Old 02-17-2008, 03:36 AM   #1
DaPCWiz
DaPCWiz's Avatar
DaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond repute
Send a message via AIM to DaPCWiz Send a message via MSN to DaPCWiz Send a message via Yahoo to DaPCWiz
How to: repair S14 hvac that doesn't light up
So I finally got tired of my S14 hvac that doesn't light up properly / lights up whenever it feels like it. This seems to be a problem with many 90's nissans. Both my S14s have had this issue and so did my G20. This guide may apply to other cars, but it is specifically for the S14.
Some people will find replacement bulbs, throw them in there and hope for the best. I have read up on this and seen mixed results with this process. I believe there is some kind of failure within the circuit board itself in many cases and the bulb is not the culprit. For this reason, I decided to wire in my own LEDs and power them independently of the circuit board. This way I could be sure they would always get the power they need.
The results weren't as good as I would have liked and I will use this knowledge to try this process again when i get time. I will update the guide when I get better results.
Materials Used:
  • Spare HVAC
  • 3x Super Bright 5mm red LEDs from my local electronics shop
  • 3x 500ma resistors
  • soldering iron
  • solder
  • glue gun
  • heat gun
  • head shrink / electrical tape
  • spare wire
  • patience
NOTE: not covered in this guide is disassembly and assembly of the hvac. I will take pictures next time I do it. Carefully analyze the HVAC and undo all visible screws / tabs (pawls?) that you can see. With some fiddling it should easily come apart. Remember or write down how you took it apart, I didn't do this and broke some stuff putting it back together - so be careful. I'm not responsible if you destroy your hvac in this process.
Step 1
Solder the resistors to the positive leads on the LEDs. The positive lead is the longer one.
Step 2
Solder a positive wire to the other end of the resistor. Solder a negative wire to the negative LED lead. Cover exposed metal with heatshrink. note I ran out of the correct size heatshrink when doing this project, so I used stuff that's a little too big in places. You shouldn't do that.
Step 3
Hot glue the LEDs to the where the 3 lights were previously. You will notice that 5mm LEDs fit perfectly in the holes. You can see the positions of the LEDs in the third picture. Please note that I ran the wiring in those pictures towards the top of the circuit board. That is WRONG as you will not have clearance if you run them like that. You should run them towards the bottom.
In the above pictures I have rerouted the wiring so that it will fit once I close everything back up.
Step 4
Splice all the positive wires. Splice all the negative wires. Add some extra wire to these splices so you can route them to a power source in the car later. Cover splices with electrical tape or heatshrink.
Testing the LEDs
Step 5
Install hvac, and run wiring. You can run the positive wire to a red/blue wire behind you dash. This is the interior lighting circuit. Black should run to a ground point.
Here are some pictures of my install. As you can see LEDs don't deliver as even a light spread as normal bulbs. On version two I may replace the right bottom LED with a standard 5mm bulb and see how I can power it. The lighting in this section (slider / ac button) is very uneven. The blue/red for temperature doesn't look good either. I will also consider replacing the right top LED (all the air direction buttons) with a wide angle LED since it ALMOST lights up everything well but not quite. The left LED seems to work well (fan speed settings)
lighting at dusk
lighting at night
Its fairly close to the intended effect, but not quite what I was looking for. I will try again soon. If anyone has any suggestions I'm open to listen. Stay tuned for v2 when I find a day that I'm bored and decide to work on the hvac again! Excuse any grammatical errors / typos as its 5:30 am and I haven't gone to bed yet. I should really go to sleep soon
http://blog.dapcwiz.com
DaPCWiz is offline   Reply With Quote
Old 10-14-2008, 07:16 PM   #2
DaPCWiz
DaPCWiz's Avatar
Whoa, I forgot I made this thread... found it by accident while searching for something else.
Update from a post I made on another forum a long time ago:
1x 1500 mcd / 120* flat tipped white LED (a/c & temp)
1x 1200 mcd / 120* flat tipped red LED (directions)
1x 1000 mlm / 360* frosted red LED (fan speed)
You can compare the brightness to the stock buttons under the hvac. There is still a tiny hot spot on the "fan" icon on the hvac, but its not super noticeable in person, and I actually think it looks kinda cool.
I am extremely satisfied with the results this time.
Old 10-14-2008, 09:12 PM   #3
neilsan
neilsan is making his/her stupidity well-knownneilsan is making his/her stupidity well-knownneilsan is making his/her stupidity well-known
Much improved over the first attempt. Reminds me of being surprised that regular LED's didn't properly light up the light spreaders in my first S13's gauge cluster. I even tried bunching like 5 of them together in parallel, lulz
ah, youth
neilsan is offline   Reply With Quote
Old 10-15-2008, 01:33 AM   #4
SlideWell
SlideWell's Avatar
SlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfection
that my friend, is fucking awesome! good work!
