Old 09-11-2006, 07:40 PM   #1
ZX88
ZX88's Avatar
yeah so my rims came in
my sportmax 006 came in 17x8 +35mm offset all around on an s13 do you think i need spacers for the front and/or rear or should i be fine? i plan to run 225/45/17 all around as well.
Old 09-11-2006, 08:11 PM   #2
Jdotsturn
Jdotsturn's Avatar
Jdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond reputeJdotsturn has a reputation beyond repute
Send a message via AIM to Jdotsturn
you should be fine. if not run a smaller tire or get a small spacer
Jdotsturn is offline   Reply With Quote
Old 09-11-2006, 08:18 PM   #3
DreamDriveDrift
DreamDriveDrift is making a name for him/her selfDreamDriveDrift is making a name for him/her selfDreamDriveDrift is making a name for him/her self
Are you running stock suspension or a beefier coilover?
If it's the latter you MIGHT need spacers, test fit it and you will know.
DreamDriveDrift is offline   Reply With Quote
Old 09-11-2006, 08:51 PM   #4
ZX88
ZX88's Avatar
yeah sorry im running sportlines with gr2s and i have a feeling i will need spacersing in the front
Old 09-11-2006, 08:58 PM   #5
ZX88
ZX88's Avatar
i test fitted the rim in the front and its just about touching the strut you what size spacer do you think i would need 5mm? 10mm? 25mm? cause the rim sat flush with the fender. im asuming im also running 0 camber but im not sure.
Old 09-11-2006, 09:46 PM   #6
slammedS14
slammedS14's Avatar
slammedS14 is an unknown quantity at this point
Send a message via AIM to slammedS14
put up some pictures when ur done.
Amatuers built the ark. Professionals built the Titanic.
Representing nova area.
95' Nissan 240sx S14sr
slammedS14 is offline   Reply With Quote
Old 09-11-2006, 10:17 PM   #7
Irukandji
It shouldn't rub unless you have coilovers.
buttt.. if you insist that it's rubbing, just try putting some washers on your studs just to measure how thick of a spacer you'll need... do NOT use them as spacers though.. haha
Irukandji is offline   Reply With Quote
Old 09-11-2006, 11:36 PM   #8
OptionZero
OptionZero's Avatar
i vote for an "official sportmax fitment thread" to be stickied
OptionZero is offline   Reply With Quote
Old 09-11-2006, 11:42 PM   #9
youngmanvr4
youngmanvr4 is making a name for him/her selfyoungmanvr4 is making a name for him/her self
Well if you think about it, read all the 17x8 +35 FN's threads. Tons of threads on it...along with tons on info.
Most people run a 215/45 on a 17x8 +35 with FN's becuase anything wider will hit. So that given, with 225/45 you will probably hit. So if I were you I would use a 8mm.
But if your all about flushiness then this would be near perfect. 17x8 +35 with a 235/45/17 with 10mm spacer up front and a 15mm in the rear. This would give you room on the inside for the strut, no stretch on the tire, and really flush with only a roll...no pull needed...providing you dont have wheel tuck.
youngmanvr4 is offline   Reply With Quote
Old 09-11-2006, 11:58 PM   #10
240silvia
240silvia's Avatar
240silvia is an unknown quantity at this point
Send a message via AIM to 240silvia
I had 17x9 sportmax 962 +35 all the way around. 235/45/17, I had a 5mm in the front, and I was fine. PLEASE post some pics when you get done.
240silvia is offline   Reply With Quote
Old 09-12-2006, 01:23 AM   #11
hellion240sx
hellion240sx will become famous soon enoughhellion240sx will become famous soon enoughhellion240sx will become famous soon enoughhellion240sx will become famous soon enough
yes i would like to see pics as well
hellion240sx is offline   Reply With Quote
Old 09-12-2006, 01:26 AM   #12
bleachcola
bleachcola's Avatar
bleachcola is an unknown quantity at this point
do u have pics of the wheels?
bleachcola is offline   Reply With Quote
Old 09-12-2006, 01:36 AM   #13
hellion240sx
sportmaxwheels.com
Old 09-12-2006, 01:47 PM   #14
ZX88
ZX88's Avatar
photobucket is down right now so ill post the pics of the fitment hopefully tonight.
Old 09-12-2006, 01:51 PM   #15
Irukandji
17x9 + 25 will barely clear coilovers.
1inch = 25.4 mm ~ 25 mm
So you do the math.
Old 09-12-2006, 03:11 PM   #16
ZX88
ZX88's Avatar
*pics*
Front
strut clearance its really close (front strut)
flushness of front rim without spacer.
clearance for the rear should be fine.
i will probably need spacers in the front but do you think i will need extended lugs?
Old 09-12-2006, 06:10 PM   #17
240silvia
240silvia's Avatar
You can get away with 5mm spacers on the stock lugs, but, anything bigger, and you will have to get extended lugs. I really think you will be fine. I had 17x9 +35 and I used 5mm spacers. You have more clearance. The celarance you have, is 5mm more than I had with my spacers.
Old 09-12-2006, 08:48 PM   #18
DrtyRat
DrtyRat's Avatar
DrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfection
Originally Posted by ZX88
*pics*
Front
OEM jack FTW...I luv it!!!
America... Too soft to place a killer in a well deserved tomb, But brave enough to kill a baby before he leaves the womb
DrtyRat is offline   Reply With Quote
Old 09-12-2006, 09:06 PM   #19
Nizzan4u2nv
Nizzan4u2nv's Avatar
Nizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura about
Send a message via AIM to Nizzan4u2nv
If its flush with the fender that far away from the wheel, its not gonna be anywhere near there when its low. I believe those gr2 are slightly slotted on the spindle part so you might be able to get more clearance if you take more camber out. I think a 5mm should do it.
Nizzan4u2nv is offline   Reply With Quote
Old 09-13-2006, 02:12 PM   #20
ZX88
ZX88's Avatar
what lug nuts fit with these wheels is there a specific size or are they just tuner lugs. will these fit?
http://www.ezaccessory.com/Spline_Dr.../98-0357bl.htm
Old 09-13-2006, 03:44 PM   #21
Nizzan4u2nv
Those will work, they look like close end muteki's to me.
Old 09-13-2006, 03:51 PM   #22
ZX88
ZX88's Avatar
i think they are. im ordering the lugs and the tires tonight 225/45/17 falken Falken GR Beta FK-451 so ill probably get them in a week or so ill post pics when this is all over for those interested. oh and the 5mm spacers.
Old 09-13-2006, 10:27 PM   #23
hellion240sx
excellent iwant to see cuz i was thinking about bigger spacers
Old 10-14-2006, 02:48 PM   #24
toekneex04
toekneex04 is an unknown quantity at this point
did you ever get these wheels on your car with the right fitment? I was planning to get these wheels with the same specs. Please post pictures if you have them on.
toekneex04 is offline   Reply With Quote
Old 10-14-2006, 10:00 PM   #25
scottyb
scottyb is on a distinguished road
He posted the pics here: http://www.zilvia.net/f/showthread.php?t=120300
scottyb is offline   Reply With Quote
