Old 03-23-2008, 03:13 PM   #1
its a kia
its a kia is making his/her stupidity well-knownits a kia is making his/her stupidity well-knownits a kia is making his/her stupidity well-knownits a kia is making his/her stupidity well-knownits a kia is making his/her stupidity well-known
blueish white smoke
i searched and didnt find anything pertaining to my scenario
out of the exhaust during a cold start and warming up, smoke is billowing out, cant tell what it smells like, my nose is clogged from a cold right now, once the car is warmed up i will drive it and it i will smoke for about one minute then it will stop, just had head work done, bc cams, springs, retainers and new valve seals and cometic headgasket
head work was done about 3 weeks ago and it started smoking about a week ago, its worse than a week ago
could this be the valve seals, piston rings, headgasket?
thanks
its a kia is offline   Reply With Quote
Old 03-23-2008, 06:40 PM   #2
sideways7
sideways7 is a name known to allsideways7 is a name known to allsideways7 is a name known to allsideways7 is a name known to allsideways7 is a name known to allsideways7 is a name known to allsideways7 is a name known to allsideways7 is a name known to allsideways7 is a name known to allsideways7 is a name known to allsideways7 is a name known to all
Blueish smoke means you're burning oil.
sideways7 is offline   Reply With Quote
Old 03-23-2008, 07:08 PM   #3
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
sounds like there's some sort of clearance issue with the cylinders and the walls. as metal heats up it expands which may explain why the smoke goes away after it's been thoroughly warmed up. Correct me if i'm wrong.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 03-23-2008, 07:11 PM   #4
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
youre burning oil. your piston rings might be fukkked
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 03-23-2008, 07:18 PM   #5
jskateborders
jskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond repute
Send a message via AIM to jskateborders
How did you search... by posting this thread?
That by the way, is the same as like 15 other threads
Blue means oil
White means water/coolant
black means gas
which means.... you are burning oil
so...
http://www.zilvia.net/f/search.php
"I am Norwegian, and are not familiar with your urban words :P"
jskateborders is offline   Reply With Quote
Old 03-23-2008, 08:25 PM   #6
its a kia
but nothing about it going away, seemed like it was constant smoke in the other threads, but thanks for the info