SlideWell is offline   Reply With Quote
Old 10-15-2008, 01:44 AM   #5
96Turbo
96Turbo's Avatar
96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute
that looks better than OEM!! It's 10x better with the white led instead of just a red blur
great work man!
96Turbo is offline   Reply With Quote
Old 02-20-2010, 08:30 PM   #6
afiser
afiser is an unknown quantity at this point
just making sure, but by flat tipped you mean LED's that look like this?
afiser is offline   Reply With Quote
Old 02-20-2010, 09:06 PM   #7
DaPCWiz
DaPCWiz's Avatar
yep... message length
Old 02-23-2010, 07:06 PM   #8
afiser
just bought 2 of the white flat tipped as seen HERE
and 1 white 360 led for fan speed light seen HERE
will post results
Old 03-06-2010, 02:45 PM   #9
afiser
the bottom led works great (hot/cold light) but the top one has a noticable hot spot on the face/feet and the feet buttons. but im really not complaining that much, it's better than before when they didnt work at all. thanks for the write up.
Old 03-06-2010, 03:38 PM   #10
Smurf_240SX
Smurf_240SX's Avatar
Smurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choices
Send a message via AIM to Smurf_240SX
Nice write up, I need to try this too, mine aren't that bright anymore...
FS OEM RB25 PARTS
Smurf_240SX is offline   Reply With Quote
Old 03-06-2010, 06:02 PM   #11
R33E8
R33E8 is an unknown quantity at this point
If you sand down the dome of the LED so it's flat it should disperse the light a lot more.. Sanding the exterior in general will help do the same thing.. Just make sure you don't sand to far that you hit the bond wire and/or the die..
(picture to show what to avoid breaking)
R33E8 is offline   Reply With Quote
Old 03-07-2010, 04:52 PM   #12
afiser
im using a 680 ohm 1/2 watt on this led quoted, and it gets hot as shit. i used that single led calculator to calculate the resistor needed but it seems it is probably wrong...
Old 03-07-2010, 04:55 PM   #13
DaPCWiz
DaPCWiz's Avatar
honestly I don't know a whole lot about figuring that stuff out. I went to my local electronics shop, told him what I was doing and he gave me the right resistors.
Old 03-07-2010, 05:15 PM   #14
afiser
it's probably the $1, $4 shipped resistors that i ordered off ebay because none of my local electronic stores had the resistor i needed, now that i think of it.
dammit lol.
the 360 bulb looks damn good on the fan speed tho. thanks again for the specs.
Old 03-09-2010, 01:21 PM   #15
ADiamond240sx
ADiamond240sx's Avatar
ADiamond240sx is an unknown quantity at this point
Recently did this by just using the power from the circuit board. As stated earlier by OP the board sometimes does not power the lights and replacing the bulb does not always work. I discovered upon doing my LED install that this was actually because the contacts had worn down on the board. My solution was not to provide separate power though ... I just used longer leads on the t5 LEDs that I installed and made sure they were making good contact. I also made sure the LED's worked before the AC controller was put back together. On a side note, I also used t10 super brights in the cluster. Had to install them from the front as they will not fit through the back of the board. Looks pretty damn good. Also, using the boards power and GOOD 12 volt LED's allows the dimmer feature to still function.
I am going to have to try that white LED on the hot/cold bar though ... that looks pretty damn good.
Here's a pic of the cluster.
ADiamond240sx is offline   Reply With Quote
Old 03-10-2010, 12:34 AM   #16
az_240
az_240's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
You guys are still soldering those things in? Why not just get these>
http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=%2Fspecs%2FNEO .htm
The NEO3 bulbs are a direct replacement and the HP ones will look waay better.
They also sell the HP cluster bulbs that actually look white.... not like that shitty blue pictured above.
Old 03-10-2010, 02:44 AM   #17
ADiamond240sx
NeoWedge series LED Lamp Specifications
My my ... someone is a bit negative. Those are super brights BTW. Just not the crappy white ones that some people use. And BTW, super brights are not 'direct' replacement. They will not fit in through the back of the board.
Rebuilding it one bolt at a time. Got any spare bolts?
Old 03-10-2010, 05:21 AM   #18
az_240
az_240's Avatar
Trader Rating: (41)
^didn't know you were going for the blue blotchy look.
I've read a few people have used the neo3 bulbs without any issues. I will be trying it out soon.
