Old 03-13-2008, 11:46 AM   #1
Mikey213
Trader Rating: (-1)
Mikey213 is just really niceMikey213 is just really niceMikey213 is just really niceMikey213 is just really niceMikey213 is just really niceMikey213 is just really niceMikey213 is just really niceMikey213 is just really niceMikey213 is just really nice
Feedback Score: -1 reviews
weird overheating problem
When i drive my temp guage would rise all the way to the top and stay there for about a min then itll go back down to normal temp... then itll rise up again the next 20-40 min and over n over I don't know what the problem is. =0( As it overheats i notice the rpms raise up just a mm above 1,000rpm I have a koyo rad, nismo thermostat, and new belts. Is it the water pump? i have a cheap ass autozone radiator cap.... or could it be that my lower chain guide is cracked and itll randomly slows down the chain causing it to heat up a bit?? i hope it's etheir of those and NOT MY HEAD GASKET =0(
Mikey213 is offline
Old 03-13-2008, 12:06 PM   #2
Skaterjunky8
Skaterjunky8 is on the path to ruinSkaterjunky8 is on the path to ruin
could be a glitchy temp sensor. check that out first. or let it sit and see if it actually over heats while the gauge is in the red
Skaterjunky8 is offline
Old 03-24-2008, 12:04 PM   #3
Air
Air is an unknown quantity at this point
sounds like a headgasket to me. I had this issue with my car and couldnt figure it out. It wouldnt overheat at idle, but as soon as i put load on the motor it began to overheat.
Air is offline
Old 03-24-2008, 12:25 PM   #4
98s14inaz
98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection
Ka's are temperamental. First check your oil and water and make sure they aren't contaminated with each other (water/coolant + oil = chocolate milk...also look to see if there are any oil rainbows in your water, good indication if you are about to have a hg go.). Next do a compression check and leak down test. Then check the sensors. Water pump and or thermostat could be a likely candidates as well. Lastly check you radiator for build up or just replace it all together. 240 owners are plagued with what previous owners did or didn't do to their cars.
-Retired
98s14inaz is offline
Old 03-24-2008, 01:25 PM   #5
Sir
Sir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud of
if it goes up than down shortly after, its just an air bubble.
you could use something like this to make your life easier.
http://cgi.ebay.com/ebaymotors/Mityv...3286.m20.l1116
Originally Posted by drift freaq View Post
I suggest you shut the fuck up.
Sir is offline
