Old 09-09-2006, 07:54 PM   #1
dktkd
dktkd is an unknown quantity at this point
Rotor/Wheel Stud Stuck :O
Whazzup,
So the tire place, cross threaded my lugs/wheel studs.
I suck it up and I'm off to fix it and might as well do a brake job.
So the stud naturally breaks off as expected.
However, I can't hammer it out. Rusted.
So I try to take off the rotor to get a better look
and angle. Won't come off either. I'm guessing rust.
I hit it with PB Blaster, however, I can't get all the nooks
and cranny b/c the rotor is still on.
Any suggestions on getting the rotor and wheel stud off?
Thanks,
DK
dktkd is offline   Reply With Quote
Old 09-09-2006, 08:00 PM   #2
s13silvia03
s13silvia03's Avatar
Location: PA.....I always thought that dogs...umm...layed eggs, and I learned something today
s13silvia03 has much to be proud ofs13silvia03 has much to be proud ofs13silvia03 has much to be proud ofs13silvia03 has much to be proud ofs13silvia03 has much to be proud ofs13silvia03 has much to be proud ofs13silvia03 has much to be proud ofs13silvia03 has much to be proud ofs13silvia03 has much to be proud ofs13silvia03 has much to be proud ofs13silvia03 has much to be proud of
Send a message via AIM to s13silvia03
Remove caliper, beat the rotor off of the hub, pound out wheel stud. Just use some muscle to get the rotor off, should come off with some force.
s13silvia03 is offline   Reply With Quote
Old 09-09-2006, 08:02 PM   #3
S13Koop
S13Koop's Avatar
S13Koop has a brilliant futureS13Koop has a brilliant futureS13Koop has a brilliant futureS13Koop has a brilliant futureS13Koop has a brilliant futureS13Koop has a brilliant futureS13Koop has a brilliant futureS13Koop has a brilliant futureS13Koop has a brilliant futureS13Koop has a brilliant futureS13Koop has a brilliant future
Send a message via AIM to S13Koop
I can't imagine why the rotor won't come off. Hammer some more and say good bye to the rotor for the sake of getting to the real problem, the stud.
Maybe try a good prybar
JZX100
S13Koop is offline   Reply With Quote
Old 09-09-2006, 08:33 PM   #4
LookOut Nick
LookOut Nick's Avatar
LookOut Nick has a reputation beyond reputeLookOut Nick has a reputation beyond reputeLookOut Nick has a reputation beyond reputeLookOut Nick has a reputation beyond reputeLookOut Nick has a reputation beyond reputeLookOut Nick has a reputation beyond reputeLookOut Nick has a reputation beyond reputeLookOut Nick has a reputation beyond reputeLookOut Nick has a reputation beyond reputeLookOut Nick has a reputation beyond reputeLookOut Nick has a reputation beyond repute
yeah just hit that bad boy with a hammer a few times to knock it off..i have a set laying around if its for your 4 lug s13 or 14
Team Pterodactyl
LookOut Nick is offline   Reply With Quote
Old 09-09-2006, 08:46 PM   #5
dktkd
Thanks guys.
My ears are ringing from all the hammering.
But I'll keep at it.
The fumes from the PB Blaster was getting to me.
I'll try again after dinner.
I'll try a torch if I can't get it off tonight.
Will I ruin my rotors?
Old 09-09-2006, 08:52 PM   #6
O3DigitalBath
O3DigitalBath's Avatar
O3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud ofO3DigitalBath has much to be proud of
Send a message via AIM to O3DigitalBath
^does it matter if you ruin the rotors? Didn't you say you were doing a brake job??? I mean thats usually pads and rotors.
There is no reason with a couple of spirited blows from the hammer the rotor won't slide off and then just get a decent size hammer and give the stud a few good blows and it will come out....
O3DigitalBath is offline   Reply With Quote
Old 09-09-2006, 08:55 PM   #7
Acecool
Acecool is an unknown quantity at this point
If it is rust, soak a rag in coke and then wrap it around the screw or whatever overnight. Coke should eat the rust away, also use ear protection if you hammer...
Acecool is offline   Reply With Quote
Old 09-09-2006, 08:56 PM   #8
dktkd
Sorry, I meant I was just replacing the pads since the rotors
were still in spec, asides from the not coming off spec.
Old 09-09-2006, 09:03 PM   #9
3day240sx
3day240sx is an unknown quantity at this point
there are two little holes in the rotor on opisite(sp?) sides of each other. take the right size and thread bolt and screw them into those holes. normally you can use the bolts that hold the caliper on but if there is a possibility that it could brake then get another set the same size as those. just twist them in until the brake or make the rotor release. if they brake then something else is wrong.
3day240sx is offline   Reply With Quote
Old 09-09-2006, 09:08 PM   #10
dktkd
Woo hoo.
Finally got the rotor off.
Hammer, hammer, hammer.
Waiting for the PB blaster to kick in for the wheel stud.
Time for dinner.
You guys rock.
Old 09-10-2006, 12:45 AM   #11
95zilvia
95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light
big
fucking
hammer
95zilvia is offline   Reply With Quote
Old 09-10-2006, 12:57 PM   #12
dktkd
The stud is still stuck.
It is deforming at the hammer end.
Asides from hammering any other suggestions.
Thanks.
Old 09-10-2006, 01:01 PM   #13
s13silvia03
Beating the piss out of it always worked for me, and I think I've replaced pretty much all of my wheel studs since I got the car...
Old 09-10-2006, 08:42 PM   #14
dktkd
I'm gonna go buy or borrow a heavier hammer/mallet/sledge hammer.
I'll let you know how it goes.
Old 09-10-2006, 09:15 PM   #15
Slidin240Wayz
Slidin240Wayz's Avatar
Wow, I never head of a stud indenting the hammer. That's some serious shit.
Carlos
Slidin240Wayz is offline   Reply With Quote
Old 09-10-2006, 11:59 PM   #16
3day240sx
get a big c-clamp and put one end right next to the stud on the hub and the other end on the end of the stud your beating the shit out of and tighten the clamp until it comes lose... or brakes the clamp and then take it to a shop to have them do it.
Old 09-11-2006, 01:13 AM   #17
AN89HATCH
AN89HATCH is a well-known jackass
yah use a big hammer! I used a small when trying to take out one of my striped studs, it did not do anything, and it knocked the head of the hammer off the handle lol I was like wtf? Then I used a bigger hamer, and in 2 hits it was out.
slide your ride.com
AN89HATCH is offline   Reply With Quote
