I was able to personally pull and bring my SR back with me from Okinawa, So I was able to take pics of where everything went to and marked everything's location. All im saying is you didnt do your research.
04-08-2008, 01:31 PM | #26 |
No its not good, Its call Cylinder Wash, fuel washes oil off the cylinder walls and causes the rings to scrape the Cylinder Walls with out lubrication which kills the piston rings = Loss of Compression
04-11-2008, 05:31 PM | #27 | |
04-12-2008, 12:28 AM | #28 |
Lol good point on the cylinder wash.
On a more "my IQ is over 80" point, who doesn't know what a motor sounds/feels like on 3 cylinders? Who would actually drive said motor on 3 cylinders to the point where it spun a bearing? Not saying that Bardabe's not the man when it comes to motors and all, but that's a pretty far-off reason to need a rebuild.
04-12-2008, 11:33 PM | #29 |
way to go ship ur engine to me and ill rebuild it for you for free if you send me all the new parts and pay for shipping both ways
