Old 02-20-2008, 08:04 AM   #1
Yami
Yami is an unknown quantity at this point
valve timing(vvt)
does anyone know what is the correct time the vvt turns on and when does it turn off?
Yami is offline   Reply With Quote
Old 02-20-2008, 08:26 AM   #2
SlideWell
SlideWell's Avatar
SlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfection
VVT is toyota. VTC is nissan. there is so much crap out there on VTC, but heres a link with actual dynos of VTC engaged and disengaged. i just did a simple google search
http://forums.freshalloy.com/showthread.php?t=152013
SlideWell is offline   Reply With Quote
Old 02-20-2008, 10:03 AM   #3
sean350z
sean350z's Avatar
sean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of light
ON when between 1,050 - 5,700 rpm and in gear (if you have a working Neutral Position Switch)
OFF when below 1,050 or above 5,700 rpm or when in Neutral.
sean350z is offline   Reply With Quote