Old 03-10-2010, 11:10 AM   #19
ADiamond240sx
Camera does not do it justice. Its actually dark blue and very even color. And yeah ... if you get any version of a super bright (the one's with 9 leds in a cluster) you are gonna have to take the gauges out of the cluster to install them. But I'm sure someone with your quit wit wont have any problems at all figuring that out.
Old 03-10-2010, 11:43 AM   #20
R33E8
LOL, super brights are crap.. Same shit you find on ebay.. If you want to talk about quality, use LEDs that at least have a manufacturer with easily accessible data sheets..
Old 03-10-2010, 12:51 PM   #21
ADiamond240sx
Umm ... superbright may be a brand but there are other manufacturers of super bright LED's. It is a style of LED. Crappy LED's won't dim, mine do. Ebay is not where I generally buy all my stuff. From the level of spite in your response I'll say I am sorry that you've had bad experiances with your choices in the past.
Old 03-10-2010, 09:15 PM   #22
az_240
az_240's Avatar
Trader Rating: (41)
Good thing you don't know what you're talking about.
They do have data sheets for all their LEDs on their site.
These are hands down the best LEDs I have had... and I've been through a few sets.
^here is my cluster using superbrightleds. I just need to change out that clock bulb with another white one I have.
^ebay LEDs.
Sure don't look the same to me...
Old 03-11-2010, 09:41 PM   #23
R33E8
REAL data sheet for a QUALITY LED:
http://cree.com/products/pdf/LEDlamp...SS&MSN&MSS.pdf
Brief info on a no-name/ebay quality LED:
5mm LED RL5-W15120 Specifications
Please tell me something I don't know about LEDs.. Because obviously I don't know what I'm talking about..
Old 03-11-2010, 10:01 PM   #24
az_240
az_240's Avatar
Trader Rating: (41)
^You don't... I just proved the ebay/lower quality lights are not the same as superbrightleds lights as you stated.
Old 03-15-2010, 02:44 AM   #25
beefcake6681
beefcake6681 will become famous soon enoughbeefcake6681 will become famous soon enoughbeefcake6681 will become famous soon enoughbeefcake6681 will become famous soon enoughbeefcake6681 will become famous soon enough
Soooo..... which LED's should I get for the cluster?
beefcake6681 is offline   Reply With Quote
Old 03-15-2010, 04:44 AM   #26
az_240
az_240's Avatar
Trader Rating: (41)
http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=%2Fspecs%2FWLE D-xHP5.htm
^these are the ones I have pictured above in white. You need 3 of them.
Old 11-16-2010, 05:12 PM   #27
smokei
smokei is an unknown quantity at this point
Not that I want to walk into a flame war on my first post here, as I really like both setups, but I was wondering if both setups were dimmable, and if so was really interested in an actual link to the different LED's used.
smokei is offline   Reply With Quote
Old 11-16-2010, 06:37 PM   #28
DaPCWiz
DaPCWiz's Avatar
My car has been sitting in a garage for the last ~year so I can't really check its dimmability right now. iirc - it didn't dim very well, it went down and did a couple steps - but it wasn't in "sync" with the rest of the lights in the car.
Old 11-17-2010, 11:23 AM   #29
smokei
Thanks for your quick response. The longer I stare at my cluster and different lights in my car, I consider if I want to go through the trouble. Great post and hope to see your car back on the road sometime.
Old 02-28-2011, 06:51 PM   #30
enkei2k
Super Moderator
Trader Rating: (29)
enkei2k is close to perfectionenkei2k is close to perfectionenkei2k is close to perfectionenkei2k is close to perfectionenkei2k is close to perfectionenkei2k is close to perfectionenkei2k is close to perfectionenkei2k is close to perfectionenkei2k is close to perfectionenkei2k is close to perfectionenkei2k is close to perfection
Feedback Score: 29 reviews
Sorry to bring up and old thread, but just wanted to let everybody know, the superbright LEDs DO fit on the back of the HVAC of an S14. You can use the NEOx-xHP bulbs, 3mm size and they will fit.
I don't have any before pics, but take my word for it when I say all the bulbs were burnt out.
assembled. Cluster is using the WLED xHP5 bulbs. HVAC has NEOx-xHP 3mm
I would highly recommend paying the extra and getting the HP version of their bulbs. I bought their regular LEDs on my first attempt and it was VERY blotchy and not at bright...you can barely see the kilometers.
Thanks to the OP DaPCWiz for this thread. Hope this helps anybody in the future.
Ask enkei2k
xquizitditz
enkei2k is offline   Reply With Quote
