Old 02-14-2008, 06:03 PM   #1
sr20powerd
sr20powerd's Avatar
sr20powerd is a glorious beacon of lightsr20powerd is a glorious beacon of lightsr20powerd is a glorious beacon of lightsr20powerd is a glorious beacon of lightsr20powerd is a glorious beacon of lightsr20powerd is a glorious beacon of lightsr20powerd is a glorious beacon of lightsr20powerd is a glorious beacon of lightsr20powerd is a glorious beacon of lightsr20powerd is a glorious beacon of lightsr20powerd is a glorious beacon of light
Odd Tire Wear
Please excuse the MS paint but I cant find my camera cable. On the inside of my tire, the tread is wearing funny, the tread block are not at the same level after the tread void, the next block is higher 1-2mm. This is just after about 4k miles. The car is lowered but it is only happening on the right side.
The red part is lower than the green
sr20powerd is offline   Reply With Quote
Old 02-14-2008, 06:04 PM   #2
nixad
nixad has made poor choicesnixad has made poor choicesnixad has made poor choicesnixad has made poor choicesnixad has made poor choicesnixad has made poor choices
bad ballance or just cheap rubber
nixad is offline   Reply With Quote
Old 02-14-2008, 06:07 PM   #3
sr20powerd
sr20powerd's Avatar
I have two sets of wheels and it's doing it to both so a problem with the wheel/tire is out of the question
Old 02-14-2008, 06:17 PM   #4
rhs13
rhs13's Avatar
rhs13 has a brilliant futurerhs13 has a brilliant futurerhs13 has a brilliant futurerhs13 has a brilliant futurerhs13 has a brilliant futurerhs13 has a brilliant futurerhs13 has a brilliant futurerhs13 has a brilliant futurerhs13 has a brilliant futurerhs13 has a brilliant futurerhs13 has a brilliant future
Send a message via AIM to rhs13 Send a message via Yahoo to rhs13
you need an alignment. damper might also need replacing.
PS are you just driving it from A to B, or sliding around?
cuz i dont give a fukk. that's why.
rhs13 is offline   Reply With Quote
Old 02-14-2008, 06:20 PM   #5
sr20powerd
sr20powerd's Avatar
Driving from a-b. By damper, do you mean shock?
Old 02-14-2008, 06:23 PM   #6
ho1ywars
ho1ywars's Avatar
ho1ywars is an unknown quantity at this point
bad struts will cause chop
ho1ywars is offline   Reply With Quote
Old 02-14-2008, 06:25 PM   #7
NemeGuero
No more nissan.
NemeGuero's Avatar
or uh.. camber?
Do you have any adjustability? 240s are notorious for having 1 side camber more than the other. (unless properly aligned)
Old 02-14-2008, 06:25 PM   #8
rhs13
rhs13's Avatar
yes.
damper/shock/strut
toe-may-toe / toe-mah-toe
Old 02-14-2008, 06:30 PM   #9
sr20powerd
sr20powerd's Avatar
I have tien HA's that are fairly new, about 18k. I hope that that wouldn't be the case, but i also wouldn't be supprised.
Old 02-14-2008, 06:35 PM   #10
nixad
ok so get a alignment check and rebalance and if its still the case ur dampering is f'in up
Old 02-14-2008, 06:41 PM   #11
bigOdom1
bigOdom1's Avatar
bigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfection
get an alignment with little toe and see if it helps
bigOdom1 is offline   Reply With Quote
Old 02-14-2008, 06:45 PM   #12
sr20powerd
sr20powerd's Avatar
Just out of curiosity, but what in the alignment would cause it? Camber,Caster,Toe?
Old 02-14-2008, 07:57 PM   #13
rhs13
rhs13's Avatar
probably all of the above. if you dont have adjustable toe/traction/rear upper arms and just slammed the car, you'd most likely have a good amount of positive toe and negative camber.
this is because the rear suspension was designed to toe out under squat/load/compression.
Old 02-14-2008, 08:05 PM   #14
sr20powerd
sr20powerd's Avatar
I keep realizing that I left so much info out. It's the left front tire on the inside, it has tension rods and camber plates(like all coilovers)
Old 02-14-2008, 08:20 PM   #15
rhs13
rhs13's Avatar
well in that case, get the alignment shop to check all of the above, assuming you know of a place that has that kind of capability.
i'd also recommend NOT putting all kinds of negative camber in the front.
Old 02-14-2008, 08:23 PM   #16
vaughn4
vaughn4's Avatar
vaughn4 is a splendid one to beholdvaughn4 is a splendid one to beholdvaughn4 is a splendid one to beholdvaughn4 is a splendid one to beholdvaughn4 is a splendid one to beholdvaughn4 is a splendid one to beholdvaughn4 is a splendid one to beholdvaughn4 is a splendid one to beholdvaughn4 is a splendid one to beholdvaughn4 is a splendid one to beholdvaughn4 is a splendid one to behold
did you ever get a good alignment after the coilovers? you are more than likely running a little toe in the front. get an alignment, however that tire will not wear down like it should. once a tire gets cupped like that it will stay like that.
vaughn4 is offline   Reply With Quote
Old 02-14-2008, 08:33 PM   #17
rhs13
rhs13's Avatar
werd. good point.
Old 02-14-2008, 08:44 PM   #18
zavala
zavala is making a name for him/her selfzavala is making a name for him/her self
toe and a tire being out of balance is what causes a tire to "cup" like that. and since you said it's not the wheel/tire balance then it's the toe. you have camber, caster, and toe. camber and toe are the two that cause tire wear, camber is usually bald shoulders either inside or out and toe causes the cupping cause the tire is literally not pointed straight forward and it's being forced across the pavement.
zavala is offline   Reply With Quote
Old 02-14-2008, 11:41 PM   #19
kouki_s14
kouki_s14's Avatar
kouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfection
Send a message via AIM to kouki_s14
if the shock is going bad then the tire can hop causing the tire to wear that way.
kouki_s14 is offline   Reply With Quote
